Toymods » Tech & Conversions » MAP ECU pickup when using quad throttles with trumpets
AbaddonGZE
MAP ECU pickup when using quad throttles with trumpets Wed, 14 August 2002 11:13 Go to next message
Does anyone have any experiance with trumpets on the 20V ?
Im thinking I will prolly have to t-piece all 4 after the butterfly's and run that to the ecu sensor?
or can you just pick of one? (perhaps too jittery)
1bam777
Perth WA
Re: MAP ECU pickup when using quad throttles with trumpets Wed, 14 August 2002 11:39 Go to previous messageGo to next message
Is it to suit an already running 20v or to adapt to a 16v?
AbaddonGZE
Re: MAP ECU pickup when using quad throttles with trumpets Wed, 14 August 2002 11:57 Go to previous messageGo to next message
for a 20V thats going in my AW11.
Its still got the stock plenum on it but im doing away with that (unless i have to keep it)
1bam777
Perth WA
Re: MAP ECU pickup when using quad throttles with trumpets Wed, 14 August 2002 14:15 Go to previous messageGo to next message
is it for a 20V ECU or the std ECU? The standard ECU will not work with the 20v motor. Totally different fuel and ignition maps. If its for the 20v ECU, then there should be a pickup on the intake manifold that already has a port where you can tap into.
Sam
Sydney, Australia
Re: MAP ECU pickup when using quad throttles with trumpets Wed, 14 August 2002 16:53 Go to previous message
If it's a silvertop 20V then it will use an air flow meter (AFM) which means it's impossible to remove the airbox and retain the factory ECU. Blacktop 20V's on the other hand are MAP sensored so it may be possible.
Previous Topic:3S-GE/GTE into ST162
Next Topic:Supercharged a 5/6me/ge?
Current Time: Thu Nov 19 21:39:53 UTC 2026
Total time taken to generate the page: 0.012151002883911 seconds
