Toymods » Tech & Conversions » SX Rolla won't start in morning????
SXI16V
Castle Hill
icon5.gif  SX Rolla won't start in morning???? Fri, 19 March 2004 05:36 Go to next message
Need some help?
My SX rolla won't start straight away in the morning?
It kicks over no problem, but i have to try 3-4 times before it starts, and when it does start its heaps rough until i hit the accelerator.
When the engine is warm I have no problems starting it.
Any help on what it could be would be great?
RollaGTi
winmalee
Re: SX Rolla won't start in morning???? Fri, 19 March 2004 09:41 Go to previous messageGo to next message
I have a GTi rolla and have the exact problem man.
The mechanic says its a cracked head or gasket. i pulled the plugs out and they are orange, he reckons thats from the moister getting in to the cylinders. cant work out what is wrong, im not losing water or oil and like you said, its only in the morning. If you start it and give it a quick rev it should be fine, you just need to get it to kick over. Clean your plugs every now and then to help it.
Thats as much as i can help you with it.
If anyone can give more info then i am all ears.
EvilJack
Sutho/Hills NSW
Re: SX Rolla won't start in morning???? Sat, 20 March 2004 04:36 Go to previous messageGo to next message
maybe your cold start injector is failing.
Scorpion
Menai area of Sydney
Re: SX Rolla won't start in morning???? Sat, 20 March 2004 06:52 Go to previous messageGo to next message
I'll vote for what EvilJack said. Very Happy
takai
Re: SX Rolla won't start in morning???? Sat, 20 March 2004 07:17 Go to previous messageGo to next message
Its the cold start injector, same thing happens on my GZE when i have it unplugged.
Tofuboi
Sunbury, VIC
Re: SX Rolla won't start in morning???? Sat, 20 March 2004 12:16 Go to previous messageGo to next message
my AE82 CSX has this problem too in the morning, sometimes in the arvo too if i havnt started it at all that day.
it will turn over first go, but VERY rough, and even with giving it some fuel through the accelerator, it still will just die out again. it takes 2-4 goes before it will turn over and stay on... but it will still be rough until its over about 1,200rpm and im giving it gas.
so it would be the cold start injector eh? hrmn... ill check that out.
SXI16V
Castle Hill
Re: SX Rolla won't start in morning???? Sun, 21 March 2004 22:13 Go to previous messageGo to next message
Thanks for the replies Very Happy
Will get new injector and try that
adamb131
Re: SX Rolla won't start in morning???? Sun, 21 March 2004 23:31 Go to previous messageGo to next message
...a wealth of info from Paul Kujawa, Toyota and Nissan specialist with Autoline Telediagnosis. "One thing that comes up frequently is long crank time cold," he told us. "The problem is that the cold start switch isn't grounding the cold start injector. We see this on '83s all the way up to '89s. I suggest they go to the switch, which is usually next to the coolant temperature sensor -- the switch will generally have a brown two-wire connector, and the sensor a green two-wire connector. Unplug the brown connector from the switch and ground the wire from the switch itself, which is usually green or yellow, then see if it starts cold for you (if the engine's warm while you're working on it, you could take the injector out of the manifold and aim it into a jar to see if it's working, but accessibility is a problem on some models). Remember, the cold start injector is just for starting -- it only gets voltage with the key in the Start position -- so don't make the mistake of blaming it for cold running problems.
"Another situation with cold start time switches is that on some Camrys and Celicas there's a hard-start problem after the engine has been sitting for two to five hours," Kujawa said. "If it's still lukewarm it may need the cold start injector, but won't be getting it because the switch doesn't ground until it gets down to 95 deg. F. or below. An updated switch is available that grounds at 113 deg."
SXI16V
Castle Hill
Re: SX Rolla won't start in morning???? Fri, 26 March 2004 05:49 Go to previous messageGo to next message
Can someone tell me the best place to get a cold start injector for my 4age and how much i'd be up for?
SXI16V
Castle Hill
Re: SX Rolla won't start in morning???? Sun, 28 March 2004 23:21 Go to previous messageGo to next message
Can someone tell me where the cold start injector is located?
RollaGTi
winmalee
Re: SX Rolla won't start in morning???? Tue, 30 March 2004 00:32 Go to previous messageGo to next message
not yet, but i got a price from toyota.
$266. this would want to be damn good.
But we all know that the toyota is expensive. Mad
SXI16V
Castle Hill
Re: SX Rolla won't start in morning???? Tue, 30 March 2004 01:07 Go to previous message
I rang toyota and i got quoted $211.20
Ring another dealer mate, bit of a rip off
Previous Topic:18rgeu turbo boost retard?
Next Topic:3SGE RWD Swap, one more time round...
Current Time: Sun Oct 18 20:04:16 UTC 2026
Total time taken to generate the page: 0.0053038597106934 seconds
