Toymods » Tech & Conversions » ECU options for the st162
dar_sbb
ECU options for the st162 Fri, 12 March 2004 02:29 Go to next message
What ecu options are available for the st162??
price and pro & cons.
smt_007
Re: ECU options for the st162 Fri, 12 March 2004 04:57 Go to previous messageGo to next message
Hey man i just saw in your sig, that your motor is bored to 2.2L Shocked , how did you do that and howmuch money?, and what motor is it?, gen1 3sge?.
As for computers you can get Motec, autronic etc but the computers alone cost $2000, your better off getting a BEAMS 3sge or a 3sgte Smile.
[Updated on: Fri, 12 March 2004 04:58]
RWDboy
Re: ECU options for the st162 Fri, 12 March 2004 15:35 Go to previous messageGo to next message
You can not put a piggy back ecu on ST162s...
As mentioned above, grab an autronic/motec or something along those lines.
Note : Beams 3S-GEs cost $6000 at least, whereas you can probably get a decent ecu installed for $2000 (try Autronic).
sideshow
Re: ECU options for the st162 Fri, 12 March 2004 20:43 Go to previous messageGo to next message
by the time u finish installing an autronic u will be up for about 3000 to 3500
u need modules and reluctor interfaces for an autronic when fitted to a toyota
basically tell me how much u want to spend and ill tell u what u can get with that money
plus need to know is the engine runnin at the moment
do u just need the ecu wired up or the rest of the engine/body loom aswell
RWDboy
Re: ECU options for the st162 Sat, 13 March 2004 00:39 Go to previous messageGo to next message
Autronic may be a bit more expensive than I stated Smile
sideshow -> would the 3000-3500 include tuning or just wiring the thing?
RWDboy
Re: ECU options for the st162 Sat, 13 March 2004 03:35 Go to previous messageGo to next message
Also - you'll notice his sig says 'TVIS' so that would be a fairly good indicator that it is a gen 1 3S-GE.
You would need to bore out approximately 4mm (to make the car 90mm bore) to get a shade under 2.2litre capacity. There is a fair bit o' room in the 3S-GE block, so it could be possible - I think. I would imagine it's just a case of buying some over-sized pistons/piston rings and getting the block bored.
sideshow
Re: ECU options for the st162 Sat, 13 March 2004 07:43 Go to previous messageGo to next message
its hard to quote
2200 is price for latest autronic i think
150 for reluctor interface
250 for module bosch 008 new
400 to 700 for a neat job
depends on condition of wiring eg. is car already runnin
or does the rest of the engine harness needs wirin to power up alternbator dash oil temp etc
150 maybe to get dizzy modified to suit (grind teeth of the pickups)
then u have to pay someone to tune it
the new autronic suppose to be able to suit toyota dizzys or cas
but i havnt heard if its out yet
autronic aint as straight forward as others just to let u know
but its a bloody good ecu
dar_sbb
Re: ECU options for the st162 Sat, 13 March 2004 11:39 Go to previous messageGo to next message
Yeah its bored... just under 2.2l... bored out bout 3mm
I was hopin for a piggy back system... but thats a no go yeah...
I was looking at the beams 3sge... sounds fantastic... but i tried to find a place for the engine... a guy quoted me 4300 plus 6spd box but there is a waiting list on the engine
can the head/inlet/exhaust manifold bolt onto the block??
smt_007, i blew the engine around two years back and i was going to plug in a mr2 3sge (same as 2nd gen) but when i found out bout TVIS, i loved the concept and decided to rebuild.. did rebuilding myself... just got machine shop to bored out. But as i find out, TVIS isnt that crash hot... thats wr the BEAMS comes in Smile
RobST162
Re: ECU options for the st162 Sun, 14 March 2004 23:49 Go to previous messageGo to next message
is that a FWD 6-speed? Shocked
Classique71
Colac, Victoria
Re: ECU options for the st162 Mon, 15 March 2004 01:35 Go to previous messageGo to next message
beams is a rwd 6 speed - came out of the rs2000 atezza
as for ECU's - Wolf have a setup for it - i know theve got an ecu plugin available ( theve done a few mr2's and clubmans with 3sge's )
webpage is www.wolfems.com.au
If you call them - ask for steve taylor
RWDboy
Re: ECU options for the st162 Mon, 15 March 2004 02:17 Go to previous messageGo to next message
I think the gen2 3S-GE can be piggy-backed, but not the gen 1 - don't quote me on this though.
dar_sbb
Re: ECU options for the st162 Mon, 15 March 2004 06:59 Go to previous messageGo to next message
ohhh... the gen 1 cant be piggy backed....
i'll see if i can find out
smt_007
Re: ECU options for the st162 Mon, 26 April 2004 03:42 Go to previous messageGo to next message
You can get a unichip for the 3sge, but theres not much performance increase on a stock motor, there will be some increase but it would be better if you atleast got some performance cams.
CelicaTurbo
Re: ECU options for the st162 Mon, 26 April 2004 03:53 Go to previous messageGo to next message
Man you can't go past an EMS for $995. And you don't need anymore parts to make it work. Its compatable with your dizzy, igniter etc. Real easy to install and tune too.
smt_007
Re: ECU options for the st162 Mon, 26 April 2004 03:56 Go to previous messageGo to next message
is that a piggyback setup or standalone?.
RWDboy
Re: ECU options for the st162 Mon, 26 April 2004 04:01 Go to previous messageGo to next message
None of the piggy back chips will change the injector timing...afaik, only the ignition timing.
dar_sbb
Re: ECU options for the st162 Mon, 26 April 2004 10:48 Go to previous messageGo to next message
What about remapped ecu's?
RWDboy
Re: ECU options for the st162 Mon, 26 April 2004 11:51 Go to previous messageGo to next message
I don't know if it's possible to remap the ECU with the 1st gen 3S-GE...subsequent ones might be easier though. If there's one part of the St162 I'd gladly call a 'turd' (compared to the rest of the car) it would be the factory ECU.
CelicaTurbo
Re: ECU options for the st162 Sat, 08 May 2004 01:24 Go to previous message
Remapped ecu's suck anyway. As soon as you mod your car a bit more or change something you need to get it remapped again. The EMS i was talking about is a full replacement ECU. You just use a laptop to retune it whenever necessary. For the price i say you can't go by one!
Previous Topic:4age flywheel bolts - Nm???
Next Topic:Full coolant system flush
Current Time: Sun Oct 18 03:19:28 UTC 2026
Total time taken to generate the page: 0.0098769664764404 seconds
