Toymods » Tech & Conversions » AE92 4AGZE questions
redgti2
geelong
AE92 4AGZE questions Fri, 12 March 2004 06:04 Go to next message
Hey guys. I got an AE92 GTi
Ive found a front cut from a AE101 for $2850. Is this a good price?
What do you think is a fair price if i went to a shop to have it fitted?
I think a friend of mine will be fitting it, but if i get a shop to do it, i will probably have a waranty on labour
-Sean
jasonp1977
Re: AE92 4AGZE questions Fri, 12 March 2004 06:22 Go to previous message
that's at least $600 too expensive for my liking...
The labour to put it in is stuff all, so dont be too concerned about getting warranty on that.
You will need a mechanical speedo drive from an ae92 or AW11 E series gearbox for your speedo to work. You will also need an ae92 GTZ rear gearbox mount or a modified C series rear mount for it to bolt in cleanly.
Fitting by a shop will range anywhere from $1K-4K depending on what parts they change and if they know what they're doing or not.
You may also need a tacho converter unless you're good with electronics, as the GTi tacho wont work with the GZE.
I wouldn't install the motor without putting a new timing belt, waterpump, seals etc through the motor, I'd also check the clutch as a bare minimum as it's a complete pain in the neck to do once the engines in the car.
Previous Topic:4age timing set
Next Topic:pictures of porting and CC's on 3K bigport head
Current Time: Thu Nov 19 00:30:28 UTC 2026
Total time taken to generate the page: 0.0053770542144775 seconds
