Toymods » Tech & Conversions » Brake lights on SW20
Alchemist
Brake lights on SW20 Wed, 17 March 2004 11:24 Go to next message
Hello,
Well....isn't this embarresing, I was trying to change my indicator fluid and I smashed my brake light Confused
Seriously though, when I bought the car one of the rear brake lights were out. Anyway I pulled back the material in the boot(assumed it would be similar to my TA23....not so), it look as if all the globes were on the outside. Anyway looked at the globe array(I dunno what to call it) and there is a small screw that seemed to be holding it all onto the back. Removed this, it loosened the whole light setup, but it still seemed very firm. I was wondering if I just need to be abit rougher and that one screw is all that holds it in, or is there a secret? Want to get this changed as its one less thing to get defected for, and its just safer.
MR. 2
Parramatta
Re: Brake lights on SW20 Wed, 17 March 2004 21:55 Go to previous message
ok there shoul be i think 2 10mm nuts up the top and then there will be 2 20mm down the bottom (not 100% sure about the bottom) now some of the nuts are hiding bit there is a circular hole just put ur fingers in each one and then u will be able to feel it. also u have to take the side indicator part (the part that sticks out and it dosnt light up the one one the very side) and then just pull it out it only clips in. then behind that there is a screw! the last thing is the center peice unscrew the top screw at meets the light and then center peice and thats it pull it out u will have to be firm with it though there ar clips holding it in!
Previous Topic:SV21 Electrical Fault, Help Please
Next Topic:1JZ Soarer/Supra differences
Current Time: Sat Oct 24 09:42:04 UTC 2026
Total time taken to generate the page: 0.0046670436859131 seconds
