Classifieds » Miscellaneous » turbo, 'cooler, cam gears, calipers etc
BigWorm
Toymods Board Member
Turramurra, Sydney.
turbo, 'cooler, cam gears, calipers etc Fri, 19 March 2004 05:33 Go to next message
It's about time I cleared out all this stuff, and I could do with the cash.
Prices are negotiable.
Pictures of all of these items are further down in the thread.
Volvo 4 piston calipers, 100mm bolt spacing. Direct bolt onto corona ST141 struts.
$250
Custom sump for 4AG, has bulge at rear. To suit a forward curving crossmember (RWD). Includes modified oil pickup.
$200
$AGE Adjustable Cam Gear inserts, to suit 100kW cam gears.
$200
JZA-70 Factory Intercooler, 550x330x70, including tanks, 55mm in & out.
Pic & info here: http://board.performanceforums.com/forums/showthre ad.php?s=&threadid=67139728&highlight=diff erence+JZA70+MA70
$300
RB20DET Ball Bearing turbo, in good condition, compressor housing has been filed back & shotpeened. Comes with wastegate actuator, factory dump, compressor outlet pipe, & spare compressor & turbine housings.
$350
RWD extractors to suite 4A-GE, 4-2-1, made by Liverpool Exhaust.
$200
Microtech MT-8, with brand new loom, plus coil & ignitor, to suite a 4AGE.
SOLD
4A-GZE Genuine Toyota Head Gasket, brand new.
SOLD
G/M/JZA-70 Brake Master Cylinder, 25mm bore, direct bolt on replacement to R/TA23 & RA28s.
SOLD
PICTURES FURTHER DOWN.
[Updated on: Tue, 06 April 2004 13:19]
KING_22
Oakleigh, Melbourne
Re: Lots of good stuff..... Fri, 19 March 2004 12:48 Go to previous messageGo to next message
is the turbo a T28?
BigWorm
Turramurra, Sydney.
Re: Lots of good stuff..... Fri, 19 March 2004 15:57 Go to previous messageGo to next message
It has a T3 turbine inlet flange, but it's T28 size.
Attachment: DSC02536hydeditsmall.jpg
(Size: 98.37KB, Downloaded 1579 time(s))
Attachment: DSC02538small.jpg
(Size: 99.07KB, Downloaded 1678 time(s))
Attachment: DSC03797small.jpg
(Size: 97.95KB, Downloaded 1548 time(s))
[Updated on: Wed, 19 May 2004 01:50]
jackel
Re: Lots of good stuff..... Fri, 19 March 2004 18:22 Go to previous messageGo to next message
just a question, how much of a difference would them volvo calipers make if put on a st141 corona?
BigWorm
Turramurra, Sydney.
Re: Lots of good stuff..... Sat, 20 March 2004 00:32 Go to previous messageGo to next message
I imagine it'd be a pretty big difference. They fit over the standard solid disc but it would be very easy to make up some spacers & fit them over thicker vented discs too.
You may need a larger master cylinder too.
Re: Lots of good stuff..... Sat, 20 March 2004 00:36 Go to previous messageGo to next message
Is the JZA70 cooler the one in the bottom of the picture?
BigWorm
Turramurra, Sydney.
Re: Lots of good stuff..... Sat, 20 March 2004 06:05 Go to previous messageGo to next message
Yep, the bigger one.
Re: Lots of good stuff..... Sat, 20 March 2004 06:23 Go to previous messageGo to next message
Ok. Do you have pictures of yours? Whats the fins like? Any damage?
BigWorm
Turramurra, Sydney.
Re: Lots of good stuff..... Sat, 20 March 2004 06:48 Go to previous messageGo to next message
It's in pretty good nick, I sat down & spent about an hour straightening every fin, so they're all good.
Here's a pic.....
http://forums.toymods.org.au/index.php?t=getfile&id=3584&rid=37&S=8e05f3000ffe73384c64e1acf2a1362f
Attachment: 2310small2.jpg
(Size: 96.30KB, Downloaded 2035 time(s))
[Updated on: Sat, 20 March 2004 06:59]
takai
Re: Lots of good stuff..... Sat, 20 March 2004 06:53 Go to previous messageGo to next message
I assume that the Microtech comes with everything needed to just plug it into a 4A?
If so $600.
BigWorm
Turramurra, Sydney.
Re: Lots of good stuff..... Sat, 20 March 2004 06:58 Go to previous messageGo to next message
It doesn't come with any sensors or plugs, so it needs to be wired up, but that's a very simple job. It's just setup/tuned for a 4AGE.
takai
Re: Lots of good stuff..... Sat, 20 March 2004 07:05 Go to previous messageGo to next message
Ah ok, well i still have my stock 100kw loom, with all plugs. I assume that the new loom is long enough for RWD, or will i have to lengthen it?
Also, the loom would be pretty clearly marked, for injectors and stuff like that.
And also i cant find any specs on the MT8, only the LT8. But from memory they are pretty similar. Thats right eh?
Oh yeah, and possible support for a CAS?
BigWorm
Turramurra, Sydney.
Re: Lots of good stuff..... Sat, 20 March 2004 08:20 Go to previous messageGo to next message
It should be lng enough for RWD, I guess it comes down to how far through the firewall you want to mount the computer. My loom only came through about 40cm.
Loom is brand new & yes, well marked.
It's pretty much the same as an LT-8 only it cannot be tuned with a laptop, only the hand controller.
It hooks up the the CAS in the bottom of the standard 16v dizzy, so it might not work with the GZE CAS, but could be adjusted to suit.
Re: Lots of good stuff..... Sun, 21 March 2004 05:42 Go to previous messageGo to next message
You have a PM.
BigWorm
Turramurra, Sydney.
Re: Lots of good stuff..... Sun, 21 March 2004 08:37 Go to previous messageGo to next message
Here's a couple of pics.
The cam gears, nicely polished.
http://forums.toymods.org.au/index.php?t=getfile&id=3594
RB20 turbo, with writing filed off.
http://forums.toymods.org.au/index.php?t=getfile&id=3595
http://forums.toymods.org.au/index.php?t=getfile&id=3596
Attachment: smallDSC02287.jpg
(Size: 94.61KB, Downloaded 1611 time(s))
Attachment: smallDSC02291.jpg
(Size: 67.03KB, Downloaded 1025 time(s))
Attachment: smallDSC02313.jpg
(Size: 70.51KB, Downloaded 986 time(s))
[Updated on: Sun, 21 March 2004 08:41]
BigWorm
Turramurra, Sydney.
Re: Lots of good stuff..... Sun, 21 March 2004 08:55 Go to previous messageGo to next message
Here's a couple things I've just added.
$75
$200
Headgasket.
http://forums.toymods.org.au/index.php?t=getfile&id=3597
RWD Extractors.
http://forums.toymods.org.au/index.php?t=getfile&id=3598
Attachment: smallDSC02321.jpg
(Size: 95.89KB, Downloaded 945 time(s))
Attachment: DSC03362.jpg
(Size: 87.93KB, Downloaded 1554 time(s))
exqzit
UNKNOWN
Re: Lots of good stuff..... Sun, 21 March 2004 11:44 Go to previous messageGo to next message
You have pm Wink
chrizer
Re: Lots of good stuff..... Sun, 21 March 2004 22:47 Go to previous messageGo to next message
sent you a pm.
TerryOBeirne
Redbank Plains,near Ipswi...
Re: Lots of good stuff..... Mon, 22 March 2004 00:50 Go to previous messageGo to next message
can you pls post/send me a pic of the sump. what car weas it made 4??.
beware, the Volvo calipers are great, but need a 25mm or larger master cylinder and an adjustable valve fitted to rear to make them work properly.
BigWorm
Turramurra, Sydney.
Re: Lots of good stuff..... Mon, 22 March 2004 15:11 Go to previous messageGo to next message
I'll try to get some pics up tomorrow.
I don't know what it was made for, it came with an engine I bought a while back.
BigWorm
Turramurra, Sydney.
Re: Lots of good stuff..... Mon, 22 March 2004 15:16 Go to previous messageGo to next message
Added:
$50
BigWorm
Turramurra, Sydney.
Re: Lots of good stuff..... Tue, 23 March 2004 15:17 Go to previous messageGo to next message
Things to do tomorrow: take picture of bump, I mean sump.
horner boy
Re: Lots of good stuff..... Wed, 24 March 2004 12:21 Go to previous messageGo to next message
what are the specs of the extractors? (size etc.)
What car did they come off?
BigWorm
Turramurra, Sydney.
Re: Lots of good stuff..... Thu, 25 March 2004 10:34 Go to previous messageGo to next message
Pics of the sump:
http://forums.toymods.org.au/index.php?t=getfile&id=3669
http://forums.toymods.org.au/index.php?t=getfile&id=3670
http://forums.toymods.org.au/index.php?t=getfile&id=3671
Attachment: DSC03440.jpg
(Size: 72.82KB, Downloaded 1398 time(s))
Attachment: DSC03442.jpg
(Size: 62.69KB, Downloaded 621 time(s))
Attachment: DSC03443.jpg
(Size: 85.11KB, Downloaded 605 time(s))
BigWorm
Turramurra, Sydney.
Re: Lots of good stuff..... Thu, 25 March 2004 10:36 Go to previous messageGo to next message
Pics of the Volvo 4 spots:
http://forums.toymods.org.au/index.php?t=getfile&id=3672
http://forums.toymods.org.au/index.php?t=getfile&id=3673
Attachment: DSC03444.jpg
(Size: 91.31KB, Downloaded 1391 time(s))
Attachment: DSC03446.jpg
(Size: 85.05KB, Downloaded 565 time(s))
BigWorm
Turramurra, Sydney.
Re: Lots of good stuff..... Thu, 25 March 2004 10:43 Go to previous messageGo to next message
The extractors have 1 1/4" primaries, 1 1/2" secondaries & goes into 2 1/4" pipe.
They came of my RA23 Celica.
cri_ag
northern beaches
Re: Turbo, intercooler, 4 spots, extractors + more Thu, 25 March 2004 10:55 Go to previous messageGo to next message
interested in the exaust, any idea if they will fit in a sprinter? or were they made to suit the celica? also will they fit a 100kw motor?
BigWorm
Turramurra, Sydney.
Re: Turbo, intercooler, 4 spots, extractors + more Thu, 25 March 2004 13:01 Go to previous messageGo to next message
I don't see why they wouldn't fit a sprinter, the bracket hanging off halfway down bolts to one of the bellhousing bolts, to give you some perspective of how close to the motor/box they run.
And yes they would fit a 100kW.
horner boy
Re: Turbo, intercooler, 4 spots, extractors + more Fri, 26 March 2004 05:01 Go to previous messageGo to next message
what about a gze?
BigWorm
Turramurra, Sydney.
Re: Turbo, intercooler, 4 spots, extractors + more Sat, 27 March 2004 05:17 Go to previous messageGo to next message
Yep, GZE too.
BigWorm
Turramurra, Sydney.
Re: Turbo, intercooler, 4 spots, extractors + more Thu, 01 April 2004 03:13 Go to previous messageGo to next message
Bumparino.
tin can
Re: Turbo, intercooler, 4 spots, extractors + more Thu, 01 April 2004 07:45 Go to previous messageGo to next message
hy big worm im still waiting on email for cam gears
thanks jess
thug_immortal
Camden, NSW
Re: Turbo, intercooler, 4 spots, extractors + more Fri, 02 April 2004 05:05 Go to previous messageGo to next message
is it worthwhile upgrading the ma70 cooler to jza70 cooler? Or would the only worth while thing be getting a custom job?
BigWorm
Turramurra, Sydney.
Re: Turbo, intercooler, 4 spots, extractors + more Sat, 03 April 2004 17:35 Go to previous messageGo to next message
Well, here's pics of the cam gears, finally. Sorry I took so long! Smile
NOTE: I'm selling the alloy inserts only, you need to machine out & then drill & tap a set of 100kW cam gears to go with them.
Installed:
http://forums.toymods.org.au/index.php?t=getfile&id=3774
And a view of the back, showing the original gear that's been machined out.
http://forums.toymods.org.au/index.php?t=getfile&id=3775
Attachment: DSC03468.jpg
(Size: 78.32KB, Downloaded 1012 time(s))
Attachment: DSC03469.jpg
(Size: 71.58KB, Downloaded 1027 time(s))
[Updated on: Tue, 06 April 2004 13:08]
BigWorm
Turramurra, Sydney.
Re: turbo, 'cooler, cam gears, calipers etc Tue, 06 April 2004 13:22 Go to previous messageGo to next message
There's alot of good stuff left here.
I'll take offers.
bump.
Attachment: DSC03472small.jpg
(Size: 89.62KB, Downloaded 1240 time(s))
[Updated on: Wed, 26 May 2004 13:36]
schneidg
Perth, WA
Re: turbo, 'cooler, cam gears, calipers etc Wed, 14 April 2004 05:26 Go to previous messageGo to next message
I currently have a T3 turbo on my 2TGEU TA22 Celica. Someone told me to get a GT28 as it would give me much better performance - probably less lag as opposed to more power.
Just curious though. Your GT28 wouldn't bolt on to a T3 exhaust manifold would it?
Do you know if you can get GT28's that can?
Obviously, I could modify manifolds, etc. but I'd prefer not to.
Gene
Re: Lots of good stuff..... Thu, 15 April 2004 13:54 Go to previous messageGo to next message
sent you PM about the turbo.
ta,
charles.
Alainve
Newcastle NSW
Re: turbo, 'cooler, cam gears, calipers etc Fri, 16 April 2004 01:17 Go to previous messageGo to next message
why are you only selling the cam gear center? you have another use for the outer
Alainve
Newcastle NSW
Re: turbo, 'cooler, cam gears, calipers etc Fri, 16 April 2004 01:39 Go to previous message
Previous Topic:FS: 15" 5 spoke rims (no tyres)
Next Topic:FS: 20v extractors and 2" exhaust for ae92
Current Time: Mon Nov 2 00:15:35 UTC 2026
Total time taken to generate the page: 0.028700113296509 seconds
