Toymods » Tech & Conversions » Oil sender mounting
demuire
Ipswich
Oil sender mounting Tue, 23 March 2004 05:48 Go to next message
I want to run 2 senders for my oil - pressure and temperature. The most straightforward solution I can think for this is to run a T-piece off the block, however there are 2 issues with this: First of all there isn't much space there to fit the senders (what with the engine mount, oil cooler sandwich plate, filter etc in the way), and secondly a few people have cautioned me that because the oil pressure sender is reasonably big there's a risk of the T-piece cracking and spilling all my oil out.
What are my options for this? Can I get an oil line made up to run from the block to a remote mount for the senders? Does anyone actually make remote mounts? Or will it have to be a custom bracket? If I take this route, how do I prevent air pockets in the line? Mount the senders lower than the block? Will the oil temp sender still be accurate since it isn't sitting on the block anymore?
Any opinions/ideas?
demuire
Ipswich
Re: Oil sender mounting Tue, 23 March 2004 06:29 Go to previous messageGo to next message
Found this thread:
http://www.newcelica.org/forums/showthread.php?s=& amp;threadid=85921
Rather interesting... Don't know if it really answers any of my questions, but it's interesting nonetheless.
demuire
Ipswich
Re: Oil sender mounting Tue, 30 March 2004 06:14 Go to previous messageGo to next message
With the stock 100kW 4AGE oil cooler, it isn't a full flow system is it? If it isn't, then I assume it makes no sense to tap any senders into the oil cooler system? Is there any way to make it into a full flow system?
If I can't tap the senders into the oil cooler system, then I think the next "best" place to put the oil temp sender would be in the sump... I take it this would be just a nut of the correct thread welded onto the sump?
SeptemberSquallIndustries
Re: Oil sender mounting Tue, 30 March 2004 07:24 Go to previous messageGo to next message
You could tap a fitting into the sump plug, which has the following advantages:
1. lowest point so constant immersion
2. no modification required to sump housing
Good luck!
c2888
Re: Oil sender mounting Tue, 30 March 2004 07:44 Go to previous message
AFAIK all the OEM oil coolers on 4AGE only cool low pressure oil.
http://www.theoldone.com/articles/oilpressure
It's quite easy to remote mount the t-block, you just need some pipe flaring tools and a bit of copper line and the t-block. If you aren't familiar with it, find a enzed or pirtek truck, have it sorted for a few drinks.
dodgydan
Previous Topic:quick one - brace from block to inlet manifold on smallport 4AGE
Next Topic:Rebuilding a AE86 diff.
Current Time: Wed Oct 21 10:00:30 UTC 2026
Total time taken to generate the page: 0.0045859813690186 seconds
