Toymods » Tech & Conversions » 18rgeu wire colours
people100
Rocklea qld
18rgeu wire colours Mon, 15 March 2004 09:44 Go to next message
Im trying to wire my efi but have a few problems. When it say blue/white for example does that mean blue wqith white stripe or can it also mean white with blue strip. Just i have a wire from the afm that is blue with a yellow strip but theres no listing so i dont know where it goes. i thought maybe i had different wiring but the computer and someother thing possibly fuel relay both have 18rg on them. How do i figure out these problems. Anyone in brisbane that can give me a hand would be great. Thanks.
sideshow
Re: 18rgeu wire colours Mon, 15 March 2004 11:30 Go to previous messageGo to next message
if u have probs tryin to understand blue with white strip then best left to a pro
colours of wires can sometimes be wrong
if u make sure the diagrtam is correct
try tracing some of the wires and see if they go to the correct spot as on the wiring diagram
this will tell u if its correct
Re: 18rgeu wire colours Mon, 15 March 2004 11:52 Go to previous messageGo to next message
Check everything with a multimeter. Trust nothing. Doing my 1UZ one at the moment and I'm suprised that there are wires the same color coming out of the ECT box that do totally different things just to confuse you!! Shocked
The wiring diagrams are generally pretty straight forward. Something like "BY" means blue wire with yellow stripe. I suggest you get someone to give you a hand or just take it very slowly. Last thing you want to do is fry the ECU.
wil8115
Seattle area, USA
Re: 18rgeu wire colours Tue, 16 March 2004 11:43 Go to previous messageGo to next message
also on the older ECUs take the cover off and look at the pin outs. It says what each one is. and check your other post Smile
TurboRG
Nor Calif USA
Re: 18rgeu wire colours Tue, 16 March 2004 19:36 Go to previous messageGo to next message
gianttomato wrote on Mon, 15 March 2004 22:52
Not every ECU has the wiring diagrams on the cover.
I have a Stock 18RGE ECU and it doesn't have it in it.
the cover was never off until I removed it.
wil8115
Seattle area, USA
Re: 18rgeu wire colours Tue, 16 March 2004 20:31 Go to previous message
Try taking off the other side. I seen an 18rgeu ecu and a 2tgeu and they had the markings on the pcb board. Confused
Previous Topic:78-79 Supra Rear end in an RA21
Next Topic:Engine Stopped In A Datsun 180B
Current Time: Tue Oct 20 22:54:07 UTC 2026
Total time taken to generate the page: 0.0046629905700684 seconds
