Toymods » Tech & Conversions » High flow downdraught carby for my 4AFC
kemicalx
Geelong.Vic.Au
High flow downdraught carby for my 4AFC Thu, 15 August 2002 09:52 Go to next message
Yo all,
I would like to replace the standard carby on my 4AFC with a high flow downdraught carby, or a set of webbers. Please don't suggest any engine conversions like everywhere else i've asked Rolling Eyes I can't afford an engine conversion yet!, and i'm smart enough to know if the cost of a carby out weighs the worthwhileness(lol not a word). Anyway I also want to get a set of extractors.
Could anybody suggest some brands, models, prices and places where i could pick up high flow carbys, webbers and extractors to suit my engine.
Thanks alot Wink
inertia
Re: High flow downdraught carby for my 4AFC Thu, 15 August 2002 23:43 Go to previous messageGo to next message
Dude,
I know how you feel with the 4afc, I have one Smile.
I wanted to modify mine, but in the end it would not be worth it without throwing serious cash at it, and even then...
One thing to consider is, there isn't a lot of room for an air filter to sit ontop of the carb as it is, so you would need to fabricate one off to the side over the transmission, or move the washer bottle over there, and put a filter where the washer bottle is, and direct cold air to that, there is a hole down under the original snorkel, I have not physically seen to where it leads... You may be able to use it for something.
Test the noisyness of the engine by removing the top of the air filter housing, and screwing the nut back down over the filter, to hold it in place, go for a drive and rev it out. Your ears will buzz hhehe. sounds good at lowish revs.
I'll make some sounds soon and put them up for y'all to laugh at, err listen to. You'll possibly be able to tell me how many problems my 4afc has!
By the way dude. How does your 4AFC handle in the cold mornings? Like a dog?
[Updated on: Fri, 16 August 2002 03:19]
kemicalx
Geelong.Vic.Au
Re: High flow downdraught carby for my 4AFC Fri, 16 August 2002 08:35 Go to previous messageGo to next message
My 4afc is reliable as, in warm or cold mornings, I'm thinking along the lines of 2 twin 40mm sidedraft dellorto's on a 4age/custom intake, and a set of extactors.
inertia
Re: High flow downdraught carby for my 4AFC Fri, 16 August 2002 15:24 Go to previous messageGo to next message
I believe the 4age intake won't bolt onto the 4AF head mate, So a custom jobby would be needed.
Mine is still reliable, just, but I gave it hell for 2 years when first on my P's and it is starting to show... Auto trans went with a bang and crunch... Got tappet noises, and in the mornings it is a complete dog, accellerates, then bogs down, almost in a state of suspended animation, then continues revving to 3000rpm, where i back off and let the auto change. In 2nd gear it bogs down more... Ahh Well.
Good to see if ya get good results from webers/intake and exhaust mods.
kemicalx
Geelong.Vic.Au
Re: High flow downdraught carby for my 4AFC Sat, 17 August 2002 03:08 Go to previous messageGo to next message
yer, plus mines a 5spd manual Smile
IRA11Y
Club Member
Re: High flow downdraught carby for my 4AFC Sat, 17 August 2002 05:21 Go to previous messageGo to next message
custom intake manifold with 36/36 IDF Weber should do the trick nicely
kemicalx
Geelong.Vic.Au
Re: High flow downdraught carby for my 4AFC Sat, 17 August 2002 05:25 Go to previous messageGo to next message
ok thanks,
2 lots of twin webers would look sweet, i know it would cost double. But would it perform better, same, worse?
c2888
Re: High flow downdraught carby for my 4AFC Sat, 17 August 2002 06:47 Go to previous messageGo to next message
Unless you can get twins secondhand, from someone who doesn't know what they're worth an engine swap will work out comparable in price. Twin side draughts go for around 800-1000, add the manifold 200 minimum, which will have to be custom, as i've never seen anything availible for a 4afc. you're up for a grand already, and you haven't begun to tune the things yet, which will cost an arm and a leg, unless you know someone who deals with them all the time. Does the 4afc have a electric fuel pump? if not thats another hundred.
I don't want to put you off your goal, but get quotes on everything and compare the difference in costs, it may only cost a bit more, and if you have to save a month or two longer then save. Cos two months is just two months waiting for cash, regret will stay with you till you sell the car. Or spend more money doing it how you really wanted in the first place.
IRA11Y
Club Member
Re: High flow downdraught carby for my 4AFC Sat, 17 August 2002 07:12 Go to previous messageGo to next message
I have a 36/36 IDF you can have for $50 and I can tell you where to get them second hand from a wrecker for $75 each any day of the week...thats pretty cheap for twin webers I reackon Smile the most expensive part will be the manifold. A low pressure eletric pump (all you need to run carbies) is $30 from P&PL
[Updated on: Sat, 17 August 2002 07:14]
kemicalx
Geelong.Vic.Au
Re: High flow downdraught carby for my 4AFC Sat, 17 August 2002 07:50 Go to previous messageGo to next message
$1000+ is a bit out there. IRA11Y, What sort of cond. is your weber in? and what is the name of this wreckers (do you know if they will ship?) Thanks for all your help, on the note about the manifold i was told a 4age one will do, but i will have to re drill holes hear and there.
IRA11Y
Club Member
Re: High flow downdraught carby for my 4AFC Sat, 17 August 2002 07:57 Go to previous messageGo to next message
my weber is in excellent condition, cant remeber the wreckers name exactly...its a european wrecker in north parra
GZE-STYLE
Camden
icon5.gif  Re: High flow downdraught carby for my 4AFC Sat, 17 August 2002 08:10 Go to previous messageGo to next message
hey IRA11Y will these webbers fit a 4AC out of a sprinter?
thanks for any info
inertia
Re: High flow downdraught carby for my 4AFC Sat, 17 August 2002 08:11 Go to previous messageGo to next message
hey IRALLY, what are the chances of a weber like yours fitting on the stock intake manifold?
Maybe my suspended animation problem is the carb...
kemicalx
Geelong.Vic.Au
Re: High flow downdraught carby for my 4AFC Sat, 17 August 2002 08:12 Go to previous messageGo to next message
GRRrRrRrRrRrRrR!!!!
stay away from those webers Evil or Very Mad Evil or Very Mad
inertia
Re: High flow downdraught carby for my 4AFC Sat, 17 August 2002 08:16 Go to previous messageGo to next message
I didn't say HIS weber dude, I said one like it lol.
IRA11Y
Club Member
Re: High flow downdraught carby for my 4AFC Sat, 17 August 2002 08:20 Go to previous messageGo to next message
Are you guys reading what is being written???? Nope
you need a custom manifold to do this sort of conversion Nod
yes you can make them fit a 4AC if you modify the manifold Nod
kemicalx
Geelong.Vic.Au
Re: High flow downdraught carby for my 4AFC Sun, 18 August 2002 00:54 Go to previous messageGo to next message
http://www.redlineauto.com.au/manifold.html#REDLIN E%204
Could anyone suggest which manifold there (if there is one) would suit my engine and 2 sets of 36/36 webers. Me thinks there aint any Sad
CrAiGzEE
south of the big smoke
Re: High flow downdraught carby for my 4AFC Mon, 19 August 2002 09:06 Go to previous messageGo to next message
mate i believe none of those will fit ya only chance is custom! (As Irally said)
i 2 have a 4afc, and looked at doing the exact same thing you are talking about, You should know u wont pass emissions with this setup,
also you still have the crappy internals of a 4afc, not 100% sure but u should be able to 4age internals in the 4afc block
but then that is more $$$
I ended up ditching this idea and am saving for my front cut!!
4agze!!!!!!!!!!!
good luck dude
keep us posted on how it goes
[Updated on: Mon, 19 August 2002 09:12]
kemicalx
Geelong.Vic.Au
Re: High flow downdraught carby for my 4AFC Mon, 19 August 2002 09:11 Go to previous messageGo to next message
Well,
I have made my mind, not going to do anything to it atm Sad
I'll save save save for a 4agze - ditch blower and replace with a t25-8 turbo.
In the long run that'll be the best and cheapest option Smile
CrAiGzEE
Re: High flow downdraught carby for my 4AFC Mon, 19 August 2002 09:14 Go to previous messageGo to next message
dude thats gunna cost ya big $$$$
aint that simple as ditching the blower
u then have to fit a 86kw head and lots of other crap
talk to yogi8u about it he will tell ya!
kemicalx
Geelong.Vic.Au
Re: High flow downdraught carby for my 4AFC Mon, 19 August 2002 09:33 Go to previous messageGo to next message
i saw a dato ute somewhere that had done this conversion, and no engine internals need be played with
Re: High flow downdraught carby for my 4AFC Thu, 22 August 2002 04:05 Go to previous messageGo to next message
Irally.. you seem to be the king of webers... do u know how much a twin-side draught set-up for an 18RGU would be worth (inc 2 x 45DCOE 45mm side-webers, manifold etc?)
cos thats what i have and im wondering what its worth in case i wanna ditch it for efi?
IRA11Y
Club Member
Re: High flow downdraught carby for my 4AFC Thu, 22 August 2002 05:42 Go to previous message
why dont you just get the 18R solex mikuni set, I know where you may be able to get the factory manifold and theres plenty of mikuni sets available at the moment it seems and they usually go pretty cheap..around $250 a set, toyota still rate this as the best carb!
Oz Craig...how do you figure you wont pass emissions??? firstly you would be modifying carb to carb...as long as the the hose from the charcoal cannister is connected to the carbs and you have a legal air filter setup there is no reason why you would not pass emmisions, if youre worried about the exhaust emmissions (which are still not done here) then you just detune the carb for the test.
[Updated on: Thu, 22 August 2002 05:46]
Previous Topic:RA60 engine oil
Next Topic:Will TA22 diff fit in Corona?
Current Time: Sat Oct 17 21:30:01 UTC 2026
Total time taken to generate the page: 0.041868925094604 seconds
