Toymods » Tech & Conversions » 4age o2 sensor
SLY16V
camden
4age o2 sensor Thu, 18 March 2004 01:14 Go to next message
how guys i have a set of stuart wilkins rally 4-2-1 extractors for a 4age but i was just wondering where abouts to weld on the plate for the o2 sensor???
pics would be good... cheers
FKN16V
NSW, East Coast
Re: 4age o2 sensor Thu, 18 March 2004 01:29 Go to previous messageGo to next message
I would suggest where the standard one goes, as the 4 become 2, or just before it.
Re: 4age o2 sensor Fri, 19 March 2004 00:56 Go to previous messageGo to next message
if you plan on using an unheated sensor, it should be within about 1-1.5 feet from the head.
if you use a heated sensor, it can be placed much further away, so you can fit in in the last collector, and sample of all 4 cylinders.. if you are confident that your injectors are ok, sampling off two cylinders should be ok, but may not get an unheated sensor hot enough.
i still have a couple of Bosch and NTK heated sensors (no flange, they have the standard M18x1.5 thread) for $60+post (or i could drop it off in camden sometime)
GZE-STYLE
Camden
Re: 4age o2 sensor Fri, 19 March 2004 02:05 Go to previous messageGo to next message
Hey oldcorollas,
i might be interested in one of those 02 sensors as mine is shagged. Do you need to alter the wiring? any benefits from a heated sensor compared to the non-heated?
cheers man
SLY16V
camden
Re: 4age o2 sensor Sat, 20 March 2004 10:42 Go to previous messageGo to next message
thread hi-jacking is illegal gze-style.... Laughing
Re: 4age o2 sensor Sun, 21 March 2004 05:42 Go to previous messageGo to next message
i pm'd him Wink
just keep in mind that the single wire will need to be within a maximum of about 1.5 feet from head for an unheated sensor, and pretty much anywhere on the extractors for a heated one.
also remember to make sure the sensor is pointing upwards (so water will not collect in it inside the exhaust pipe) water in the sensor when it heats up can destroy the zirconia sensor.
just put the flange wherever it fits, pointing up, and as close to the head as needed for the type you use.
SLY16V
camden
Re: 4age o2 sensor Mon, 22 March 2004 02:30 Go to previous message
cheers dude...
Previous Topic:10 Sec MR2
Next Topic:stupid mkIV noise
Current Time: Fri Nov 20 04:36:16 UTC 2026
Total time taken to generate the page: 0.020351886749268 seconds
