Toymods » Tech & Conversions » Oil pressure sender and idiot light?
demuire
Ipswich
Oil pressure sender and idiot light? Mon, 22 March 2004 11:58 Go to next message
I've got a 4AGE, and I want to run an oil pressure gauge, oil temp gauge and the oil pressure idiot light (red light that comes on when low pressure).
Instead of running 3 separate senders, a friend of mine mentioned to me he's heard of a way to make the idiot light work using the oil pressure sender? Something about (he wasn't sure either) using some sort of diode that only allows current through after a certain voltage?
Does anyone know how to set this up?
demuire
Ipswich
Re: Oil pressure sender and idiot light? Mon, 22 March 2004 12:00 Go to previous messageGo to next message
Did a quick search, I think it's called a Zener diode?
Re: Oil pressure sender and idiot light? Mon, 22 March 2004 13:08 Go to previous messageGo to next message
Yep, it is. A Zener will only conduct above a certain voltage, consult an electronics book for more details, or just use a combined idiot light/gauge sender Evil or Very Mad
demuire
Ipswich
Re: Oil pressure sender and idiot light? Mon, 22 March 2004 13:12 Go to previous messageGo to next message
Already have the oil pressure sender, so don't really want to buy another one (considering mine cost me $70!!!)
Had a look around the net, apparently some senders work by frequency, and based on what my friend said, I'm guessing some work by voltage... I wonder what the VDO ones do...
I presume testing it by applying 12V to it and then applying air pressure and testing voltage would be the best way to test it?
Also, what pressure should the light come on at?
[Updated on: Mon, 22 March 2004 13:13]
Re: Oil pressure sender and idiot light? Mon, 22 March 2004 23:27 Go to previous messageGo to next message
I'm very interested in this, currently only have the gauge which is useless really as you can't always be watching it unlike a light that warns you.
At a guess 15psi you'd want the light to come on at?
demuire
Ipswich
Re: Oil pressure sender and idiot light? Tue, 23 March 2004 00:11 Go to previous messageGo to next message
Actually, stuff trying to pressurise the sender... Just hook up a variable resistor to the signal wire and change resistance until you get the pressure you want it to come on at, and then check that voltage...
Now the only question is what pressure you'd want the idiot light to come on at... Might have a look at the 4AGE book when I get home and see what the normal operating pressure is... Unless someone on here knows it off the top of their head? Smile
IRA11Y
Club Member
Re: Oil pressure sender and idiot light? Tue, 23 March 2004 03:14 Go to previous messageGo to next message
60-80 psi from memory, drops as low as 20-25 at idle
use a potentiometer to dial up your required resistance depending on what your doing.. i.e track or road. obviously on the track youd want your pressure to stay nice and high when your at high rpm, cause if it lets go at 6000rpm by the time the pressure drops to around 15psi to turn the light on your engine will allready be on its way to rebuild city.
just find the voltage range of the sensor and buy a potentiometer (with or without an added resistor) to suit the range
demuire
Ipswich
Re: Oil pressure sender and idiot light? Tue, 23 March 2004 03:30 Go to previous messageGo to next message
So... For normal driving 15psi is a reasonable pressure to have the light come on?
Trying to understand what you mean with the potentiometer, I'm guessing to run a potentiometer and the zener diode (of a much lower voltage breakoff) and set the potentiometer high when driving around normally so that the light will only come on at low (ie 15psi) pressure, and then set the potentiometer high for trackwork so that the light will come on at a higher (ie 40psi maybe) pressure?
STR8 2.8
Re: Oil pressure sender and idiot light? Tue, 23 March 2004 09:27 Go to previous messageGo to next message
why not just use a t-piece where the sender mounts to the block?
if its anything like the old 5ME, a t-piece with the factory sender and the gauge hookup will do fine.
IRA11Y
Club Member
Re: Oil pressure sender and idiot light? Tue, 23 March 2004 10:12 Go to previous messageGo to next message
because T pieces like to snap off leaving a small section in the block under even mild vibration Wink
demuire
Ipswich
Re: Oil pressure sender and idiot light? Tue, 23 March 2004 14:06 Go to previous messageGo to next message
There is no factory sender Razz Plus I've got oil pressure and temp I want to hook up, would prefer not to also have to run another sender for idiot light, if I can use the oil pressure sender that would be flash Smile
I'm thinking of running a T-piece, mount oil temp sender (small) on one side, and remote mount the oil pressure sender (big). Hopefully with little stress on it it won't crack or break...
Re: Oil pressure sender and idiot light? Tue, 23 March 2004 23:44 Go to previous messageGo to next message
Yeah I had a T piece and broke. was a huge pain to get the bit out of the block. Had to get a specalist come and drill it / tap it out and had the headache of wondering if any metal filings fell in inside. Would never run one again.
c2888
Re: Oil pressure sender and idiot light? Wed, 24 March 2004 00:20 Go to previous messageGo to next message
If you wanna run 2 senders
pictures, thousand words
http://www.theoldone.com/articles/oilpressure/
explaination ain't bad either
dodgydan
Anthony Kellam
Re: Oil pressure sender and idiot light? Wed, 24 March 2004 00:28 Go to previous messageGo to next message
If you want to accurately set an "idiot light" you should look in to a more useful device called a comparator. There are many cheap kits (under $20) in Jaycar and DSE based on these (the LM339 is a common one). Examples of these kits are low fuel warning lights, over temp warning lights etc. most of the kits show how to adapt the kit to another application. A little more elegant than chucking a zener diode on it and due to the high input impedence of a comparator, it wont affect your analog guage at all.
I am pretty sure the VDO type you have will be voltage output.
In a 4AGE with idiot light only a few seconds of cranking is enough to extinguish the light so one would have to presume that it is in the range of 5-10 psi.
With the above circuit, you could also have two settings as suggested, selectable with a switch.
demuire
Ipswich
Re: Oil pressure sender and idiot light? Wed, 24 March 2004 04:12 Go to previous messageGo to next message
c2888: Thanks heaps for that link, might run that setup Smile
Anthony: Thanks for that... Would the Jaycar kit KA1778 work? That's the closest I can find on their website...
Re: Oil pressure sender and idiot light? Wed, 24 March 2004 04:23 Go to previous messageGo to next message
fwiw: check the block near the poil-pressure sender as there might be another take-off point.
My 18R block had a steel, screw-in plug blocking a hole just below the oil-pressure sendor. Both ports opened up to the same oil gallery.
So i have the oil pressure sensor in the lower hole and the upper hole feeds the oil-cooler which feeds cool oil to the turbo.
maybe your block has an alternate port?
Also, i've seen thick, pipe-like brass fittings that have the same female threaded hole and one half-way down the 'pipe' so you could run a hose to this fitting to remote it and have two holes. I'll see if it's still in my collection of plumbing shit when i get home - tho i do recall stuffing it when trying to clean the threads out with a cheapo tap-n-die set.
IRA11Y
Club Member
Re: Oil pressure sender and idiot light? Wed, 24 March 2004 05:47 Go to previous messageGo to next message
I have seen the remote T piece set up before and to me its just another easy failure point. Although PVC tubing is fairly rugged it is not uncommon for the connection points to fail, leaving a nice big oil spray around the engine bay
personally id just run a second wire off the factory pickup to the idiot light.
demuire
Ipswich
Re: Oil pressure sender and idiot light? Wed, 24 March 2004 05:54 Go to previous messageGo to next message
Michael: I see the point you're making. However, for me it's not as simple as running a second wire off the factory pickup point. If you read the above posts you'll see what I mean.
For a start, my sender doesn't screw into the factory pickup (different thread) so I'll need to use an adaptor anyway. Secondly I have 2 senders to feed - temperature and pressure. Therefore I either need two seperate points on the block to feed from, or run a T-piece - remotely or otherwise.
Does anyone know what the other hole in the block is (next to the factory oil pressure sender)? If I'm not mistaken (I briefly saw it the other day, didn't investigate) there is a bolt through it. Does it lead to the same oil gallery? If so I might be able to put the temp sender on there with an adaptor (it's only small and light after all) and just run a flex line from the factory point to the oil pressure sender, remotely mounted. That way I don't need to run a T-piece.
IRA11Y
Club Member
Re: Oil pressure sender and idiot light? Wed, 24 March 2004 06:34 Go to previous messageGo to next message
there are plenty of places to pick up a second line.. goto Bill Sherwoods website and look for the oil flow diagrams , i think club4ag has them too and you can easily see where the other pickup points are.. you can also drill and tap at a couple of points.. youll see the flat machined spot where to do it on the block when you cross reference the pictures
you can buy short adapters that fit the sender so that the weight is still close to the block.. the other option is to use a T piece but make a supporting brace off the block to help stabilise it.. if done correctly it can help.
demuire
Ipswich
Re: Oil pressure sender and idiot light? Wed, 24 March 2004 06:39 Go to previous messageGo to next message
Ta for that, I'll go look for those oil flow diagrams tonight...
takai
Re: Oil pressure sender and idiot light? Wed, 24 March 2004 06:52 Go to previous messageGo to next message
That bolt next to the oil sensor is the coolant drain plug, not a hugely great idea to loose that.
demuire
Ipswich
Re: Oil pressure sender and idiot light? Wed, 24 March 2004 07:08 Go to previous messageGo to next message
Ah dang. Oh well, thanks for the info, saves me taking it out and finding green stuff instead of black stuff Smile
pedroenglish
icon14.gif  Re: Oil pressure sender and idiot light? Wed, 24 March 2004 11:08 Go to previous message
I had this problem when I changed the dash for one with extra instrumentation with the new electric oil guage I still wanted the idiot light as well. I found the voltage at the sender was lo with the motor stopped and went up over a volt as engine started and oil pressure went up. I used this voltage to switch on a small transistor that disabled another pulling on the idiot light, so that when oil pressure low or non-existant idiot light came on.
Cost of bits close to zero.
Previous Topic:speaker and sub help?
Next Topic:urgent help needed on TO4 & TO4E
Current Time: Sun Oct 25 23:21:12 UTC 2026
Total time taken to generate the page: 0.0050220489501953 seconds
