Toymods » Tech & Conversions » idle adjuster screw on 18rgeu
barned01
idle adjuster screw on 18rgeu Mon, 22 March 2004 06:55 Go to next message
ok in order to get to a decent idle i almost have to have my idle adjuster screw falling off, if i put the spring on it then it usually has enough force throw the screw out of it's hole.
so one begs the question.
1. Is my screw buggered (hmm this sentence sounds weird)
2. is the throttle body thread stuffed.
3. is the idle tuning all wrong
why won't it stay?
sik sx
Sunshine Coast
Re: idle adjuster screw on 18rgeu Tue, 23 March 2004 04:22 Go to previous messageGo to next message
hey
i have the same problem..the idle didnt change much when i screwed it out..and it was on its last thread like it felt like it was gonna fall out..so i screwed it in a bit more..but the idle is still ruff with air con on..mine might be screwed to..i dont know
good luck
HighRolla
Re: idle adjuster screw on 18rgeu Tue, 23 March 2004 09:31 Go to previous message
sik sx. if you have trouble with air con on - adjust aircon idle up valve. It's a seperate unit located away from the throttle body. You can just turn nob with fingers.
As for not having adjustment. I've never had this problem but would suggest that maybe the channel that allows air in when you open screw is blocked up with something. I'm sure somebody else has had this problem and could give more info
Previous Topic:difference between W50 and W55
Next Topic:gearbox Q (supra)
Current Time: Thu Oct 29 12:59:24 UTC 2026
Total time taken to generate the page: 0.022650957107544 seconds
