Toymods » Tech & Conversions » 84 Cressida - Not staying in Overdrive.. ???
Mazda626
Perth WA
84 Cressida - Not staying in Overdrive.. ??? Sat, 13 March 2004 14:24 Go to next message
Ok, i been driving my grandparents cressida lately (626 got problems Laughing )
Anyway only today its not staying in overdrive... Confused
Going along the road at 90km/h overdrive is kicked in rpm around the 2.5k mark then it just jumps out and the engine is around 3krpm... not a real problem as such but hampers fuel economy on long trips Sad If i press the over drive button out and back in it kicks in but not right away like it used too...
Is there a relay for the overdrive that may be stuffed ?
Because its got me puzzled Sad
Car in question is a 1984 Cressida 5ME Auto Smile
Re: 84 Cressida - Not staying in Overdrive.. ??? Sat, 13 March 2004 15:26 Go to previous messageGo to next message
checked fluid level? causes all sorts of worries.. usually with car warm, engine running, and in park or neutral.
Mazda626
Perth WA
Re: 84 Cressida - Not staying in Overdrive.. ??? Sat, 13 March 2004 16:15 Go to previous messageGo to next message
car changes gears fine though... kicks down perfect... can shift the car manually fine but will jump out of overdrive and back to 3rd.. Sad
ZZT231
melbourne.vic.au
Re: 84 Cressida - Not staying in Overdrive.. ??? Mon, 15 March 2004 00:35 Go to previous messageGo to next message
Check the fluid levels and if there is anymore trouble have a look at the Overdrive solenoid to see if it is functioning properly.
Another problem is the fluid in the box might be getting too hot Rolling Eyes
Get a gearbox specialist to have a look at it.
M.J.H
Re: 84 Cressida - Not staying in Overdrive.. ??? Mon, 15 March 2004 05:57 Go to previous messageGo to next message
Had the same problem with the Crown once.Topped up the oil and no more problem.
cressTT
Re: 84 Cressida - Not staying in Overdrive.. ??? Mon, 15 March 2004 06:33 Go to previous message
my 1G-GTE auto used to jump from 5th to 4th (yes 5 gear auto trans, 2 gears after the 3rd) gear intermitently..turned out that the brake swith at the foot padle needed adjustment...my brake light was flasing intermitently causing the trans to downshift to 4th gear. I adjusted the switch and the problem is now gone.
Previous Topic:TA22 Windscreen
Next Topic:sprinter to trueno headlight conversion
Current Time: Wed Nov 18 16:12:28 UTC 2026
Total time taken to generate the page: 0.006458044052124 seconds
