Toymods » Tech & Conversions » [urgent] - where to earth the negative battery strap?
ae86drift
sydney.au
[urgent] - where to earth the negative battery strap? Thu, 11 March 2004 22:45 Go to next message
directly onto the bellhousing?
or directly betten the BH and the starter? or onto the starer itself?
its a 4age RWD (ae86)
quick help is good help. i searched but there is nothing specific and google is vague as
[Updated on: Thu, 11 March 2004 22:49]
Re: [urgent] - where to earth the negative battery strap? Thu, 11 March 2004 22:57 Go to previous messageGo to next message
I use two - one to the chassis of the car and the other to the engine block.
feral4mr2
Bundaberg, Qld.
Re: [urgent] - where to earth the negative battery strap? Thu, 11 March 2004 22:59 Go to previous messageGo to next message
Freak you should have at the least an earth strap from the battery to the chassis to the engine/gearbox.
bolt it to your gearbox somewhere on a nice big bolt/nut.
it doesnt need to go onto your starter, just as long as it's on the engine/gearbox.
ae86drift
sydney.au
Re: [urgent] - where to earth the negative battery strap? Thu, 11 March 2004 23:00 Go to previous messageGo to next message
where do you buy a dual strap of decent quality from? repco? supercheap? how much??
also can you earth to the head? or is it not a good idea?
[Updated on: Thu, 11 March 2004 23:03]
feral4mr2
Bundaberg, Qld.
Re: [urgent] - where to earth the negative battery strap? Thu, 11 March 2004 23:10 Go to previous messageGo to next message
Freak i use good quality 4 guage stereo power cable.
the head on my car is earthed. not a 4 guage like the others, i will upgrade it oneday.
ae86drift
sydney.au
Re: [urgent] - where to earth the negative battery strap? Thu, 11 March 2004 23:13 Go to previous messageGo to next message
my head is earthed to the chassis from the engine lift hook
im wondering if i can earth both the negative battery strap and the head from the same spot?
err whats this? im not a stereo head.
is it that thick cable covered in red clear plastic?
[Updated on: Thu, 11 March 2004 23:19]
Re: [urgent] - where to earth the negative battery strap? Thu, 11 March 2004 23:25 Go to previous messageGo to next message
The more earth straps the better. I choose to use 3 straps. 1 to the engine, 1 to the front chassis rail and 1 to the rear chassis rail. Having a voltage potential between 2 earth point can and will cause rust and corrosion.
Lambolica
Northwestern Sydney
Re: [urgent] - where to earth the negative battery strap? Thu, 11 March 2004 23:56 Go to previous messageGo to next message
Resulting in a bad Earth??? Laughing
Sorry Cool1 can you clarify that last statement? Does 3 points solve the corrosion problem or reduce the risk??
NVD05X
parra
Re: [urgent] - where to earth the negative battery strap? Fri, 12 March 2004 07:30 Go to previous message
i dont think there is any evidence to say that is true...
i've heard the theory though...
basically the more earths the better because current actually flows from negative to positive so if you have a small earth lead or a bad earthing point the current will encounter resistance and give you problems...
you can buy very good earth straps from supercheap for like 50 bucks... it even comes with o-ring terminals
Previous Topic:mechanic help
Next Topic:GA70 Supra Misfiring?
Current Time: Wed Nov 18 22:14:30 UTC 2026
Total time taken to generate the page: 0.052731990814209 seconds
