Toymods » Tech & Conversions » bloody miss
coronamark2
bloody miss Tue, 16 March 2004 07:39 Go to next message
ok i have just got a fully rebuilt 350 holley put on my 4m it had a 350 holley b4 but ran hella rich so i took it to a carbie place and the guy said i have the wroung type of 350 holley on there so he said i'll put the right one on there for $300 and install it for $100
so i went and picked it up and it ran worse than before Razz
(this was with half an exaust so it was loud as fk and didnt want to idle so i got the exaust fixed and brought it back.
the guy said its not getting enough fuel so he put an electric fuel pump on (carter fuel pump - pumps 6psi) it ran better but still had a miss but it wasnt constant it would do it every now and then.
he replaced the plugs, points, condesor, rotorarm and set the timing, he also tried colder spark plugs as it was running rich and said he had put size 58 jets in there from 61 ( Confused jet sizes mean nothing to my feble knowledge)
and still had an intemitent miss
so he said i reckon its the distributer so he suggested electronic ignition
but my wallets getting pretty slim at the moment so i thought id get a second opinion so i rang a performance tuning place they suggested this other carbie place
i told the guy what the go was and strait out he said its the carbie he said its to big he said " the carbie you wouldve had on there before wouldve been single throat the 350 is dual"
he recommends a webber i said i'll bring it in and get him to have a look
what do you guys reckon/suggest?
charliechalk
Re: bloody miss Tue, 16 March 2004 07:42 Go to previous messageGo to next message
Fuel injection Very Happy
*shrugs* good luck with it anyway.
coronamark2
Re: bloody miss Tue, 16 March 2004 07:46 Go to previous messageGo to next message
charliechalk wrote on Tue, 16 March 2004 15:42
Razz thanks
Re: bloody miss Tue, 16 March 2004 08:14 Go to previous messageGo to next message
Yep. Bolt on the 5ME fuel injection manifold and ECU.
coronamark2
Re: bloody miss Tue, 16 March 2004 08:58 Go to previous messageGo to next message
GT do you reckon the webber would solve the problems?
Re: bloody miss Tue, 16 March 2004 09:14 Go to previous messageGo to next message
No.
I reckon fuel injection might. But then again I'm not sure what your misfire is due to.
Don't waste your time with carbs seriously. For the price of a Weber, you will be able to get a whole fuel injection system from a 5ME.
Wilbo will be wrecking an MX62 soon...chat to him. Or go to some local wreckers. I have wiring diagrams/ECU pinouts if that's an issue.
Would have been nice to have setup an in-tank fuel pump in your drop tank.
[Updated on: Tue, 16 March 2004 09:17]
torque
UK at moment
Re: bloody miss Tue, 16 March 2004 10:13 Go to previous messageGo to next message
fuel filter?
Condition of carb?
A weber will only solve the problem if the problem is the current carb.
What cc's is a 5ME? - a 350 is getting towards large for most toyota's isn't it?
I hate mystery misfires!
clubagreenie
1st street on the right
Re: bloody miss Tue, 16 March 2004 10:48 Go to previous messageGo to next message
I have a efi from a MS112, harness etc. Yours for the price of freight from Sydney if you want it. PM me if you are interested.
Re: bloody miss Tue, 16 March 2004 12:50 Go to previous messageGo to next message
sell the holley to buy EFI hardware...
a single H 350 is big enuf to power a 265 hemi valiant, it's too big for a 5M.
even dropping the jet size won't help you much - they're designed for big-breathing engines (like big fords and valiants 6 cyls).
if you don't like the idea of going EFI then get a factory carbi, rebuild it with a carbi kit and get a HEI kit from dick smith or Jaycar (approx $50) to improve the spark. the holley's only good for stoping the shed door slam shut on you.
also, intermitent miss with throttle steady would be spark, not fuel...
coronamark2
Re: bloody miss Wed, 17 March 2004 01:23 Go to previous messageGo to next message
wont i lose power if i go efi?
to setup the efi properly woundlt i have to get it tuned up + dont you have to have electronic ignition with efi Confused
so i would need the efi manifold,ecu,loom,electonic igintion dont you need to put sensors in the exaust and intake?
that sounds pricey
i've spent like $250 on the air filter for the carb (k&n element with k&n extreme top) so then id have to get all the efi set up then another air filter.
I love the sound of the carbie suction and want to stick to carbie until i do a conversion
one last thing whats a HEI?
Re: bloody miss Wed, 17 March 2004 01:36 Go to previous messageGo to next message
HEI = high energy ignition.
Isn't your motor completely standard apart from some headers/exhaust and the wretched Holley?
The EFI system really will be able to cope with the minimal improvement in airflow afforded by the exhaust.
You buy a full EFI system off a 5ME. If you look around, loom ECU, dizzy and intake manifold will set you back $150. MX62 Cressidas are currently the wreckers pet hate. Get your drop tank modified to take an MA70 in tank EFI pump.
Sell that POS Holley and Carter low pressure fuel pump to fund your upgrade. This way you will have setup your fuel system for when you do decide to do a conversion and you will have a perfectly reliable EFI setup that you never have to tinker with again. You'll also learn all about EFI with the most basic EFI system, and come to realise how much even this basic EFI system shits on carbs.
As an aside, I'm not sure why you got a Carter fuel pump. My standard mechanical 4M fuel pump pumps enough fuel at 7 psi to fill 3 fuel bowls at full throttle. In fact, I had to adjust the fuel pressure down so I didn't overwhelm the needle and seats in the SUs.
coronamark2
Re: bloody miss Wed, 17 March 2004 01:57 Go to previous messageGo to next message
the head / extractors have been ported and its got differnt pistons in there so it has a higher compresion.
the guy at this carbie place said it needs the fuel pump Razz
i doubt it now though
thats why i wanted the second opinion i think he's just interested in the $$
i spoke to another guy who said it sounds like the power valve (whatever that is)
he said he'll recon a webber and make an adapter plate fit it and tune it for $350
All the toyota wreckers are bloody rip offs over hear as u know i got quoted $300 for the electronic igniton of a 5m so you can imagine what they would quote for the rest
i'll do the ring around and get some prices but the place i rang is the biggest toyota wreker in WA
i dont want to bring the tank back to the dodgy fck who made it so that would be more $$ to get it put in there + finding the efi pump from an ma70
i hate my car Razz
[Updated on: Wed, 17 March 2004 01:58]
Re: bloody miss Wed, 17 March 2004 02:06 Go to previous messageGo to next message
Just take your time, sounds like there is no great rush.
Justin (clubagreenie) has some bits that you can have for free (+postage) and I have a range of bits you can have for free (+ postage).
Is there a Pick a Part style wrecker in Perth? Often they are quite well priced.
coronamark2
Re: bloody miss Wed, 17 March 2004 02:30 Go to previous messageGo to next message
cheers dude
there are a few pick a part wreckers but they are usually raped and a rip of they wanted $50 each for a seat belt from a vl
this is kenwick for the perth people
I'll save up a few pennies do the ring around at the wreckers. and pm you guys and see what you guys have i will pay for the stuff
the thing is i cant have my car off the road for more than a day as i need to get to work as i have 2 jobs (one at night)
thanks for the input guys
Re: bloody miss Wed, 17 March 2004 02:55 Go to previous message
Setting it all up is a weekend job at a fairly luxurious rate. You could use a VL Commo fuel pump at a push if you didn't want to do the in tank bizzo.
Previous Topic:interchangeable turbos?
Next Topic:Increasing track width
Current Time: Sat Oct 17 10:02:07 UTC 2026
Total time taken to generate the page: 0.006350040435791 seconds
