Toymods » Tech & Conversions » anyone running methanol/water injection?
MAZMAN
anyone running methanol/water injection? Fri, 19 March 2004 13:36 Go to next message
just wondering if any1 is running methanol/water injection on they're cars? if so,what kits are you using and how are you activating the kit,and any other info appreciated..
Danny
Re: anyone running methanol/water injection? Fri, 19 March 2004 14:17 Go to previous messageGo to next message
me! on a suck-thru carbi+turbo
a DIY affair, simple really:
attache line to a port on the intake manifold
put a 1-way valve in line to t-piece or alloy block.
pressure switch on base of t-piece
pressure switch can be adjustable or pre-set (mine is set to approx 5psi)
bleed valve on other side of t-piece (1/32" hole actually)
pressure switch earths circuit
from IGN, 12+ goes to a wiper/washer pump mounted at base of a tank (in engine bay) then on to switch. You can also add an indicator wired same way as pump.
pump needs inline filter after pump to prevent bleed/nozzle getting blocked
after filter, t-piece with 1/32" hole in base is attached to top of the tank
(small hole feeds into tank and prevents syphoning)
other side of t-piece goes to nozzle mounted in front of carbi
nozzle sprays thru carbi into turbo (helps atomise it before getting to turbo/manifold
keep line from bleed->nozzle as short as possible
but... if you want to spray directly into the intake manifold of a turbo then you probably need something like this <www.aquamist.co.uk>
clubagreenie
1st street on the right
Re: anyone running methanol/water injection? Fri, 19 March 2004 16:15 Go to previous messageGo to next message
Speak to ed_ma61, he is setting up on a 7mge.
Cyber-punk
Brisbane, QLD
Re: anyone running methanol/water injection? Fri, 19 March 2004 22:57 Go to previous messageGo to next message
what is the purpose of a methanol\water injection set up
i've searched on google etc
but havnt found anything clear
all i find are kits for it :/
perhaps i'm useing the wrong search parameters...
[Updated on: Fri, 19 March 2004 22:57]
Re: anyone running methanol/water injection? Sat, 20 March 2004 00:22 Go to previous messageGo to next message
It's used to suppress detonation. It basically does the same thing as an intercooler, but if set up right it can be more effective.
Re: anyone running methanol/water injection? Sat, 20 March 2004 02:37 Go to previous message
that's why i have it - otherwise, the 18R detonates fiercely over about 5psi - partly as i have no boost retard, and partly as i need a high static-advice to get it to start/run.
combined with intercooling would allow you to run higher boost/compression and/or more aggresive timing.
it might be useful in conjunction with a knock control - but latency issues (time from getting event trigger to delivery of fluid to plenum) would have to be dealt with.
however, if you dont run an intercooler, it might improve engine longevity.
Previous Topic:Anyone fitted an aftermarket charger (not SC12 or 14) to a gze?
Next Topic:Turbo upgrade for 3SGTE
Current Time: Thu Oct 29 19:58:47 UTC 2026
Total time taken to generate the page: 0.0047950744628906 seconds
