Toymods » Tech & Conversions » Some 1GGZE Tech Help!
gtv6gp
icon5.gif  Some 1GGZE Tech Help! Wed, 14 August 2002 12:17 Go to next message
Hey Guys!
whats up just joined.
i have recently brought a 1ggze supercharger SC14.
im am using for a coustom kit..
some questions i have,
what oil to use in the charger, i was told 90wieght.
any other ideas?
also i need to know how the clutch system is set up on the toyota engine. how it works on the vacume switches where they are, how the engine sucks air when the charger is off?
is there any manuals online or anything?
how could i set up the kit to work on a diffrent engine what needs to be done.
what ever ideas and help would be grate.
gtv6gp
Re: Some 1GGZE Tech Help! Thu, 15 August 2002 09:04 Go to previous messageGo to next message
does anyone know?
ChuckLandwehr
Re: Some 1GGZE Tech Help! Thu, 15 August 2002 10:57 Go to previous messageGo to next message
Hey Buddy, good to see a new name on the forums.
The oil you require for the supercharger is available through Toyota spare parts departments.
The Clutch works the same as an airconditioner clutch. The cluth engages and drives the supercharger above 1200rpm. You could use a simple toggle type on/off switch, as used by the guys who set up 1GGZE superchargers on 3.8 litre V6 Commodores.
The manifolding on GZE engines has a blower bypass, through which intake air is drawn when the supercharger is "off"
Hope this helps "a little"
regards Chuck
gtv6gp
Re: Some 1GGZE Tech Help! Thu, 15 August 2002 16:26 Go to previous messageGo to next message
thanks for the reply
hmm i guess i need to rig some air bybass system for when its off. any ideas on that.
i would be good if anyone has some pictures of that part of the engine. i cant find any.
woulD you know a alt oil to use, i was told a 90W snth, whats the OEM worth.
i might have to make the pulley smaller. but with the clutch setup it aint very smart. what diffrent on the HKS one.
also i need to convert it to a Vbelt ..ideas?
E30-323ti
Re: Some 1GGZE Tech Help! Thu, 15 August 2002 20:33 Go to previous messageGo to next message
The HKS pulley is for the crank not the S/C, you leave the S/C pulley as is.
I think the toyota oil is about $30 for 50ml, need 100ml from memory.
Grant
Newcastle, NSW, Australia
Re: Some 1GGZE Tech Help! Thu, 15 August 2002 21:56 Go to previous messageGo to next message
I've never heard of a HKS crank pulley for the 1GGZE. The 1GGZE was not considered a performance engine so there is very little in the way of 'go-fast' bits for them. From memory, I don't think you can swap the smaller 4AGZE blower pulley either as it has the wrong belt offset. Anything you do will most likely have to be custom made.
As for oil, a good syntehtic engine oil like 5-50 is fine. Other oils like ATF or power steering fluid may be thinner (and better) but I'm not sure how they would effect the casing seal (o-ring).
Jonoze
Re: Some 1GGZE Tech Help! Thu, 15 August 2002 23:55 Go to previous messageGo to next message
Grant,
you dont happen to know the crank pulley diameter of the 1GGZE do you??
Cheers.
Grant
Re: Some 1GGZE Tech Help! Fri, 16 August 2002 00:32 Go to previous messageGo to next message
150 I think. I'll check it over the weekend.
gtv6gp
icon3.gif  Re: Some 1GGZE Tech Help! Fri, 16 August 2002 08:51 Go to previous messageGo to next message
what about using castrol 80-90w oil in the 1ggze charger?
Grant
Re: Some 1GGZE Tech Help! Mon, 19 August 2002 21:41 Go to previous messageGo to next message
Crank pulley dia. is 155. As explained before, heavy oils are not suitable for the 1GGZE. They are designed to operate with light lubricating oils.
Jonoze
Re: Some 1GGZE Tech Help! Mon, 19 August 2002 22:46 Go to previous messageGo to next message
Thanks Grant!
gtv6gp
Re: Some 1GGZE Tech Help! Sun, 25 August 2002 07:01 Go to previous message
what oil is light and sutible?
gearbox oil?
engine oil?
what wieght>?
also if anyone has experiance with a 1ggze please contact me
im doing a coustom job and need some tech into please..
im stuck with a problem maybe some 1 can help.
working out boost presure on my engine\charger
and a belt problem, crank pully is Vbelt charger is ribbed
thanks .
Previous Topic:what goes around comes around/gearbox
Next Topic:RA65 Ute?
Current Time: Mon Oct 19 18:03:25 UTC 2026
Total time taken to generate the page: 0.0058021545410156 seconds
