Toymods » Tech & Conversions » Possible cheap pistons for 3T-GTE?
Purple_Beasty
New Zealand
icon5.gif  Possible cheap pistons for 3T-GTE? Sun, 21 March 2004 22:21 Go to next message
Hopefully someone can confirm this for me (I don't have access to the piston specs myself).
Was talking to a guy with a 3T-GTE the other day about pistons. Apparently he is using forged pistons from a Mercedes 280 6 cylinder. Only required a 1mm overbore and he got a complete engine for $180NZ which left him with two spare pistons.
Now to me it sound too good to be true, but maybe someone else has more details. I have no idea of pin height etc but supposedly they mated to the standard rods.
If this is correct, could be a very cheap way to get a set of decent pistons into the 3T-GTE.
Callum
roger
Re: Possible cheap pistons for 3T-GTE? Mon, 22 March 2004 00:09 Go to previous messageGo to next message
So far I have turned up a bore size of 86 on the merc pistons, I need pin height and size ?
[Updated on: Mon, 22 March 2004 00:43]
roger
Re: Possible cheap pistons for 3T-GTE? Mon, 22 March 2004 22:37 Go to previous messageGo to next message
bump,
Any one have a data base with these pistons, my searching has turned up squat. Just need to know pin height and pin diamater.
If pin diameter is 22mm
and compression height around 35mm we may be in luck
3T-GTE
Re: Possible cheap pistons for 3T-GTE? Mon, 22 March 2004 23:25 Go to previous messageGo to next message
Hmmm, sounds very interesting.
I think that even if these pistons did have a matching measurements to the 3T-GTE:
bore: 85mm (obviously can go oversize)
pin diameter: 22mm
compression height: 35mm
..it would be interesting to see how strong these pistons are. They may be forged, but they may not be well suited to high boost conditions.
Callum, can you find out any more details about these pistons? It would be great to know what model the pistons came out from.. especially what year would be a good start, as the 280 has been around since the 1970s, I would say they wouldn't have used forged pistons until much later than that.
I guess also being a Mercedes, it may not be the cheapest option either, especially if you are looking at buying new pistons.. but it could still be cheaper than custom forgies..
Worth investigating futher.
3T-GTE
[Updated on: Tue, 23 March 2004 04:14]
Purple_Beasty
New Zealand
Re: Possible cheap pistons for 3T-GTE? Tue, 23 March 2004 01:25 Go to previous messageGo to next message
Can't get more details sorry, was out of town at the time and don't know the guy.
He was babbling on about being merlin forged pistons, strongest you can get blah blah blah. Thats why I really want to get some actual confirmation. Apparently his own engine was running around 17 pounds boost and 295hp at the wheels, but as they say talk is cheap.
Callum
3T-GTE
Re: Possible cheap pistons for 3T-GTE? Tue, 23 March 2004 02:21 Go to previous messageGo to next message
With a lot of luck he might read this thread on Toymods & give us some more info Rolling Eyes
Seriously speaking though, if there is an ounce of truth to what he was saying, it would definitely be worth looking into some more.
I'm wondering if a call to Mercedes spare parts division may be worthwhile. Not sure how helpful they may be or if they will have the information we need on record, but it is worth a try.
kool22
Mentone
Re: Possible cheap pistons for 3T-GTE? Tue, 23 March 2004 03:33 Go to previous messageGo to next message
Reading this, this morning got me quite interested as well, and working for mercedes in spare parts, i thought I might do a bit of investagating. Now the pistons from a 110 motor (280S,SE,SEL)
are 86mm in standard form, but the pictures aren't the best, and as benz don't keep any in the country (at $310 odd a slug there isn't much call for them) I can't check pin size. So I called a customer who is a benz engine builder and he has a set of non genuine pistons there that I will measure up against my 3tgte pistons (when I get the motor apart) and let you all know.
roger
Re: Possible cheap pistons for 3T-GTE? Tue, 23 March 2004 04:04 Go to previous messageGo to next message
Kool 22,
sound like a good contact you may have. the 110 engine is the one with the right piston size so I am assuming this is the one also. In the mean time can you get a measurement of the pin diameter and a height from either pin center to crown top or pin top to crown top? as that would give as the best indication as to whether they are a goer.
As far as strength is concered mercedes typically make tuff engine stuff built to tolerance unmatched by local car manufactures any way.
Roger
3T-GTE
Re: Possible cheap pistons for 3T-GTE? Tue, 23 March 2004 04:24 Go to previous messageGo to next message
Kool22, I'd be very interested also.
From what I have found, speaking to someone who has "dabbled" a little with Mercs, is the following:
C280:
Motor designation M104.941
89.90 x 73.50 B/S
1.22:1 B/S ratio
10:1 Compression
1.5 x 1.75 x 3.0 Rings
He is going to see if he can find out the pin diameter & height for me... see how we go.
3T-GTE
Re: Possible cheap pistons for 3T-GTE? Tue, 23 March 2004 04:27 Go to previous messageGo to next message
Roger,
As far as strength goes, yes I agree they should be stronger than most, but I would wonder how they would compare to some Sean Maloney specials, or some Ross / Weisco Forgies... if they would be as good???
Any thoughts??
Purple_Beasty
New Zealand
Re: Possible cheap pistons for 3T-GTE? Tue, 23 March 2004 05:32 Go to previous messageGo to next message
My intention was not to compare to new forgies (at $300 plus each might as well go custom). But may be useful for a budget build where good condition second hand forgies make a rebuild affordable when a standard piston dies.
Callum
Jayem
Finland
Re: Possible cheap pistons for 3T-GTE? Tue, 23 March 2004 16:06 Go to previous messageGo to next message
This is so interesting! Smile
I have been looking cheap pistons for my turbo 3T project, too.
I asked this from my friend who has piston catalogue, he hasn't replied yet.
Are they forged or not? In stock form, I believe that these pistons are pressure casted and made by Mahle. Like most of the German and Swedish car pistons. Just like VW "forgies".
There is good chance that Mahle might supply these as forged too(still cheap). Somebody prove me wrong Very Happy .
Jayem
Finland
Re: Possible cheap pistons for 3T-GTE? Tue, 23 March 2004 16:35 Go to previous messageGo to next message
http://www.laffey.co.uk/mercedes/mercedes.php
kool22
Mentone
Re: Possible cheap pistons for 3T-GTE? Tue, 23 March 2004 21:53 Go to previous messageGo to next message
I'll measure them up later today, and let you all know Smile I'll also find out what the cost of them are and if they are forges or not. (but I have a sneaky suspicion theyr'e not)
3T-GTE
Re: Possible cheap pistons for 3T-GTE? Tue, 23 March 2004 22:06 Go to previous messageGo to next message
Sounds great Kool22, I'm very interested to see if they are the right size, & most importantly forgies.
I'd say if they are forged & will work, you might find a sudden increase in demand for these 280 pistons Wink
roger
Re: Possible cheap pistons for 3T-GTE? Tue, 23 March 2004 22:26 Go to previous messageGo to next message
At $300 a hit brand new je/ross forgies would be the go. I would use second hand pistons if they are forgies.
Talking to a mercedes inthusist at work that knows his cars. He belives they are forged. I belive Mercedes gear is made in house unlike other euro manufactures.
Strength of the piston will depend on the ring grove positions on the piston and the piston material both unknown but if forged certainly stronger than normal.
Jayem,
How configdent are you that these are Mahle pistons? Even if they are Mahle pistons, these things are still strong. I know people putting them into escort engines running 9000 rpm with good results compared to cast pistons (no more cracking at the ring lands)
With the link you have provided if you take a look at the 280 you will see item 49a under engine ie all information is not provided.
Take a look at the 200 and there is a lot more detail ie pin diameter but still no compression height.
3t-gte,
The details you have provided seem to be from a earlier engine ie M104 as opossed to M110. The 89.9 bore is pusing it on a 3t engine, but by all means get the pin diameter and compression height, may be usefull for someone building a 2ltr 3tgt.
Roger
[Updated on: Tue, 23 March 2004 22:35]
Jayem
Finland
Re: Possible cheap pistons for 3T-GTE? Tue, 23 March 2004 22:56 Go to previous messageGo to next message
Quote:
Jayem,
How configdent are you that these are Mahle pistons?, with the link you have provided if you take a look at the 280 you will see item 49a under engine ie all information is not provided.
It's more like hunch. AFAIK. VW, Audi, Saab and Volvo uses Mahle as stock pistons and I vaguely remeber that BMW and MB belongs into that bunch too. But I could be very wrong.
There aint too much info but something to give idea and what I get from my friends shabby message, it looks like MB pistons wont work. Yet Im hoping that Im wrong! It did look that compression height is +40mm and pin diameter is ~26mm depending on MB engine.
My friend send my this: "Catalogue didnt know such a engine as M110 and closest on MB's was 86x42.7+ 14.9x89.6".
That's Hebrew to me Confused .
Once again I hope that Im wrong!
3T-GTE
Re: Possible cheap pistons for 3T-GTE? Wed, 24 March 2004 00:11 Go to previous messageGo to next message
Some more thoughts...
First thought ... One thing that we will need to work out is how the piston shape will effect the final compression ratio. The 3T-GTE pistons have quite a dome shape, going to a flat top is going to drop the compression ratio a fair amount... & if the Merc pistons are dish/bowl shaped, it could drop the compression ratio even further.
Another thought... speaking with another engine builder he tells me that the Nissan VG30 pistons will work in the 3T-GTE also. Has anyone ever looked into these? Are they forged?
A final thought ... Speaking with yet another engine builder friend I have also come across some brand new forged pistons that I could get a full set for $900.00, even includes high quality rings. This makes me wonder, how much cheaper could I do it even if the Merc pistons worked, I would still need to buy rings, & pin-clips etc... I reckon it would be hard to do it any cheaper than $900.00
Any thoughts??
kool22
Mentone
Re: Possible cheap pistons for 3T-GTE? Wed, 24 March 2004 01:19 Go to previous messageGo to next message
Ok had them measured, and here we go:
Pin size is 23mm
And from the top of the pin to the top of the piston is 30.5mm
Now they're not forged, they are heavily domed at the top,are about $800 for a set of 6, and from what he says they are a much heavier piston than the toyota piston, so balancing problems may occur.
But I have been doing some other looking myself and found that paradise garage in the states (they are the guys that race the 3t powered cars) have a special at the moment, a set of forges (with pins and rings) for about $400US. And they only charge $20US to ship overseas. With the dollar doing well at the moment, that could be another avenue people could go down. They also have all maner of other cool stuff for 3ts for sale.
3T-GTE
Re: Possible cheap pistons for 3T-GTE? Wed, 24 March 2004 02:01 Go to previous messageGo to next message
Hi Kool22,
Sounds like the Merc 280 pistons are no go, both for price & also sizing.
The "Paradise Garage Special" sounds really good... do you have a URL for them? $420 US works out to around $560 Australian.. I'd say that is a great deal, depending on the quality of the pistons & rings.
Any more info you could give us on these would be great.
Any thoughts on the Nissan VG30 pistons?
kool22
Mentone
Re: Possible cheap pistons for 3T-GTE? Wed, 24 March 2004 02:51 Go to previous messageGo to next message
Theyr'e called paradise racing (not garage, sorry Rolling Eyes ) and their address is www.paradiseracing.com
The special is close to $500US, but still thats not bad!
As for the VG30 slug, I haven't heard anything about them as yet, but if someone has a connection at nissan they could be a cost effective option.
3T-GTE
Re: Possible cheap pistons for 3T-GTE? Wed, 24 March 2004 03:10 Go to previous messageGo to next message
Thanks for the link Smile
For everyone else, here is what they look like:
http://www.paradiseracing.com/ariaspistons4agte.jpg
Comes complete with:
Forged pistons.
Wrist pins: high carbon, case-hardened.
Ring set: chrome moly faced top, cast 2nd, 3-piece oil.
Locks: carbon steel wire.
They have a special on a 4 cylinder kit for $499.00 US + $20.00 US for shipping = $690 Australian.
They certainly look nice & shiny in the picture, but has anyone ever used Arias pistons here before? I wonder what the quality is like, compared to say a Ross forgie??
Also, am I correct in remembering (it has been a while Rolling Eyes) that the 3T-C has the exact same bore, pin diameter & height as the 3T-GTE... in fact the 3T-C shares the same block as a 3T-GTE??
boris
On probation
Brisbane, Queensland
Re: Possible cheap pistons for 3T-GTE? Wed, 24 March 2004 03:11 Go to previous messageGo to next message
they look pretty though
CLG
Perth, Western Australia
Re: Possible cheap pistons for 3T-GTE? Wed, 24 March 2004 04:29 Go to previous messageGo to next message
Those pistons in the photo are for a 16 valve motor, factory 3TGTE pistons look nothing like that from memory, and the new slugs would need machining to clear I'd say, losing more compression not only from the machining but also the four valves flycuts too.
Purple_Beasty
New Zealand
Re: Possible cheap pistons for 3T-GTE? Wed, 24 March 2004 05:13 Go to previous messageGo to next message
if you go to http://www.paradiseracing.com the picture covers all the piston sets on sale.
Having said that, the pistons are for the 3T-C with no mention of comp ratio. I assume the 3T-G pistons having much lower compression could create problems. May need to contact them to check if they have them for turbo 3T applications.
Callum
kool22
Mentone
Re: Possible cheap pistons for 3T-GTE? Wed, 24 March 2004 05:35 Go to previous messageGo to next message
I was a bit secptical about the picture as well, so I email them (his name is Luis) and asked him if had any pictures of the 3T slugs. I also invited him to join the discussion as I have read some of his threads on club 4ag and he knows his stuff on the 3Ts. So I'll let you know what he says (or he'll let us all know if he joins)
3T-GTE
Re: Possible cheap pistons for 3T-GTE? Wed, 24 March 2004 22:36 Go to previous messageGo to next message
Hi Kool22,
Have you heard anything back yet?
I would be interested in seeing if he can give some details on the arias pistons suited to a 3T-GTE?
I also noticed that they had a website:
http://www.ariaspistons.com
They had some pretty good specials on their specials page (none sutied to the 3T-GTE though)
Perhaps it is worthwhile contacting Arias directly?
Maybe we could do a "group buy" through Toymods & see if we can get a good price?
haydennz
Re: Possible cheap pistons for 3T-GTE? Thu, 25 March 2004 10:55 Go to previous messageGo to next message
i'd be very interested in a set for under $1000NZ
kool22
Mentone
Re: Possible cheap pistons for 3T-GTE? Thu, 25 March 2004 22:02 Go to previous messageGo to next message
Nah nothing as yet, but I'll keep you all posted Smile
CLG
Re: Possible cheap pistons for 3T-GTE? Fri, 26 March 2004 00:29 Go to previous messageGo to next message
3T-GTE wrote on Thu, 25 March 2004 06:36
Been there, tried that, it never seems to get off the ground (maybe too many keyboard warriors?!?):
http://forums.toymods.org.au/index.php?t=msg&t h=26686&rid=1781&S=655352c88c2c295a1d22d23 b7b6df2a2&pl_view=&start=0#msg_230408msg_2 30408
I have spoken to "buttocks" about the price and availability of forged pistons, he had alot of good "supply" info, I suggest you send him a link and an invite to join the conversation. Personally, I've decided to go with a 3SGTE, over rebuilding a 3TGTE.
3T-GTE
Re: Possible cheap pistons for 3T-GTE? Fri, 26 March 2004 02:42 Go to previous messageGo to next message
PM sent... hopefully, he might be able to shed some light on the subject.
I was also looking down the path of going to a 3S-GTE, but I figured if I was going to go that far, I would probably go something completely different... It would have to be lightweight & powerful .. probably a 13B turbo...
Previously I was crazy enough to have a 1JZ in the TA-22... went like a rocket, not so good around corners though. Rolling Eyes
For now, I am just looking to get my TA-22 up to a decent speed on a budget (got a family to support & house to pay off these days) ...so I can go out & have some fun Sprint racing at Phillip Island... with the handling / braking package I have now the 3T-GTE will probably do nicely for now.
So, if I can find some decent quality forged pistons at the right price & throw on a T28 BB - of a S15 (or something similar) that will do nicely.
CLG, what vehicle are you running the 3T-GTE in at the moment? What is it used for?
[Updated on: Fri, 26 March 2004 02:43]
CLG
Re: Possible cheap pistons for 3T-GTE? Fri, 26 March 2004 04:52 Go to previous messageGo to next message
It currently resides in the RA28 advetised in the signature thread below, and is used for Tarmac Rallies/Touring Road Events, short and long course motorkhanas, track days, sprints, ..., and is also adorned with a T28 off the side!
3T-GTE
Re: Possible cheap pistons for 3T-GTE? Sun, 28 March 2004 23:41 Go to previous messageGo to next message
So did anyone look into any of these options further?
I am still wondering about the VG30 pistons. From what I have heard these will work in a 3T-GTE.
Looking up some specs on the VG30, there is the VG30-DETT engine which came out in the 300ZX from 1989 onwards, producing 280hp@6000. Surely, this would have had some decent forged pistions???
Jayem
Finland
Re: Possible cheap pistons for 3T-GTE? Mon, 29 March 2004 13:06 Go to previous messageGo to next message
I did think about 3S-GTE pistons, but forget the idea due to compression ratio dilemma. I have again started to think about this recenly because 4A-GZE pistons are in reputation of cheap and good, so I guess 3S-GTE should be also. 3S-GTE has 22mm gudgeon pin and 35mm compression height. Diameter in standard form is 86mm and you can get 0.25, 0.5 and 1mm overbore sizes(from memory). Suitable for 3T you might say but these come with bowl top. Was it something like -8cc. Anyway, I'm thinking about shaving the head and fill welding the compression chambers in the head.
Has anybody tried this?
3T-GTE
Re: Possible cheap pistons for 3T-GTE? Tue, 13 April 2004 03:38 Go to previous messageGo to next message
Did anyone get any further with this?
I have also heard that apart from the VG30 Pistions, it may also be possible to use the SR-20 pistons.
Does anyone know anything about these?
3T-GTE
EMP-2TG
Carlingford, Sydney
Re: Possible cheap pistons for 3T-GTE? Tue, 13 April 2004 08:22 Go to previous messageGo to next message
damn u guys are getting some great info here
i heard that 3sgte pistons fit, and there is a guy floating round here somewhere that has a set in his 3tgte
roger
Re: Possible cheap pistons for 3T-GTE? Tue, 13 April 2004 23:07 Go to previous messageGo to next message
SR20 pistons would also be my pick if you simply needed pistons that replace the current one (not forged put probably a good piston none the less)
Dimension are
Bore = 86mm standard up to 87mm
Compression height = 32mm
Pin diameter = 22mm
compression height may seem a little low but with machining of the head and block some could be recovered.
The SR20 pistons are not fly cut like the 3sgte pistons and are a dome shaped piston
3T-GTE
Re: Possible cheap pistons for 3T-GTE? Wed, 14 April 2004 00:01 Go to previous messageGo to next message
I am leaning towards the VG30 pistons. I believe that these are the same dimensions as the SR-20 & will work well in the 3T-GTE.
I also believe that they are forged, but I am yet to confirm this.
I am going down to check out a VG30DETT engine in the next couple of weeks & see for myself if these are forged.
It would be good to know if anyone else has looked into this already.
mongorola
christchurch (new zealand)
April 2005
Re: Possible cheap pistons for 3T-GTE? Tue, 26 April 2005 10:42 Go to previous messageGo to next message
r 3tc pistons the same as 3tgte?
c2888
Re: Possible cheap pistons for 3T-GTE? Tue, 26 April 2005 16:17 Go to previous messageGo to next message
Wiseco do a 3tc forged piston, dunno if this is any good.
I have no idea, i break em, not build em Very Happy
http://www.wiseco.com/PDFcatalogs/SC05_toyota.pdf
dodgydan
styler
Re: Possible cheap pistons for 3T-GTE? Tue, 12 July 2005 05:19 Go to previous messageGo to next message
anyone found more info or possible oem forged pistons? wiseco do a low compression 22mm pin 35 compress height piston, id say thats the cheapest one i have found. i read about using vw pistons too - mahle.
Merudo
Central Coast, NSW
February 2005
Re: Possible cheap pistons for 3T-GTE? Tue, 12 July 2005 05:51 Go to previous messageGo to next message
mongorola wrote on Tue, 26 April 2005 20:42
holy resurrected topics batman!
GefGef
January 2005
Re: Possible cheap pistons for 3T-GTE? Tue, 12 July 2005 12:08 Go to previous messageGo to next message
I've built a number of engines using Wiseco pistons. For 1800+ 2TG's and 3TGTE's I've never paid more than $720 delivered. They're listed as 3T-c pistons from the yanky market. They've got larger diameter and deeper valve reliefs than standard 2TG or 3TGs for the use of oversized valves and bigger cams. For how good they are I reckon they're cheap as chips. Definately cheap insurance anyway. I've never busted one and believe me I've tried.
Jezza
Re: Possible cheap pistons for 3T-GTE? Tue, 12 July 2005 22:27 Go to previous messageGo to next message
care to share where you get your wiseco's from?
wouldnt mind a set....then i just need to find a 3t crank Wink
muaythaiman
Re: Possible cheap pistons for 3T-GTE? Tue, 12 July 2005 23:18 Go to previous messageGo to next message
A mate of mine recently bought some ARIAS pistons for a 3tg build up. He has never used them before and usually uses wiseco forgies. They were that much cheaper he couldn't resist. Will be interesting to see how they go. If they have no problems I will be buying a set for my donk.
bunkyT18
Pilbara
Re: Possible cheap pistons for 3T-GTE? Wed, 13 July 2005 01:50 Go to previous messageGo to next message
I had heard a whisper that there were some forged pistons from both VW and Mazda that would be applicable for a 3TGTEU but I'm not sure if these were for a turbo 3TC or a twin cam head.
Windex
Melburn!
June 2005
Re: Possible cheap pistons for 3T-GTE? Wed, 13 July 2005 02:57 Go to previous messageGo to next message
3T-GTE wrote on Wed, 14 April 2004 10:01
I am pretty sure they are forged, and that they will work if the SR20 ones do. Because some of the pulsar boys (www.pulsar.org.au) have aparantly used them. However in the SR20's they raise the compression to something like 11:1.
Purple_Beasty
New Zealand
Re: Possible cheap pistons for 3T-GTE? Wed, 13 July 2005 03:28 Go to previous messageGo to next message
Merudo wrote on Tue, 12 July 2005 17:51
Isn't it a good thing when someone uses the SEARCH button????
Rolling Eyes
bunkyT18
Pilbara
Re: Possible cheap pistons for 3T-GTE? Wed, 13 July 2005 03:43 Go to previous messageGo to next message
<edited post due to low blood sugar levels> I'm ok now Razz
[Updated on: Wed, 13 July 2005 05:02]
styler
Re: Possible cheap pistons for 3T-GTE? Wed, 13 July 2005 09:31 Go to previous messageGo to next message
this thread is not over... that is why it has been brought up Wink
so far i can find a set of wisecos for about aus 550 from the US not including shipping of ??. anyone found cheaper?
styler
Re: Possible cheap pistons for 3T-GTE? Wed, 10 August 2005 02:17 Go to previous message
seems the guy who built my 2tg hybrid used nissan navara pistons???, but also needed to weld up the head chambers a bit because it had a too low compression. maybe these would be right for 3tgte? if they are forged it would be even better!
Previous Topic:AE86 Fuel pump not working
Next Topic:3tgte clutch upgrade?
Current Time: Sun Oct 18 15:55:54 UTC 2026
Total time taken to generate the page: 0.010234832763672 seconds
