Toymods » Tech & Conversions » 3sge (st162) engine problems
j_o_e_l_05
Gympie, Queensland
icon5.gif  3sge (st162) engine problems Wed, 17 March 2004 00:55 Go to next message
hey everyone, i've got a celica with a 3sge and i was driving it and it just suddenly lost oil pressure, then nearly stalled, so i got it home (about 20m down the road from when it happened) and now when i try to start it, i just hear a "click". i thought the timing belt could of come off and got jammed, but its fine.
any idea's as to what's wrong with it?
coz im stumped... thanks for your help guys, much appreciated
RWDboy
Re: 3sge (st162) engine problems Wed, 17 March 2004 01:10 Go to previous messageGo to next message
If you lost oil pressure, it could be that you've seized the engine...then you may be fucked.
There are other numerous possibilities though...your oil pressure guage may be crapped...I've heard of oil pressure lights carking it it just as an engine's oil pump breaks, leaving the driver unaware of the hell that is about to break loose Smile
Try starting the car out of gear (in neutral) it could just be that your clutch release bearing (?) is fuxored if you are the kind of guy who starts the car in gear with the clutch in. Driving without a decent clutch is a bastard as well.
Try seeing if you can move the engine by the crank - take the car out of gear, get a 17 or 19mm socket wrench or ring spanner (I think it's 19mm, can't remember exactly) and try to rotate the engine, if you can't at all no matter how hard you try, then it's likely that your engine is seized.
Just some suggestions...if you are positive your oil pressure dropped to like 'zero' before the car stalled, then it's likely that you have seized the bastard, and it's time to get a half-cut Smile
Oh and it could be your electrics as well, check the battery voltage reading thingo...
[Updated on: Wed, 17 March 2004 01:13]
j_o_e_l_05
Gympie, Queensland
Re: 3sge (st162) engine problems Wed, 17 March 2004 02:17 Go to previous message
thanks FWD, ill give that a go.
yeah it wont start in nuetral either, ill try the spanner on crank trick. but yeah i think its time for a new engine too.......
Previous Topic:Increasing track width
Next Topic:ra40 engine mounts
Current Time: Sat Oct 17 13:31:05 UTC 2026
Total time taken to generate the page: 0.0051891803741455 seconds
