Classifieds » Miscellaneous » TOUGH DIFF FOR AE86 FOR SALE!!!
ALI16L
TOUGH DIFF FOR AE86 FOR SALE!!! Thu, 15 August 2002 09:07 Go to next message
Ok ladies and gentlemen, are you sick of that pissy, open wheeler, drum wearing, pathetic excuse or a final drive unit under your fully sick Ae86 drift Machine???
Disgusted at the $1800+ price tags on jap disc 2 disc lsd's that were made to take no more than 86kws???
seriously... Im selling a borg warner 28 spline lsd diff from a hsv maloo ute(53000ks).Professionally shortened, and modified, ready to bolt straight into your sprinter. Stud pattern has been changed to 4 stud so you can keep your SICK mags and a new 4;11 gear set has been fitted. Borg warner stuff is everywhere in oz so you'll have no hassles finding parts, different ratios etc. With it you'll get another commodore diff with good(apparently reco'd)calipers etc. Remember these diffs were made to take at least 185kw, and a shitload more torque than your little gte/gze will dish out.
ps. i havent used it since i had it made...
...tell em the price son!!!
ONLY $1500!!!
call me 0414800395 if you're interested.
thanx.
GSR18U
Re: TOUGH DIFF FOR AE86 FOR SALE!!! Thu, 15 August 2002 10:34 Go to previous messageGo to next message
hey ive seen your car
its around belmore ay
what diff you got on your car now?
MRTA22
Re: TOUGH DIFF FOR AE86 FOR SALE!!! Fri, 16 August 2002 08:27 Go to previous messageGo to next message
Mate im pretty sure this will fit in my TA22?? Its either slightly wider or narrower than a TA22 diff? ( i need a bit wider !!)
How much do you want for just the one that has been modified?? Or are the both of them needed to make a complete one(brakes etc??)
If you are negotiable on the price a bit give me a call on 0408482399. Im also in Sydney so picking it up wouldn't be a problem.
Jamie.
TE72_Turbo
Re: TOUGH DIFF FOR AE86 FOR SALE!!! Fri, 16 August 2002 10:20 Go to previous messageGo to next message
jamie, did you get the bluebird diff? have you had a chance to measure it up from flange to flange?
PHil
MRTA22
Re: TOUGH DIFF FOR AE86 FOR SALE!!! Fri, 16 August 2002 16:42 Go to previous messageGo to next message
Hi Phil, yeah i have it here. Its 1450mm from side to side measured on the discs where the back of the wheel sits. The housing itself is 1300mm. It will need to be shortened 40mm to fit in my car. I have alot of room due to offset so i can go 10-15mm wider per side than standard. I will get it shortened and the mounts changed soon. The tailshaft and handbrake cables i have sorted out that was the easy part.
Jamie.
TE72_Turbo
Re: TOUGH DIFF FOR AE86 FOR SALE!!! Sat, 17 August 2002 09:55 Go to previous messageGo to next message
cool! that means its only 15mm wider each side than the T18 diff!
no shortening for me!
Phil
MRTA22
Re: TOUGH DIFF FOR AE86 FOR SALE!!! Sun, 25 August 2002 09:57 Go to previous messageGo to next message
Hi Phil, i want to buy this diff off Ali but have to sell my TRX one to help fund it. Are you interested in it?? I will be going near your way next week so if you are i could deliver it.
They go for around $1000 complete in wreckers so offers around $700. One hub seal is leaking slightly and the discs are a little worn (just need a machine!) otherwise it is perfect. Its 3.9:1 ratio. I have handbrake cables and lever aswell.
Jamie.
TE72_Turbo
Re: TOUGH DIFF FOR AE86 FOR SALE!!! Mon, 26 August 2002 11:00 Go to previous messageGo to next message
wish i could dude, but i'm gonna be short of cash for quite some time now that i'm doing this engine conversion.
good luck selling it anyways, it will be awesome to have Ali's diff under the '22!
Yeeehah
Re: TOUGH DIFF FOR AE86 FOR SALE!!! Tue, 27 August 2002 01:12 Go to previous messageGo to next message
i am very keen to buy. Although i have a couple of qqqqquestions?
Is it ae86 stud offset/pattern?
Why aren't you using it?
Have you got a pic?
Will it bolt up to my ae86 tailshaft?
Would you sell without the other comodore diff?
Ash
ALI16L
Re: TOUGH DIFF FOR AE86 FOR SALE!!! Tue, 27 August 2002 16:04 Go to previous messageGo to next message
Yes.
I need the cash for uni.
No, you'll need to have a t/shaft made, i have the flange and uni joint and bolts.
You'll need both diffs.
Yeeehah
Re: TOUGH DIFF FOR AE86 FOR SALE!!! Wed, 28 August 2002 05:00 Go to previous message
I think i'll let it go.
Thanx
Ash
Previous Topic:AE86 Parts..end of the line!
Next Topic:I WANT A FLYWHEEL
Current Time: Sat Oct 31 13:16:44 UTC 2026
Total time taken to generate the page: 0.009835958480835 seconds
