Toymods » Tech & Conversions » Clutch Screeching
kristian
Clutch Screeching Wed, 14 August 2002 09:54 Go to next message
Hi guys
Clutch on my sprinter makes a screeching sound when pressed. Any ideas on what is causing this ? Could it be the thrust bearing ?
kingmick
Banned by his request
moved to tamworth
Re: Clutch Screeching Wed, 14 August 2002 11:20 Go to previous messageGo to next message
new clutch or old clutch? and yes can be the thrust bearing when the load comes off.
kristian
Re: Clutch Screeching Mon, 19 August 2002 11:01 Go to previous messageGo to next message
i guess old clutch. I have fitted 14 volks over the stock 13s and now the rpm surges from 3 to 4k, slipping like hell, id like to fit in a heavy duty clutch, how much these go for ?. im not really confident in DIY mechanic but im eager to learn Smile.
dorikin
NE Melbourne
Re: Clutch Screeching Mon, 19 August 2002 12:01 Go to previous messageGo to next message
can usually get stock spec clutches beefed up with around 30-40% increse in clamping pressure for not much at all. i have been quoted about $160 trade for this exact setup for a beefed up stock spec Sprinter clutch.
kristian
Re: Clutch Screeching Tue, 20 August 2002 01:56 Go to previous messageGo to next message
dorikin
how do you beef up a stock clutch ? $ 160 for the parts ? how about the labour, i also need the replace the spigiot or thrust bearing
faulksy
Re: Clutch Screeching Tue, 20 August 2002 03:32 Go to previous messageGo to next message
you should be able to buy the thing as a compete package
raSkaS
Perth WA
Re: Clutch Screeching Tue, 20 August 2002 03:36 Go to previous messageGo to next message
You will probably get the clutch release bearing with the clutch disk and pressure plate as a kit,not sure bout the spigot bearing
just go to a clutch specialist (some one who builds them) and ask to have the pressure plate upgraded, also ask what the original clamping pressure is
ive had a daikin pressure plate upgraded for me AE92 for 500lbs to 2200lbs
Cam
CrAiGzEE
south of the big smoke
Re: Clutch Screeching Tue, 20 August 2002 08:42 Go to previous messageGo to next message
Raskas how much did that set you back as i will be looking to do it soon
raSkaS
Perth WA
Re: Clutch Screeching Wed, 21 August 2002 00:08 Go to previous messageGo to next message
well i got it in NZ and for cost from a company called BNT ( not sure if thats a australian company or not ), anyway it cost me $360 for the 1 ton pressure plate + a brass button clutch plate + a release bearing. So it would have been less if i got an organic clutch plate
Retail i guess is probably around 30% more
Cam
faulksy
Re: Clutch Screeching Wed, 21 August 2002 06:18 Go to previous message
no you dont usually get a spigot bearing with the clutch as it isnt usualy considered part o the clutch assembly. but it would be stupid not to replace it while you have the gearbox out
Previous Topic:The Different Types Extractors
Next Topic:HELP: KE30 Conversion
Current Time: Thu Oct 22 08:59:55 UTC 2026
Total time taken to generate the page: 0.073870897293091 seconds
