Toymods » Tech & Conversions » 1UZ Starter Motor
1UZ Starter Motor Mon, 15 March 2004 03:34 Go to next message
Does anyone know the symptoms of a stuffed 1uzfe starter motor?
Is it the solanoid that goes? brushes? rust?
Every now and then, I just get a click, nothing else.
Is this the typical 1uz starter failure?
If I put the car in 5th, roll it a few inches, she will engage.
Battery power is not the problem, nor is the cabling itself.
Ideas? Thoughts? Views?
SupraPete
Re: 1UZ Starter Motor Mon, 15 March 2004 03:40 Go to previous messageGo to next message
I had this problem.
Your wire is TOO THIN. Or your connection is not good enough.
This can be either the LARGE wire to your battery, or the trigger wire. (I had to re-wire both ... a few times)
Re: 1UZ Starter Motor Mon, 15 March 2004 03:45 Go to previous messageGo to next message
Well, the main wire is 4 guage, and I'm pretty sure the joints are perfect, but the trigger wire is original MX73, so that could be too small.
I'll look into upgrading that
SupraPete
Re: 1UZ Starter Motor Mon, 15 March 2004 03:51 Go to previous messageGo to next message
Sorry for being so late with my solution Very Happy Gotta love toymods, you can get an answer to a problem in 6 minutes Smile
I had to upgrade the trigger wire from the plug with two brown wires 1 black wire, then put in a NEW relay with a nice thick (don't know what guage) direct to the battery.
So, in other words I had to add another relay so the wire from the dash triggered the relay with a much heavyer wire to the trigger on the starter.
Edit: typo
[Updated on: Mon, 15 March 2004 03:52]
Re: 1UZ Starter Motor Mon, 15 March 2004 03:54 Go to previous messageGo to next message
HKSPete wrote on Mon, 15 March 2004 11:51
Yeah, thats a fairly typical arrangement to bypass dodgy wiring, but definately something to look into
So what is the typical starter failure? or is it just dodgy wiring on the owners behalf?
Re: 1UZ Starter Motor Mon, 15 March 2004 04:09 Go to previous message
i had to do that for my 18R as sometimes i was only getting 6-9V from the start switch inside the cabin.
it is a risk for theft (makes jump start v.easy) ... but is cheaper than a whole new starter motor/solenoid.
damage is usually to the solenoid windings getting a bit hot when being held open with only 6-9V instead of 12V. Also, pitting on contact surfaces of the solenoid also contributes to poor performance.
Previous Topic:sprinter to trueno headlight conversion
Next Topic:RA60 Stubborn Crank Pulley Bolt
Current Time: Wed Nov 18 13:46:34 UTC 2026
Total time taken to generate the page: 0.0049571990966797 seconds
