Toymods » Tech & Conversions » 22re dizzy insides in a 18rgeu dizzy
people100
Rocklea qld
22re dizzy insides in a 18rgeu dizzy Sun, 21 March 2004 03:21 Go to next message
as the subject says how is this done. Ive done it and its a direct fit in but the little lugs on the inside to actually make the sparks doesnt line up how do i fix that. Does anyone have pics of how they have done this???
people100
Rocklea qld
Re: 22re dizzy insides in a 18rgeu dizzy Wed, 07 April 2004 11:06 Go to previous messageGo to next message
bump
Steve M
Re: 22re dizzy insides in a 18rgeu dizzy Wed, 07 April 2004 23:40 Go to previous messageGo to next message
Usually it is a case of using an 18R dizzy.
The points "cam" part of the 18R shaft needs to be machined round until the four pointed star bit from the 22R presses into the spot.
As far as I could tell the outer ring bits just bolted into place in my brothers.
then you just put a hole in the outer casing of the dizzy and slide the cables through.
that is what ours looks like. Everything lines up.
The Witzl made it for us, so he should be able to tell you.
people100
Rocklea qld
Re: 22re dizzy insides in a 18rgeu dizzy Thu, 08 April 2004 09:34 Go to previous message
so it deffinetly can be successfully done then. Ill have to look into it further
Previous Topic:PROBLEM 100KW!!!!!!!!
Next Topic:r154 into ma61 tranny tunnel... final verdict
Current Time: Fri Oct 30 07:55:13 UTC 2026
Total time taken to generate the page: 0.0049710273742676 seconds
