Toymods » Tech & Conversions » AE86 rollcages?
genkin
AE86 rollcages? Sat, 13 March 2004 04:38 Go to next message
just a few quick questions about ae86 rollcages (bolt in)...
* Is there a difference between hatch and coupe rollcages?
(most ae86 rollcages i see advertised don't specify)
* Are bolt-in types (with padding) generally legal for street use? Should i expect it to pass roadworthy test or not?
* What are some good ae86 bolt in rollcage makers?
SprinterBoy
Re: AE86 rollcages? Sat, 13 March 2004 05:08 Go to previous messageGo to next message
It depends on how many point you want, be it pre made to 'bolt in'
Cages are only legal (in ACT anyways) if it's engineer'd and if its a 3\4 cage.
Don't know of any, try an parts importer, but there are pre made ones, a friend of mine has one in his trueno
genkin
Re: AE86 rollcages? Sat, 13 March 2004 05:13 Go to previous messageGo to next message
a few more quickies...
* what price should i expect to pay for a fairly rigid (maybe 5-6 point) welded rollcage.
* what is a good place to get this done and engineered?
SprinterBoy
Re: AE86 rollcages? Sat, 13 March 2004 05:21 Go to previous messageGo to next message
well. my mate with a supra TT AERO got a cage put in his, it's 6point and cost bout 3G
ae86drift
sydney.au
Re: AE86 rollcages? Sat, 13 March 2004 15:01 Go to previous messageGo to next message
i have a half cage
came in my car when i got it
currently out of my car as i need passenger space
Cusco make the "safety 21"
a full bolt-in cage
costs $1000+
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: AE86 rollcages? Sat, 13 March 2004 15:23 Go to previous messageGo to next message
i just fitted a cusco cage today,m bolt in type, Has a main hoop, two braces, once for each wheel arch, and a cross over brace.
All bolted in perfectally, took me longer to look around the work shop for hightenstile nuts and boltsw then it did for the ctuall driling and install process!
works a bloody treat, chassis is so much stiffer
ae86drift
sydney.au
Re: AE86 rollcages? Sat, 13 March 2004 15:35 Go to previous messageGo to next message
haha
i wanna stick mine back in now you said that
my cage sounds like yours
Wink
defectable though... Sad
Simon-AE86
Banned user
Re: AE86 rollcages? Sat, 13 March 2004 15:38 Go to previous messageGo to next message
not if the main hoop is 30 cm from peoples heads, and the car is registered as a 2 seter,
Paint cage same colour as interiour Wink
Re: AE86 rollcages? Sat, 13 March 2004 15:49 Go to previous messageGo to next message
check with your local big brother about what is acceptable.. in NSW, they have pretty diagrams to measure cage clearance from soft people bits, BUT the cage doesn't even have to be bolted in! can just sit there....
go figure...
anyhoo, better to check first, than be busted later.
heh heh, i'f they'd let us wear helmets for street driving, clearance to cage wouldn't be such a prob Razz heh heh
Seadog
Re: AE86 rollcages? Sun, 14 March 2004 01:09 Go to previous messageGo to next message
Check with Youngy, he just put a cage in his (welded in) and he is paranoid about it all being legal so he should know what you can or can't do in NSW.
ae86drift
sydney.au
Re: AE86 rollcages? Sun, 14 March 2004 02:18 Go to previous messageGo to next message
Simon-MrRx7 wrote on Sun, 14 March 2004 02:38
it is already black
but i might go and get it powercoated matte finish
genkin
Re: AE86 rollcages? Mon, 15 March 2004 01:29 Go to previous messageGo to next message
thanks for all the replies guys.
Im still unsure whether a 3dr rollcage will fit in a 2dr body without cutting up the parcel shelf chassis. can anyone give me a definate answer?
Simon: where did you get your cusco rollcage? what type is it? 6p? did you get it new from a cusco dealer?
ae86drift
sydney.au
Re: AE86 rollcages? Mon, 15 March 2004 02:28 Go to previous messageGo to next message
the ae86 chassis is the same regardless of coupe/hatch
all the ae86 cages i have seen are bolted just behind the front seat mount for the main hoop and onto the front side of the rear wheel arch each side for the "struts" and then between the struts for a cross brace
http://www.jspec.com.au/garth/147%20(35).jpg
JDM hachi
was adelaide now newcastle
Re: AE86 rollcages? Mon, 15 March 2004 03:01 Go to previous messageGo to next message
that roll cage is the same as mine, dont think that it will pass though, the drivers seat when adjusted back on its rails puts your head about 6 inches from the b-pillar posts, maybee you can rig your seat so that if you get it engineered, you can only move the seat back about 1 inch, im kinda short so this might work for me, but not all,
matty.
frank_grimes
Re: AE86 rollcages? Mon, 15 March 2004 06:39 Go to previous messageGo to next message
My cage sits about the same place but it doesn't have that middle piece..
http://members.optusnet.com.au/~mjaworski/DCP01255.jpg
garyskl
Re: AE86 rollcages? Mon, 15 March 2004 11:14 Go to previous message
Most rollcages fit both 2 dr and 3 dr. Cusco, Stillway, TBO, and so on. Some made from steel and alloy. Prices varies with points. For a Cusco 6 point, about 1100+, u need to specify whether u have sunroof and whether it is going to be a 2 seater or 4 seater.
Previous Topic:Fitting A series engine where R or S came from
Next Topic:7afe ae86
Current Time: Sat Oct 24 08:30:27 UTC 2026
Total time taken to generate the page: 0.0056369304656982 seconds
