Toymods » Tech & Conversions » 1g in ra23
Orange23
newcastle
1g in ra23 Sat, 13 March 2004 06:24 Go to next message
when putting a 1g-gte in an ra23 and using a 1 piece ta22 tail shaft do u need to shorten it at all the tail shaft that is
ymyars
Re: 1g in ra23 Sat, 13 March 2004 09:43 Go to previous messageGo to next message
why would you want to use 1 piece tail shaft
you can use the standard ra23 2 pieces
CrAiGzEE
south of the big smoke
Re: 1g in ra23 Sat, 13 March 2004 10:01 Go to previous messageGo to next message
depending on where u put the motor it will directly bolt in!
Fattony
Re: 1g in ra23 Sun, 14 March 2004 02:51 Go to previous messageGo to next message
I would say in a 22 if it came out with a one peice tailshaft you would not have the holes in the floor to bolt in a 2 peice 23 series tailshaft.
ra23celica
Re: 1g in ra23 Mon, 15 March 2004 07:54 Go to previous messageGo to next message
I would hazard a guess that you may in fact have to lengthen a TA22 drive shaft if you are fitting a 1G to a RA23. I also reckon that the splines on a '22 driveshaft are different to that from a '23 two piece unit.
And yes, why would you bother when a '23 unit is a direct fit?
It is for my RA23 with 1G-GZE.
Mitch.
CrAiGzEE
Re: 1g in ra23 Mon, 15 March 2004 08:59 Go to previous messageGo to next message
the yoke on the ta22 auto is exactly the same as a two piece tail shaft
as for length the one i have is exactly the same length as my 2 piece
also he may want a single piece if he is planning 300rwhp +
Orange23
newcastle
Re: 1g in ra23 Mon, 15 March 2004 10:12 Go to previous messageGo to next message
yeah lots a power through a 2 piece will make it into a real 2 piece or should i say 2 pieces
Re: 1g in ra23 Mon, 15 March 2004 22:50 Go to previous message
What makes you think a 2-piece tailshaft can't handle decent amounts of power? I have a 2-piece in my Supra and I suspect it has more power than your average 1G. Razz
Previous Topic:13 sec sprinter.
Next Topic:Carb gasket question
Current Time: Fri Oct 23 12:02:01 UTC 2026
Total time taken to generate the page: 0.0051331520080566 seconds
