Toymods » Tech & Conversions » @@ Turbo- oil restricter?
haydennz
@@ Turbo- oil restricter? Mon, 15 March 2004 11:58 Go to next message
Do I need to use a oil restrictor on my rb20det turbo when I put it on my 3tgteu? if so what size?
I also dont know if its ball bearing or not.
Re: @@ Turbo- oil restricter? Mon, 15 March 2004 22:44 Go to previous messageGo to next message
At a guess - no you dont need any restrictor.
Re: @@ Turbo- oil restricter? Tue, 16 March 2004 13:59 Go to previous messageGo to next message
ick... you DO!! Use the factory nissan part, from memory the hole is less than 1mm in size Evil or Very Mad
Re: @@ Turbo- oil restricter? Tue, 16 March 2004 14:08 Go to previous messageGo to next message
so don't they have a restrictor in the connector on the turbo? it's in the line?
haydennz
Re: @@ Turbo- oil restricter? Tue, 16 March 2004 19:52 Go to previous messageGo to next message
it came off a 1990 r32 gtst, im still not 100% sure its ball bearing, even if it was normal bearing would it still need the restricter, and will it actaully DAMAGE it without it? or just smoke?>
Re: @@ Turbo- oil restricter? Wed, 17 March 2004 21:55 Go to previous messageGo to next message
If it's the ball bearing one, you do need the restrictor, which is just a small hole in the banjo bolt itself, not in the pipe anywhere. If it's a Cefiro turbo, not Skyline, then my understand is that you won't need the restrictor, but please ask a Nissan nut to make sure!
haydennz
Re: @@ Turbo- oil restricter? Thu, 18 March 2004 09:39 Go to previous messageGo to next message
how do i tell tho, i was told it came off a 1990 Nissan Skyline GTST, iwas not supplied any oil lines/fittings.
Manny
Re: @@ Turbo- oil restricter? Thu, 18 March 2004 11:37 Go to previous messageGo to next message
-hit the skylines forums, post pics and ask
-see a reputable wrecker who can ID it
-see a reputable turbo specialist
A ball bearing turbo without a restrictor will result in oil loss, lots of smoke out the exhaust and lot's of oil in your intake pipework, intercooler, throtrtle body, plenum etc
I run a 0.8mm restrictor in my garret GT cores.
haydennz
Re: @@ Turbo- oil restricter? Thu, 18 March 2004 12:13 Go to previous messageGo to next message
-have searched everywhere
-no respectible turbo specialist anywhere near my area unfortunatly.
If I put it on the engine with no oil restrictor at all will it kill the turbo? cause I spose this is how I could test, because if I put a restrictor on a turbo that had a standard core it would die pretty quickly yeah?
3tgteu's oil pressure gets upto 120psi on cold start eeek,
[Updated on: Thu, 18 March 2004 12:13]
Manny
Re: @@ Turbo- oil restricter? Thu, 18 March 2004 12:25 Go to previous messageGo to next message
Doubt it would kill it if it's a ball bearing core, but will affect spool up with the extra unecessary resistance.
Re: @@ Turbo- oil restricter? Thu, 18 March 2004 21:36 Go to previous messageGo to next message
I DO know from experience that running without the restrictor will make for a pretty smokey ride if nothing else... I've got one of these turbos lying round, I'll try and include measuring the restrictor in my day's activities Evil or Very Mad
haydennz
Re: @@ Turbo- oil restricter? Fri, 19 March 2004 00:26 Go to previous message
but did it still work properly afterwoods? maybe ill go for a 3mm restrictor or something and if it doesnt smoke then it must be standard bearing.
Previous Topic:AE93 Seca SX info please?
Next Topic:Indicators are on the fritz :(
Current Time: Sat Oct 24 12:38:50 UTC 2026
Total time taken to generate the page: 0.0053739547729492 seconds
