Toymods » Tech & Conversions » 2 pin flasher unit
2 pin flasher unit Fri, 12 March 2004 01:50 Go to next message
Hello, does anyone know how the 2 pin flasher (indicator) relay unit thing is meant to work? Is it just signal in from the switch - signal out - to the indicator?
I dont quite understand how this would work..
I'm trying to work out why the indicators in a mates 1975 lancer don't work and so yeah, trying to understand the flasher unit better.
Joel
Lambolica
Northwestern Sydney
Re: 2 pin flasher unit Fri, 12 March 2004 02:05 Go to previous messageGo to next message
Somthing I found a while back when I was aking the same question
Hope it helps
The Flasher Relay
A flasher relay is a self-actuating switch. It turns itself on and off as current flows through it.
A relay is just a electrically controlled switch. Instead of manually flipping the switch on or off, the switch is controlled by applying voltage to it. A relay is most commonly implemented using an electro-magnet to move the switch mechanism.
A flasher relay is just a special kind of relay: it's a relay that opens and closes itself automatically. Most automotive flasher relays have a electro-magnet that controls current flow. It's this electro-magnet opening and closing the switch that makes the clicking noise inside the relay. What makes each type of flasher relay different is the switching technology used to operate the relay.
There are a few types of flasher relays:
Thermal (Thermo-Couple)
Electro-Mechanical
Electronic (IC controlled)
A Thermo-Couple Flasher is packaged in an heat-tolerant aluminum "can". It uses a thermal-mechanical switching mechanism to control current flow to the bulb directly, unlike electro-mecanical or electronic flasher relays which use an electro-magnet.
The thermal switch is designed with two paths for current to flow. We'll refer to the initial-position of the switch as "open". In the initial position, the switch allows current to flow, but not fast enough to light the bulb. In this "open" position, the switch actually looks like a resistor. (e.g. The Tridon Stant 552 thermal flasher I disected has a resistance of 42.9 Ohms across the 2 terminals, X and L.)
When voltage is applied to the switch, current flows through it heating it up and causing it to bend and "close". In its closed position, the switch creates a less restrictive path for current to flow--enough current to cause the bulbs to flash on.
The bulb continues to draw current until the switch cools enough to bend back to its initial "open" position. And the cycle continues...
An Electo-Mechanical Flasher uses a different switching mechanism. Typically it uses what's called a "tank circuit." A tank circuit uses a coil or inductor and a capacitor togeather. In the case of a relay, the coil is working double duty because we're using the magnetic field it creates not only to store a charge, but to operate the relay itself.
You have to know a little about how inductors (e.g. a coil) and capacitors work and how they interact to understand how a tank circuit works. The capacitor and coil both are able to store a "charge". A coil stores a charge in a magnetic field, whereas a capacitor stores a charge in an electric field. A coil tends to resist change in current, whereas a capacitor tends to resist change in voltage. When you connect a properly selected coil and capacitor in parallel and apply voltage, the circuit will essentially store a charge by "bouncing" it back and forth between the coil and capacitor.
Here are some links that describe how a tank circuit works:
From the "Electrical Engineering Training Series" chapter on "Tuned Circuits". How the Parallel-LC Circuit Stores Energy
An Electronic Flasher typically incorporates an intigrated circuit (IC) and other components to control the relay. The IC controls precicely the rate in which the relay opens and closes and isn't dependant on the load like a thermal or electro-mecanical flasher relay, but many implement this behavior in the IC itself. That is, the IC is smart enough to know when one bulb is burnt out and adjusts the speed of the relay to "fake" the behavior of the thermal flasher relay.
I don't have a schematic of these, nor do I know how they work internally. They are the norm in automotive applications today. In any case, the important part is to know what the job of the relay is, and what the terminals are for. In the computer science arena we'd say "look at it as a black box. Abstract away from the internal details, and work with the interface." In this case and ironically enough, we're literally working with a black box, and the interface is the terminals sticking out of it. Smile
Depending on the implementation of the flasher relay circuit, it may have between 2 and 4 terminals. Depending on the origen of the relay (where and by whom it's manufactured) the terminals may be labeled differently.
Minimally the relay is going to have 2 terminals. One is the input from the battery and the other is the output to the blinker bulbs through the turn signal or hazard switch.
Re: 2 pin flasher unit Fri, 12 March 2004 02:14 Go to previous messageGo to next message
funny you should mention this, i pulled one apart the other day Very Happy
mine was connected to the poer IN to the switch, and the switch determines which indicator lights up.
basically, inside is a bimetallic strip which forms a switch. power goes thru this strip which heats up and then bends and opens the switch (like a thermostat bimetallic switch for airconditioner?) the strip is thin, so it cools down quickly, and then flicks back and closes the circuit again.
the top one of these
http://www.machinedesign.com/Content/Issue/10627/BimetallicSwitches.gif
if a globe blows and shorts, more current goes thru the flasher unit, and it will have shorter on periods. if a globe is totally blown, then less current goes thru and it stays 'on' for longer.
hope this helps Smile
Re: 2 pin flasher unit Fri, 12 March 2004 02:16 Go to previous messageGo to next message
doh, beaten to the punch Wink Very Happy
Lambolica
Northwestern Sydney
Re: 2 pin flasher unit Fri, 12 March 2004 02:18 Go to previous messageGo to next message
Ah-Ha Very Happy
But yours has pictures Crying or Very Sad
[Updated on: Fri, 12 March 2004 02:19]
Re: 2 pin flasher unit Fri, 12 March 2004 02:20 Go to previous messageGo to next message
TurboRA28 wrote on Fri, 12 March 2004 12:50
Joel
it should go something like
battery - flasher unit - indicator switch - lights - body
either there's no power to the relay can/switch, or the lights are not grounding properly (they usually do it thru the body work)
check for power everywhere when the switch is on, and then work back from globe to see if you have continuity to ground.
Re: 2 pin flasher unit Fri, 12 March 2004 03:41 Go to previous messageGo to next message
Thanks all for the info! This should get me out of trouble Smile
So would you have a flasher unit for left and right, or it somehow is shared?
Lambolica
Northwestern Sydney
Re: 2 pin flasher unit Fri, 12 March 2004 03:48 Go to previous messageGo to next message
Logic would say yes there would be left and right and usually a separate one for hazards. But I don't know for sure when i was looking into it it was to fix the hazzards which had it's own relay.
Re: 2 pin flasher unit Fri, 12 March 2004 04:21 Go to previous messageGo to next message
The flasher has +13v at the terminals. So must be earth problem eh?
Re: 2 pin flasher unit Fri, 12 March 2004 06:50 Go to previous messageGo to next message
probably... turn the indicator switch on, then measure continuity from the flasher can output, to ground..
on my rolla (KE15) the flasher can is BEFORE the switch, which is why it only has 2 pins... since it flashes for both 'channels'
if it is after the switch, then you need flasher for each channel (sometime sin same can as lambolica said)
clubagreenie
1st street on the right
Re: 2 pin flasher unit Fri, 12 March 2004 14:07 Go to previous messageGo to next message
I personally in either Jap, American or British elecs seen a flasher after the switch as this would inded require two (by my way of thinking). Power runs to the unit (any no of pins). Then to the switch which decides which side to send the flash to. This is how it's shared.
EDIT: The multi pin (more than two) has outputs for earth and something else that temporarily escapes me (Look at the time).
[Updated on: Fri, 12 March 2004 14:14]
hemi twofifteen turbo
Re: 2 pin flasher unit Mon, 15 March 2004 07:06 Go to previous message
I use an electronically controlled flasher can,
which is controlled by a microcontroller which
is temperature compensated so has an exact delay.
It also incorporates 2 adjustable knobs on the dash
i can use to further 'tune' the indicator time.
One says the on time, the other the off time.
So when i'm feeling kind of daring, i'll turn the
speed right up, but for sunday cruises i like to have
it real slow.. (around 1--2 seconds off, and a big lazy
4 second on)
I can also simulate 80's white vans changing lanes
with a .1 second on time and a .8 second delay.
These flasher cans come complete for $49.95 with mounting
bracket and 1.2 m of connecting wire. (available in red/blue anodised aluminium, or powder coated black.
[Updated on: Mon, 15 March 2004 07:09]
Previous Topic:3t-gte what car ??
Next Topic:Monroe struts - rebuildable?
Current Time: Sun Oct 25 03:59:16 UTC 2026
Total time taken to generate the page: 0.0053670406341553 seconds
