Toymods » Tech & Conversions » Clutch pedal not returning all the way
BlackSupra
icon4.gif  Clutch pedal not returning all the way Mon, 15 March 2004 09:42 Go to next message
My clutch is starting to slip a wee bit. Its a 'heavy duty' off the shelf item so the specs of it im unaware of. The slip only occurs at high revs if i am really moving, probably more of a tardy coordination thing haha.
After engaging the clutch and im driving in gear, the clutch pedal only comes back up to about half way.
What would be causing this, a worn clutch or a hydraulic issue?
The clutch master was reco'd a few months ago, but not the slave.
Ideas? Rolling Eyes
Ta guys.
CrAiGzEE
south of the big smoke
Re: Clutch pedal not returning all the way Mon, 15 March 2004 10:46 Go to previous messageGo to next message
are you using fluid? if so check for leeks
also you may have air in ya line
peewee
adelaide
Re: Clutch pedal not returning all the way Mon, 15 March 2004 12:50 Go to previous messageGo to next message
i had my brake master recoed..... then lost all pressure on the way home. they hadn't done the line to the slave up properly and as soon as i put some decent pressure on it went out. never went back there again.....
but anyway, my first thing would be to bleed it to make sure it's not air
Re: Clutch pedal not returning all the way Mon, 15 March 2004 13:01 Go to previous message
Check the spring return on the pedal if the above things pass the test
Ya never know
Previous Topic:location of thermotime sensor, on 4age
Next Topic:my brake lights arent working... FIXED NOW
Current Time: Sat Oct 24 05:41:02 UTC 2026
Total time taken to generate the page: 0.0050148963928223 seconds
