Toymods » General Car Talk » Just got me some splits.....
Callifo
Gawler, SA
Just got me some splits..... Tue, 23 March 2004 12:34 Go to next message
Got my Jaycar Response 6.5" splits today in the mail and I have noticed that the tweeters have two pairs of the +ve and -ve plugs (2x +ve, 2x -ve). Just wondering why this is so and should I just hook them as normal (to a pair of +ve/-ve)?
Also is there any problem with the woofers resting on the side intrusion bars in the doors? Got some thin foam in between to reduce bumping but is there any other problems?
boris
On probation
Brisbane, Queensland
Re: Just got me some splits..... Wed, 24 March 2004 01:49 Go to previous messageGo to next message
I ordered some of these last night and should be getting them today... wooohooo!
Re: Just got me some splits..... Wed, 24 March 2004 06:16 Go to previous messageGo to next message
they are actually part of the same terminal on the tweeter if you look closely. Just hook up whichever pair is easier
As for the woofers, as long as they dont vibrate, it dont matter.
boris
On probation
Re: Just got me some splits..... Wed, 24 March 2004 07:30 Go to previous messageGo to next message
Got them! Just need my car back now...
shinybluesteel
melbourne
Re: Just got me some splits..... Wed, 24 March 2004 08:48 Go to previous messageGo to next message
are these the kevlar splits?
if so, are they going into a sprinter?
if you answered yes to both of the above,
time for me to give something back to my lovely, lovely toyota community Very Happy
i just installed these in my car, and i am pretty happy with how it turned out, but it took quite a while to install them, as there isnt much space in the doors.
i mounted the tweeters on aluminium strips in the standard 4 inch speaker holes so cunning car theives wont see them on my dashboard.
the woofers took some thought, after cutting away a fair amount of metal on the drivers side, i got sick of it and just made some spacers out of 16mm MDF to make it a bit easier, trial fitted them a hundred times and then bit the bullet and cut the holes for them.
they fit perfectly now and dont vibrate against anything.
to run wires into the doors, i bought some clear flexible tube from bunnings and ran it through a hole i made in the removable rubber plug/seal that is in the door (kinda oval shaped) the drilled holes in the body, installed grommets and ran the wire through, make sure you use pipe big enough to fit the speaker cable easily inside it, its very hard to push/pull through.
if you like i will measure the distance from the edge of the doorskin to the edge of the speaker grille, it will save you heaps of trouble.
oh yeah, as a point of interest, the "reciept and general shit holder" in the drivers door would have got int the way of the speaker, so i pissed it off. it has loads of japanese writing on it and the inscription "AE85" so there is a bit to add to the "is an AE86 an AE85 discussion"
have fun!
[Updated on: Wed, 24 March 2004 08:51]
boris
On probation
Re: Just got me some splits..... Wed, 24 March 2004 08:51 Go to previous messageGo to next message
so WHAT DO THEY SOUND LIKE?!?!?!? Very Happy
shinybluesteel
melbourne
Re: Just got me some splits..... Wed, 24 March 2004 08:57 Go to previous messageGo to next message
pretty good, althoguh im no audiophile, im still comoing to terms with having one speaker "really close to my right ear firing sound at my foot" and one speaker "really far away firing pretty much at my ear"
but im happy with them for what i paid.
i need to do some more testing, my car is sitting in my back yard with a busted ass 4AC (to clarify, its actually broken, i know all 4ACs are pretty busted ass) so the battery goes flat pretty quick.
oh yeah, and you will need some sort of sub in the boot too, naturally!
Callifo
Gawler, SA
Re: Just got me some splits..... Wed, 24 March 2004 09:57 Go to previous messageGo to next message
Ive put the woofers in part closest to the hinge of the door. Just fits but protrudes by about 2mm too much but the door trim covers that up easily. Moved the junk holder on the drivers door right to the end of the door near the back seat. Looks all good....
Tweeters I have put where the cig lighter is and the other spare hole on the opposite side. Crossovers are taped to the top of the headunit (inside the dash) and I have wiring to do tomorrow morning.
Will get some pics later Very Happy
[Updated on: Wed, 24 March 2004 10:43]
Callifo
Gawler, SA
Re: Just got me some splits..... Wed, 24 March 2004 10:38 Go to previous messageGo to next message
Relocating the cig lighter to the spare plastic square on the left side of the steering wheel. Will need to make the wires longer though because they are so damn short.
My stock 4" speaker holes already have some 4" speakers in there but the problem is that they are too far below. It makes the 6x9s in the back very dominant. The 6.5"s should make up for bass in the front because those 4" werent doing a very good job.
Also have to find something to wrap the woofers in so that they cant get wet from the water in the door when it rains.
Shinybluesteel: Where did you put the woofers so that you had to cut metal?
[Updated on: Wed, 24 March 2004 10:42]
Callifo
Gawler, SA
Re: Just got me some splits..... Thu, 25 March 2004 03:10 Go to previous messageGo to next message
THE WITZL: You seem to know enough about these splits. I hooked all the wiring up and have found that the woofer is working but the tweeters arent. I hooked it up in a pair, or am I supposed to hook up one from each pair?
There isnt any +ve or -ve written on them so Im dont know, dont want to try reversing them unless I am certain.
Anyone be able to help me fairly soon?
Edit: Ok I got them running but unlike the woofers there doesnt appear to be a +ve or -ve, how do I know its running the right way round?
[Updated on: Thu, 25 March 2004 11:47]
Callifo
Gawler, SA
Re: Just got me some splits..... Thu, 25 March 2004 12:37 Go to previous messageGo to next message
Anyone ^^^
shinybluesteel
melbourne
Re: Just got me some splits..... Fri, 26 March 2004 07:02 Go to previous messageGo to next message
what do you mean?
these are the kevlar splits right? the crossovers are marked + and -, from memory the tweters and the woofers are marked + and - too.
if not, then plug the wires into the speakers the only way they will go (small plug goes on small spade, big plug goes on big spade) then clamp them to the crossover in this way
copper colored cable goes onto positive, silver colored cable goes to negative.
easy as that!
Callifo
Gawler, SA
Re: Just got me some splits..... Fri, 26 March 2004 11:56 Go to previous messageGo to next message
Well I finished it all today but...
I know everything was labelled +ve -ve except for the tweeters. They just had plugs which meant nothing really. At first I plugged into one pair of plugs and it did nothing. Then I plugged one from each pair and off it went. The tweeters have 1 large plug and one short but fat plug in each pair.
I just made sure that +ve and -ve are the same way around on each tweeter (not sure if its the correct way round though Confused ).
Callifo
Gawler, SA
Re: Just got me some splits..... Fri, 26 March 2004 12:02 Go to previous messageGo to next message
Apart from my little dilema with one of the woofers, all of it sounds great. The splits and the 6x9s do an awesome job.
Callifo
Gawler, SA
Re: Just got me some splits..... Sun, 28 March 2004 04:03 Go to previous message
Well I got the pics, although in the first pic it seems the camera lens is a bit dirty (specky). Havent posted the actual pics because they are just under 1.5mb so links are here.
http://www.users.on.net/nperin/Pictures/Car/Speake rs001.jpg
http://www.users.on.net/nperin/Pictures/Car/Speake rs002.jpg
http://www.users.on.net/nperin/Pictures/Car/Speake rs003.jpg
http://www.users.on.net/nperin/Pictures/Car/Speake rs004.jpg
Notice in the second pic where I put the cig lighter, probably move it again later but its not much of a problem because I only use it once in a bluemoon. Strange how the flash made the cig tray look brown Laughing
Previous Topic:Indicator Flashing Too Fast
Next Topic:*WINGE* lock your car!!!
Current Time: Sat Oct 31 00:22:49 UTC 2026
Total time taken to generate the page: 0.035540103912354 seconds
