Toymods » Tech & Conversions » Old or faulty Oxygen Sensor - does it affect idle speed
3sge
Old or faulty Oxygen Sensor - does it affect idle speed Wed, 17 March 2004 05:04 Go to next message
The idle speed on my ST162 varies a lot -- 99% of the time, it is 100 to 150 rpms below the 750rpm that is steady when the T & E1 connectors are shorted. It is about 200 rpm lower when stopping and starting on a hot engine. The timing is spot on at 10 deg BTDC (with T & E1 shorted). I'm pretty sure it's not a vacuum leak or dirty injectors. Could a faulty or old oxygen sensor cause the erratic idle? The check engine light does not come on, so I presume that it is still sending an acceptable signal to the computer. I don't wanna spend dough on a new oxygen sensor if there is little or no chance that it affects the idle speed.
Re: Old or faulty Oxygen Sensor - does it affect idle speed Fri, 19 March 2004 00:59 Go to previous messageGo to next message
no, i don't believe the O2 sesnor is active for idle mixtures (but i could be wrong Wink ) check what voltage the sensor is giving, should flick back and forth from 0-1V when the engine is in closed loop mode.
Ben Wilson
Re: Old or faulty Oxygen Sensor - does it affect idle speed Fri, 19 March 2004 07:25 Go to previous messageGo to next message
I had bouncing idle problems with my ZE which turned out to be an old oxygen sensor..
Re: Old or faulty Oxygen Sensor - does it affect idle speed Fri, 19 March 2004 09:21 Go to previous messageGo to next message
i stand corrected Very Happy
so ben, you are saying that the ECU is in closed loop mode at idle?
anyone have a reference (ie a manual or similar) to confirm?
bmak
Re: Old or faulty Oxygen Sensor - does it affect idle speed Fri, 19 March 2004 11:33 Go to previous messageGo to next message
I believe the computer uses closed loop mode for idle & cruising.
My 4age popped a bit at idle when the oxy sensor was broken
sideshow
Re: Old or faulty Oxygen Sensor - does it affect idle speed Fri, 19 March 2004 12:36 Go to previous messageGo to next message
yer o2 sensor only works at idle or cruise
thats y these guys how buy cheap ass air /fuel ratio meters dont get correct readings above cruise
i do know on 20vs that it makes em bit better of the mark if o2 meter is connected
had probs with one one day when i fixed it customer said car went bit better off the mark
HighRolla
Re: Old or faulty Oxygen Sensor - does it affect idle speed Fri, 19 March 2004 14:48 Go to previous messageGo to next message
Only open loop on full throttle from all that I've read ... Razz
Juggalo
Sydney (Liverpool)
Re: Old or faulty Oxygen Sensor - does it affect idle speed Sat, 20 March 2004 08:10 Go to previous messageGo to next message
My O2 sensor isn't connected at all and my GZE seems to be running fine with no idle problems.
MaNGeW
Formerly TRD_RoLLa
Re: Old or faulty Oxygen Sensor - does it affect idle speed Sat, 20 March 2004 08:15 Go to previous messageGo to next message
I had same experience as Juggalo. No real noticeable affects on my fuel economy either.
takai
Re: Old or faulty Oxygen Sensor - does it affect idle speed Sat, 20 March 2004 11:54 Go to previous messageGo to next message
I get bouncing idle at the moment, but train of thought is that the O2 sensor is dead. I will unplug to test in the next few days.
HighRolla
Re: Old or faulty Oxygen Sensor - does it affect idle speed Sat, 20 March 2004 12:27 Go to previous messageGo to next message
As said by others previously, short the diagnostic terminal if you have one to see if any fault codes come up. Only some of them trigger the check engine to stay on when the car is running. I think in 4age oxy sensor was a code 21 but check for you car.
Toobs
Re: Old or faulty Oxygen Sensor - does it affect idle speed Sun, 21 March 2004 03:03 Go to previous message
your AFM could be getting a bit stuffed... that will cause low idle to the point of annoying vibration.
Previous Topic:Grp A bumper - is this bit I broke important?
Next Topic:Camshaft options...st162
Current Time: Mon Nov 2 06:05:38 UTC 2026
Total time taken to generate the page: 0.11769104003906 seconds
