Toymods » Tech & Conversions » how to work out speed vs revs?????
Mr DOHC
how to work out speed vs revs????? Sat, 13 March 2004 23:20 Go to next message
basically i wanna work out what speed i can get out of my car in each gear
i have the diff ratio/gear ratios, all i need it tyre circumference,
whats the formula
[Updated on: Sat, 13 March 2004 23:30]
7M-Brisbane
Re: how to work out speed vs revs????? Sun, 14 March 2004 00:16 Go to previous messageGo to next message
I can't help you with the formula, however another way is to do 2000rpm in each gear and get your passenger to write down what speed you are doing.
For ease of maths divide it by 2, and you have the number of km/h per 1000rpm in each gear.
Then if your redline is (say) 6500rpm, multiply that figure by 6.5 and you'll have the maximum speed available.
Seadog
Re: how to work out speed vs revs????? Sun, 14 March 2004 01:05 Go to previous messageGo to next message
I just wrote up a spreadsheet to do this. If you want it I can email it to you. It's pretty simple, but it gives you max speed in each gear and revs at speed. You put in the variables like max revs, tire width, profile, wheel radius, diff and gear ratios etc. It's pretty simple to do yourself. Otherwise
it goes like this:
Tyre circumference = pi x total diameter
Total diameter = sidewall x 2 + wheel diameter
Sidewall = tyre width x aspect/100
eg. for 195/50 R15, sidewall = 195(mm) x 50/100 = 97.5(mm)
Make sure units are the same! IE convert wheel diameter (usually in inches) to mm. IE x 25.4
Once you have the circumference you can then convert this to metres. Then you know distance/revolution (wheel) then you just multiply in the diff and gear ratio you want and then you should get a relationship between engine revs and distance travelled. Then you can work out what you want.
Fattony
Re: how to work out speed vs revs????? Sun, 14 March 2004 02:40 Go to previous messageGo to next message
Bah who needs a formula when you can take it for a drive.
Purple_Beasty
New Zealand
Re: how to work out speed vs revs????? Sun, 14 March 2004 23:59 Go to previous message
http://www.angelfire.com/ri2/RINGMASTERSREALM/SPEE D/gearingandtiresizingshort.xls
Has a tyre size calculator as well. There is also a section for calculating torque at the wheels from a dyno graph that someone added for me.
Callum
Previous Topic:RA60 Stubborn Crank Pulley Bolt
Next Topic:Exchanging front springs?
Current Time: Wed Nov 18 11:08:44 UTC 2026
Total time taken to generate the page: 0.0045070648193359 seconds
