Toymods » Tech & Conversions » MX83 strut/brake upgrade for MA61
MX83 strut/brake upgrade for MA61 Mon, 22 March 2004 13:08 Go to next message
For anyone who wants 5-stud hubs, bigger brakes and coilovers on their MA61, you might want to look at this little web page I slapped together. Note that this info also applies to RA6x Celica's and of course MX83 Cressida's. Thanks go to John Duel from ImportBitz.com for letting me borrow his struts/brakes for the test-fit!
http://members.optusnet.com.au/~norbee/StrutUpgrad e/default.htm
Re: MX83 strut/brake upgrade for MA61 Mon, 22 March 2004 13:26 Go to previous messageGo to next message
Keep me posted Norbie, this has got to be the easiest way to upgrade MX73 to 5 stud
bbaacchhyy
Re: MX83 strut/brake upgrade for MA61 Mon, 22 March 2004 15:23 Go to previous messageGo to next message
Norbs
Do you have an indicative (or even accurate measure for that matter) measurement for the difference in arm length between the 300ZX and R33 calipers ?
Michael B
Re: MX83 strut/brake upgrade for MA61 Mon, 22 March 2004 16:05 Go to previous messageGo to next message
norbie - do you have any exact measurement in terms of change in offset?
if the +35 fould the outer edge, would some +40s fix that?
bbaacchhyy
Re: MX83 strut/brake upgrade for MA61 Mon, 22 March 2004 16:42 Go to previous messageGo to next message
Norbs,
Just another quick question. The adjustable strut tops that are shown for the JZX81/MX83 - can you explain a little better how it doesn't sit properly ?
Got any spare Very Happy
{EDIT} : Are the ones that suit an AE86 anywhere near similar ? Do any other strut tops fit ?
Also, as mentioned in the article, you indicate that the MX83 strut has a shorter body, but does the overall length of the strut provide you with the right height, or do you have to get custom springs made up to compensate ?
Michael B
[Updated on: Mon, 22 March 2004 17:44]
wilbo666
Re: MX83 strut/brake upgrade for MA61 Mon, 22 March 2004 22:12 Go to previous messageGo to next message
bbaacchhyy wrote on Tue, 23 March 2004 03:42
I'm pretty sure that the bolt spacing on the tops differs by something like 5mm between MA61/RA65 etc and AE86 and MX62 for that matter Rolling Eyes).
Re: MX83 strut/brake upgrade for MA61 Mon, 22 March 2004 23:03 Go to previous messageGo to next message
So many questions!
- I didn't measure the differences between the R32 and R33 calipers, but I'd guess the mounting holes on the R33 caliper are about 10mm further out.
- Unfortunately I had no way of measuring the change in offset since there are too many variables affecting it. I really won't know anything about wheel clearance until I have a complete spring/strut combo properly installed in the car with the camber issue sorted out. I have a feeling I won't be able to use a tyre any wider than 225 though.
- The JZX81 strut tops do sit properly, it's just that they're rotated about 30 degrees and thus not "square" with the struts. It's really not a big deal, and in fact it's probably a good thing as you get a little more caster as you dial in more camber. No I don't have any strut tops spare, in fact I don't have any of my own yet!
- The shorter length of the JXZ81 strut is pretty much irrelevant since you need to weld on a different spring seat (or coilovers) anyway. Since you're doing that you can mount the spring wherever you like, and you can make the overall length of the strut the same as your old strut if you want.
[Updated on: Mon, 22 March 2004 23:04]
rsdeo
Burlington, On. Canada
Re: MX83 strut/brake upgrade for MA61 Tue, 23 March 2004 00:40 Go to previous messageGo to next message
Great find Norbie. Lucky for us your friend was working on it for his MXxx.
Too bad we can't get those calipers on this side of the pond. I phoned every where and no luck. I wonder if that strut is the same as the one our Cressidas?
I'm thinking of using a WRX coil over strut with the bottom half of a MA61 strut. Don't know if it will work, but I'm willing to do the research to see if it will work. Some fabrication and welding will be needed. Got in contact with a local distributor of performance parts and he said he was willing to help with the specs and part sourcing. Most every kit is sold complete and you can't get individual parts. He will get the individual parts for me if I need them.
[Updated on: Tue, 23 March 2004 00:41]
IRA11Y
Club Member
Re: MX83 strut/brake upgrade for MA61 Tue, 23 March 2004 03:09 Go to previous messageGo to next message
Nice write up Norbie.. if you have any hassles sourcing the struts gimme a yell i know where i can get a few sets
gold28
Madrid - Spain
Re: MX83 strut/brake upgrade for MA61 Thu, 25 March 2004 04:39 Go to previous messageGo to next message
So the intention is to fit these to a MA61 strut???
If so I think I have decided on my next upgrade, I'm already half way there with the struts fitted:D
I would prefer a 4 stud pattern though, I am sure there are ways around it.
[Updated on: Thu, 25 March 2004 04:40]
wilbo666
Re: MX83 strut/brake upgrade for MA61 Thu, 25 March 2004 06:04 Go to previous messageGo to next message
gold28 wrote on Thu, 25 March 2004 15:39
Nope, the plan is to replace the MA61 struts with MX83 ones Sad
(doh for me as well because I also have MA61, well SA63 struts with supra springs in my car Sad)
Milhouse
Re: MX83 strut/brake upgrade for MA61 Thu, 25 March 2004 10:20 Go to previous messageGo to next message
Hi Norbie,
Thanks for the info! Do you know if the new brakes will fit under a stock MX83 Cressida 15 inch rim?
How much do R33 calipers go for at the moment?
Re: MX83 strut/brake upgrade for MA61 Thu, 25 March 2004 12:08 Go to previous messageGo to next message
I never tried fitting anything smaller than a 17" rim over this combo, but I suspect you'll need at least a 16" rim.
Not sure about R33 calipers, I'm still trying to find a pair myself!
bbaacchhyy
Re: MX83 strut/brake upgrade for MA61 Thu, 25 March 2004 12:50 Go to previous messageGo to next message
Milhouse wrote on Thu, 25 March 2004 21:20
Hi Norbie,
Very unlikely.
I am using a 326mm disc and 300ZX calipers, and with 3 piece Simmons rims, there is less than 5mm clearance, so with std cats mags, 16" might also not make it over the Faclon/Skyline brake combo.
Justen GT4 got a set of R33 Calipers for his project, contact him for where he got them from
Michael B
Southo
Re: MX83 strut/brake upgrade for MA61 Thu, 25 March 2004 13:18 Go to previous messageGo to next message
Since Norbie showed me this a few days ago I have been looking at finding all the components and getting prices..
I found a set of struts for Norbie in BNE for about $75 each.
(Did you buy them Norbie ??)
R33 GTSt Calipers are going for anywhere between $250 and $395 a pair depending on where you call. Some wreckers offer warranty, others won't and that is reflected in the pricing. I've found a few sets in my calls, but just waiting on response from a few more places before I decide where to buy from...
(Make a few calls, there are quite a few places with them in stock...)
BA Falcon Rotors "New" are about $115 each
BA Falcon Pads "New" are from about $50 to $135 a set.
So for an MX83 Cressida - the whole package can be had for under $550. - BARGAIN !!!!!
bbaacchhyy
Re: MX83 strut/brake upgrade for MA61 Thu, 25 March 2004 13:26 Go to previous messageGo to next message
Southo,
You'll need 300ZX/Skyline pads, not the BA Palcon ones. Make sure you get a decent compound though. Don't skimp on brakes.
Regardless of the price that you pay for the calipers, get an overhaul kit. It is only $30.
Don't forget to add in new brake lines, and remeber that for an MA61, the spring perch needs to be altered, and also the shocks are different. If only $550 was it ....
Michael B
Southo
Re: MX83 strut/brake upgrade for MA61 Thu, 25 March 2004 13:45 Go to previous messageGo to next message
OOps, my bad re the pads - Not thinking properly..
I paid $120 for EBC Greens for my R32 GT-R about 3 years ago, so allow for inflation etc - they are probably closer to $200 a pair... Anyone priced/bought any recently ??
The $395 price I quoted was from a brake specialist who supplies them overhauled with 12 mths Warranty...
Braided lines are about $75 from Pittwater Brake and Clutch...
OK, revise my estimate - make that about $900.... Embarassed (for a Cressida.....
[Updated on: Thu, 25 March 2004 13:45]
bbaacchhyy
Re: MX83 strut/brake upgrade for MA61 Thu, 25 March 2004 13:55 Go to previous messageGo to next message
Southo wrote on Fri, 26 March 2004 00:45
The best price I could get for the EBC Greens was $250.
IMO, braided lines on a street car are a waste of money. Yes they are better, but you have to have everything else up to scratch, have good tyres and race cars. On the track they are worth it, but for the road, spend the money on other things.
$395 for a pair of overhauled calipers. Shit that's cheap. When looking for the 300ZX calipers here in Adelaide, some want $300 PER CALIPER AS IS !!!!!!
Michael B
Purple_Beasty
New Zealand
Re: MX83 strut/brake upgrade for MA61 Thu, 25 March 2004 22:15 Go to previous messageGo to next message
Another option if you need to stick to 15's is AUII or AUIII rotors, identical except smaller diameter (287mm). May work with the R32 calipers if they don't sit out as far. Minor machining of the disc may still be required. This is the option I will be looking at as 16 inch rally tyres are hard to find. Crying or Very Sad
Callum
c2888
Re: MX83 strut/brake upgrade for MA61 Thu, 25 March 2004 23:44 Go to previous messageGo to next message
Out of interest, how far apart are the holes at the bottom??
Do you need to get RCAs, i guess roll centres would drop by similar amounts, but you'd still get a decent amount of bump steer if you went low enough.
dodgydan
Backspace
Behind you
Re: MX83 strut/brake upgrade for MA61 Fri, 26 March 2004 04:51 Go to previous messageGo to next message
$900 still doesnt seem that expensive.
Looks like im going to have to find some 17s.
Anyone got a cheap set of is200 rims Very Happy
Purple_Beasty
New Zealand
Re: MX83 strut/brake upgrade for MA61 Fri, 26 March 2004 05:20 Go to previous messageGo to next message
Backspace wrote on Fri, 26 March 2004 16:51
I *think* the IS200 is 5x100, sure I saw pics of the wheels on an MR2. Bit of a bugger, can someone confirm?
Callum
bbaacchhyy
Re: MX83 strut/brake upgrade for MA61 Sun, 28 March 2004 22:47 Go to previous messageGo to next message
Purple_Beasty wrote on Fri, 26 March 2004 16:20
Callum
According to the good book, they are 5 x 114.3, but the offset is +50mm, which is pretty high and may cause problems with caliper clearance unless a spacer is used which then brings in other hassles ......
sticky667
usa
Re: MX83 strut/brake upgrade for MA61 Tue, 30 March 2004 03:26 Go to previous messageGo to next message
hey norbie or anyone else, just a thought but couldn't you redrill to make the camber plate sit 'square' in the strut tower?
jeremy
Re: MX83 strut/brake upgrade for MA61 Tue, 30 March 2004 03:45 Go to previous messageGo to next message
Yes, if you were worried about it you could do that.
Cyber-punk
Brisbane, QLD
Re: MX83 strut/brake upgrade for MA61 Tue, 30 March 2004 06:38 Go to previous messageGo to next message
this wouldnt work on the rears as well would it?(using mx83 rear struts?)
also, not that i can or will likely ever be able to afford them, but are JZX90\100 coilovers similar\identicle to JZX81?
Re: MX83 strut/brake upgrade for MA61 Tue, 30 March 2004 06:49 Go to previous messageGo to next message
Neither the MX83 nor the MA61 have rear struts; they have double-wishbone IRS and trailing arm IRS respectively. Needless to say the suspension components are in no way interchangeable!
I don't know much about the JZX90/100 but I suspect they have double wishbone front suspension.
Cyber-punk
Brisbane, QLD
Re: MX83 strut/brake upgrade for MA61 Tue, 30 March 2004 06:52 Go to previous messageGo to next message
Norbie wrote on Tue, 30 March 2004 16:49
as soon as i posted that i realised the error in it and tried to edit it, but it wouldnt let me :/ kept saying there was a problem
i always keep thinking i should put more thought into most of my posts...maybe one day i will
the reason i asked about JZX interchangability is because i got bored at tafe and tried looking for JZX81 coilovers and could only find JZX90\100...
Southo
Re: MX83 strut/brake upgrade for MA61 Tue, 30 March 2004 07:19 Go to previous messageGo to next message
Well,
I just managed to find a set of Front Calipers for $220.
If anyone else is after some - these are the places I have called and confirmed that they had at least one Pair... - prices ranged from $295 (to a whopping Darryl Kerrigan inspired "Tell him he's dreamin") $550
Exclusive Jap - Holden Hill SA - 08 8369-0037 - $350
Moss St Motor Wreckers - Slacks Creek QLD - 07 3208-9466 - $300
The Toy Shop - Cardiff NSW - 02 4953-7277 - $385
Japco - Woodville SA - 08 8347-3599 - $450
Niz Auto Recyclers - Keilor East VIC - 03 9331-5889 - $550
Just Jap - Kirrawee NSW - 9545-0532 - $295
the following DID NOT have any..
Formula One NSW
Adelaide Jap SA
All Jap Wreckers QLD
Currumbin Auto Wreckers QLD
Trascar - VIC
Top Imports - VIC
Edited to include prices
[Updated on: Wed, 31 March 2004 01:22]
bbaacchhyy
Re: MX83 strut/brake upgrade for MA61 Tue, 30 March 2004 21:50 Go to previous messageGo to next message
Good work Southo.
What places had what prices ?
Michael B
Southo
Re: MX83 strut/brake upgrade for MA61 Wed, 31 March 2004 01:34 Go to previous messageGo to next message
Updated post above and sent you a PM
bbaacchhyy
Re: MX83 strut/brake upgrade for MA61 Wed, 31 March 2004 02:20 Go to previous messageGo to next message
Cheers Southo. It's amazing how much they can vary. I sourced some 2 pot rear 300ZX calipers for $200, and some places wanted $200 EACH !!!!
Keep us posted on your conversion
Norbs,
I guess there is one bit to be machined, and that is a 'donut' that locates the disc centrally on the hub, as the hole in the BA disc is bigger than that of the Cressida ? Is this correct - pretty easy to do anyway
Michael B
Re: MX83 strut/brake upgrade for MA61 Wed, 31 March 2004 03:54 Go to previous messageGo to next message
Yes, a locator ring is required... forgot to mention that. Smile
Cyber-punk
Brisbane, QLD
Re: MX83 strut/brake upgrade for MA61 Wed, 31 March 2004 05:27 Go to previous messageGo to next message
http://members.optusnet.com.au/~norbee/StrutUpgrade/tn_WheelB_01.jpg
what brand are those mags?
Re: MX83 strut/brake upgrade for MA61 Wed, 31 March 2004 06:17 Go to previous messageGo to next message
They're P1 rims, don't know the manufacturer.
sticky667
usa
Re: MX83 strut/brake upgrade for MA61 Wed, 31 March 2004 07:23 Go to previous messageGo to next message
buddy club p1 racing
jeremy
Southo
Re: MX83 strut/brake upgrade for MA61 Wed, 31 March 2004 08:41 Go to previous messageGo to next message
bbaacchhyy wrote on Wed, 31 March 2004 12:20
Cheers Southo,
Norbs,
Michael B
When I bought my rims I explained I was doing a brake conversion and he asked what rotors/stud pattern etc so he could get me the right offset and ring locator until the brakes were done.
At that time I was going with 330mm C'dore Rotors and Calipers..
The Cressida Rotors are has a 60mm Centre hole whereas bother the Commodore and Falcon ones are 71.5mm - so my current 17x7 "commodore" wheels will still fit without any drama..
The factory Cressida alloys probably will not fit now...
The total rotor hat height is 3mm difference out - Cressida is 68mm, Falcon is 65mm..
Soo, of I have worked this out correctly.. The Caliper will sit about 3mm closer to the wheel spokes, the ring locators (on the front at least) can be tossed away.
As for the rears.. Apparently the US Cressidas got Vented rear rotors from the JZX81 ????
[Updated on: Wed, 31 March 2004 08:46]
bbaacchhyy
Re: MX83 strut/brake upgrade for MA61 Wed, 31 March 2004 21:55 Go to previous messageGo to next message
Nah,
The 'donut ring' I was referring to was to locate the disc onto the hub centrally.
Depending on the rim used, you may need a similar thing to ensure that the wheel is located centrally on the hub.
Hope that make sense
Michael B
Re: MX83 strut/brake upgrade for MA61 Wed, 31 March 2004 23:41 Go to previous messageGo to next message
Me means like this:
http://users.bigpond.net.au/justcallmefrank/32006.jpg
The silver ring around the hub where the rotor sits over the top.
Southo
Re: MX83 strut/brake upgrade for MA61 Thu, 01 April 2004 03:07 Go to previous messageGo to next message
Ahhh, Ok, I know what you mean now...
BTW, I forgot to mention that the place I bought my Calipers from for $110 each was RMA Spares (Southport) in QLD.. (07 5532 7914)
They are certainly the cheapest place so far and the staff there (Steve / Rod) were very easy to deal with and got back to me when they said they would.
Re: MX83 strut/brake upgrade for MA61 Thu, 01 April 2004 04:08 Go to previous messageGo to next message
I got a pair of R33 calipers from RMA as well. Ordered them yesterday over the phone and they arrived this morning!
Southo
Updated Pricing...
OK, I now have firm pricing for the parts to give you an idea if you are chasing this conversion...
R33 Skyline GTSt Calipers - $220 Pair
DBA4504 - BA Falcon Rotor - $110 Pair (Standard)
DBA4504 - BA Falcon Rotor - $280 Pair (Slotted)
DBA4504 - BA Falcon Rotor - $360 Pair (Cross Drilled and Slotted)
DB1170 - R33 GTSt Fr Pads --$ 95 Pair (Ultimates)
DB1170 - R33 GTSt Fr Pads --$ 58 Pair (Metals)
Custom made Braided lines - $130 Pair (ADR Approved)
Caliper Overhaul Seal Kit - $ TBA
Re: MX83 strut/brake upgrade for MA61 Thu, 01 April 2004 04:31 Go to previous messageGo to next message
I wonder if EBC's are available for these calipers? I must find out...
Out of interest, my calipers came with brake pads and they're green; I wonder if they're EBC Greenstuff? That would be a bonus!
E30-323ti
Re: MX83 strut/brake upgrade for MA61 Thu, 01 April 2004 04:53 Go to previous messageGo to next message
sticky667 wrote on Wed, 31 March 2004 17:23
jeremy
I think Buddy club just put their label on them, like Spoon rebadges regga master Evo's.
They are made by Kosei and are called K-1'shttp://www.wheelspecs.com/specs/wheelmodels/212
bbaacchhyy
Re: MX83 strut/brake upgrade for MA61 Thu, 01 April 2004 05:15 Go to previous messageGo to next message
Norbie wrote on Thu, 01 April 2004 14:31
Most definitely. The going price is about $250 (from several places). You can find out the pad no from the ebc website.
I was going to look at either Ferodo DS2500/DS3000 (the latter for track work) for my application.
I haven't got pads yet myself, but will wait till I need them at the last minute
Michael B
Cyber-punk
Brisbane, QLD
Re: MX83 strut/brake upgrade for MA61 Thu, 01 April 2004 10:33 Go to previous messageGo to next message
E30-323ti wrote on Thu, 01 April 2004 14:53
jeremy
i found this link...looks similar or the same perhaps?
http://www.wheelspecs.com/specs/wheelmodels/465
[Updated on: Thu, 01 April 2004 10:34]
Milhouse
Re: MX83 strut/brake upgrade for MA61 Thu, 01 April 2004 11:00 Go to previous messageGo to next message
Norbie,
The locator ring on the hub needed for the BA disc - does that have to be custom made or can you use a ring from something else?
Southo
Re: MX83 strut/brake upgrade for MA61 Fri, 02 April 2004 18:50 Go to previous messageGo to next message
Further pricing.....
I found some Caliper kits available from a few places....
- They start at about $145.00
Also found a pair of DBA Club Spec 4000 Performance series Club spec rotors for about $160 each (slotted)
EBC Greenstuff pads ( Part Number 21200 from memmory are priced from around $200-
bbaacchhyy
Re: MX83 strut/brake upgrade for MA61 Sun, 04 April 2004 22:21 Go to previous messageGo to next message
Southo wrote on Sat, 03 April 2004 04:50
Yikes !!!!
I paid $30 for the caliper overhaul kits. This included 8 dust seals, 8 piston seals, 8 metal rings to hold the dust seals in, and a wee bit of rubber grease. This does BOTH calipers !!!!
What else did you get in the $145 kit ?????????????
Michael B
Southo
Re: MX83 strut/brake upgrade for MA61 Mon, 05 April 2004 08:28 Go to previous messageGo to next message
Crying or Very Sad Crying or Very Sad Crying or Very Sad
I wish I could find them for $30.
I called quite a number of places - in the end - Nissan was the cheapest place that could guarantee supply. there were a few places that said "yeah, we might be able to make up a kit...depending on what you need" - but they would not quote a price.
Unique Autosports wanted $160
Repco/Supercheap/Autobahn/Auto One all could not supply.
I have not bought them yet - I have only bought the Calipers so far, and just priced the rest.
Yours might be a locally suppied (ie, PBR) kit - hence the $30 price tag...
[Updated on: Mon, 05 April 2004 08:30]
bbaacchhyy
Re: MX83 strut/brake upgrade for MA61 Mon, 05 April 2004 22:20 Go to previous messageGo to next message
If you want, I could always order you another set and post them to you for the costs ?
Michael B
Southo
Re: MX83 strut/brake upgrade for MA61 Tue, 06 April 2004 02:08 Go to previous messageGo to next message
That sounds like a great idea...
check your PM....
Thanks heaps
sticky667
usa
Re: MX83 strut/brake upgrade for MA61 Fri, 07 May 2004 16:46 Go to previous messageGo to next message
what's up guys
any updates on this conversion and also what to do about getting 5 stud in the rear???
trying to gather everything to get it all done
thanx
jeremy
Southo
Re: MX83 strut/brake upgrade for MA61 Sat, 08 May 2004 18:12 Go to previous messageGo to next message
So far....
Calipers $220.00 (Nissan GTS25t Factory)
Rotors - $320.00 (DBA 4000 series slotted)
Pads - - $ 80.00 (Bendix Ultimates)
Just waiting on finding a cheaper caliper overhaul kit ( best is about $145.00 so far..) - looks like genuine is the ONLY way to go, although I was chatting to a mate who owns A brake / clutch specialists workshop and he seems confident he will be able to overhaul them cheaper than that once he takes some measurements...
I'll keep you posted..
Backspace
Behind you
Re: MX83 strut/brake upgrade for MA61 Sat, 08 May 2004 18:43 Go to previous messageGo to next message
Southo wrote on Sun, 09 May 2004 04:12
So far....
Southo, where did you dind the calipers for $220?
Southo
Re: MX83 strut/brake upgrade for MA61 Sun, 09 May 2004 05:06 Go to previous messageGo to next message
Read up....
RMA Imports - Gold Coast QLD
Re: MX83 strut/brake upgrade for MA61 Sun, 09 May 2004 05:37 Go to previous messageGo to next message
If anyone is interested in a pair of R32 OR R33 calipers, I'm selling mine.
Backspace
Behind you
Re: MX83 strut/brake upgrade for MA61 Sun, 09 May 2004 14:08 Go to previous messageGo to next message
Norbie, i might be interested (the R33 calipers).
How much. And why are you selling them?
bbaacchhyy
Re: MX83 strut/brake upgrade for MA61 Sun, 09 May 2004 22:16 Go to previous messageGo to next message
Yep,
I have the MS123 rear stubs now residing in the MA61 contril arms. All I need to do now is to fit them to the car and jigger around with the brake shoes to make them fit the new discs Very Happy
Norbs, how come you are selling both of your calipers ? Got something even better in the wings ......
Re: MX83 strut/brake upgrade for MA61 Sun, 09 May 2004 22:58 Go to previous messageGo to previous message
John Duel is selling his complete setup (ie the gear I was test-fitting at the beginning of this post) so to save myself the hassle of chasing down struts etc I'm just going to buy it all and be done with it. That means the calipers I already bought are redundant, so out they go!
As for the price, I'm asking $220 for each pair.
Previous Topic:MR2 supercharger on a 22re
Next Topic:determaning what 18rg parts are from what engine..how???
Current Time: Mon Nov 2 06:56:26 UTC 2026
Total time taken to generate the page: 0.13252711296082 seconds
