Classifieds » Miscellaneous » EOI: 13x6" Superlites
Callifo
Gawler, SA
EOI: 13x6" Superlites Thu, 11 March 2004 12:18 Go to next message
Just wondering what 13x6 superlites in charcoal colour are worth exactly? Got 6 of them here, was gonna use them but cant at the moment. They all have tires but they appear to be racing slicks so they basically need new tires.
Fit the sprinter but I have no idea what the offset could be. (any easy way of finding out?)
Re: EOI: 13x6" Superlites Thu, 11 March 2004 13:31 Go to previous messageGo to next message
'performance' superlites?
15x6 go for about 220-240 or so brand new.
13x6 i'm pretty sure are around 200 each..
used??? i'd buy em now if they were 4x110 Wink doh!
what condition are they in? if in very good/perfect, maybe 150-200 each? (what do you think?)
[Updated on: Thu, 11 March 2004 13:52]
Callifo
Gawler, SA
Re: EOI: 13x6" Superlites Thu, 11 March 2004 13:40 Go to previous messageGo to next message
Yeh Performance superlites, they are all in perfect condition bar 1 which has about a 1cm kurb scratch.
They look kind of like the black ones on http://www.performancewheels.com.au/super_lite_whe els.htm They are a lot darker though in person. Looking at that page though I seem to lack the centre 'cap'.
Re: EOI: 13x6" Superlites Thu, 11 March 2004 13:50 Go to previous messageGo to next message
superlites rock!! they make almost any car look good Very Happy and the charcoal ones even better! at the NRMA motorfest, there were soo many cars with them...
to be honets i'd prefer http://www.panasport.com/street.html but at $500+ a corner and importign from US?.. ahh.. no Wink
Performance superlites it will be Very Happy
oh.. bump Very Happy
Callifo
Gawler, SA
Re: EOI: 13x6" Superlites Fri, 12 March 2004 12:07 Go to previous messageGo to next message
Anyone? Smile
FKN16V
NSW, East Coast
Re: EOI: 13x6" Superlites Fri, 12 March 2004 13:17 Go to previous messageGo to next message
These are the rims ive been thinking about but not the right size. Idprefer the 15x7 myself thou if im unable to find any at the right price ill come back too ya, providing you still have them.
Callifo
Gawler, SA
Re: EOI: 13x6" Superlites Fri, 12 March 2004 13:25 Go to previous messageGo to next message
Yeh I put them up against my 15x6 Speedy Hyperfangs which have 195/50s and they are almost identical size. If you have some big tires they come out about the same size. They have racing slicks on at the moment so they look massive.
Any way working out the offset?
slydar
Re: EOI: 13x6" Superlites Sat, 13 March 2004 11:47 Go to previous messageGo to next message
call performance, theyll tell you. i am pretty sure they mostly only do 1 offset in each size. if they were 13 by 7 or 8, id be interested.
Callifo
Gawler, SA
Re: EOI: 13x6" Superlites Sat, 13 March 2004 12:27 Go to previous messageGo to next message
Bugger Smile
Any who I sent an email to performance and about it and Ill see what they say.
Looking all over the wheel there are a lot of numbers printed on it and the only one which stood out was 32JJ. That doesnt mean much does it?
Re: EOI: 13x6" Superlites Sat, 13 March 2004 15:38 Go to previous messageGo to next message
easy way to measure offset...
hmmm
measure distance from the flat part where hub face goes... measure from there to the outside of the rim in both directions
then subtract one from other...
http://www.yokohamatire.com/utcustom.asp
http://www.rsracing.com/tech-wheel.html
basically
Quote:
Wheel offset
The wheel's offset is the distance from its hub mounting surface to the centerline of the wheel. To determine wheel offset:
Position the wheel on a flat surface and measure its overall width.
Subtract the backspace and divide by two.
The offset of a wheel can be one of the following three settings:
Zero offset:
The hub mounting surface is even with the centerline of the wheel.
Positive offset:
The hub mounting surface is toward the front or wheel side of the wheel. Positive offset wheels are generally found on front-wheel drive cars.
Negative offset:
The hub mounting surface is toward the back or brake side of the wheel's centerline. "Deep dish" wheels are typically negative offset.
my rims have 90mm on brake side, and 60mm on curb side, so are +15 offset?
pretty sure that performance make multiple offsets..
Quote:
Available in Gold, Silver and Charcoal colours, genuine Performance superlite alloy wheels are made to order in most offset and PCD configurations. Racing purpose steel tapered inserts available upon request
brump
Callifo
Gawler, SA
Re: EOI: 13x6" Superlites Sat, 13 March 2004 22:37 Go to previous messageGo to next message
Well if its right then these wheels appear to be +30 offset. They are 110mm on the brake side and 50mm on the wheel side. That leaves 60/2 which is +30?
They also appear to have the "Racing purpose steel tapered inserts".
Callifo
Gawler, SA
Re: EOI: 13x6" Superlites Mon, 15 March 2004 08:08 Go to previous messageGo to next message
Bump :/
Callifo
Gawler, SA
Re: EOI: 13x6" Superlites Tue, 16 March 2004 11:18 Go to previous messageGo to next message
And up? Razz
Only have offer of like $120 from a mate so....
[Updated on: Tue, 16 March 2004 11:19]
TerryOBeirne
Redbank Plains,near Ipswi...
Re: EOI: 13x6" Superlites Wed, 17 March 2004 22:08 Go to previous messageGo to next message
what are the slicks like???> if they are not totally worn out, they will have dimples in them across the face. what brad/info off the side of them???. I may be a taker.
Callifo
Gawler, SA
Re: EOI: 13x6" Superlites Thu, 18 March 2004 00:29 Go to previous messageGo to next message
2 of them still have a good 3mm deep dimples left (in the centre, deeper on the outside), 2 others have about 2mm in the centre and other two getting close to bald in the middle (still have dimples but they are very shallow). Cant get pics of the tread for another week because the camera's gone on holidays.
Everything off the tire
Avon ACB10
x82545
7.0/22.0-13
Pic of them here http://www.mickeythompsontires.com/avon/acb10.html
Re: EOI: 13x6" Superlites Fri, 19 March 2004 06:19 Go to previous messageGo to next message
found out today 13x6 and 15x6 are about $210-220 each
7 and 8" are around $240 (all prices from Jax)
dammit, why couldn't they be 4x110!!!!
$120 for one or 4? Wink
pm me what you are after Wink i might grab em anyways Very Happy
Callifo
Gawler, SA
Re: EOI: 13x6" Superlites Fri, 19 March 2004 12:07 Go to previous messageGo to next message
Umm nope $120 for all six Im guessing, dont really know what I would do with the last two if I sold them as a set of 4. As for how much, not sure at this moment because anything towards getting my sprinter interior retrimmed would be cool (would definately consider trade for the stock jdm sprinter seats with rails Very Happy (a pair of my rails are bent T-18 rails Confused ))
Might try the trading post or something, as there would be more people in SA looking in that. The only problem with interstate is it might be a little pricey for shipping? (any idea how much it might be?)
Callifo
Gawler, SA
Re: EOI: 13x6" Superlites Sun, 21 March 2004 01:07 Go to previous message
Got the email back, they are infact +23 offset so I was close Razz
Previous Topic:ST205 Steering rack
Next Topic:FS: SC-14 Supercharger
Current Time: Tue Nov 3 15:55:31 UTC 2026
Total time taken to generate the page: 0.041847944259644 seconds
