Toymods » Tech & Conversions » Hilux diff swap & tailshaft shortening.
Jayem
Finland
Hilux diff swap & tailshaft shortening. Tue, 23 March 2004 20:54 Go to next message
I read this and sub-links also but I didn't find a word about shortening tailshaft.
http://forums.toymods.org.au/index.php?t=msg&t h=19281&rid=1627&S=c453a1411a411ccd17e7428 08c1f58f9
I remember that shortening was mandatory and I also remember that somebody mentioned about it, in some topic.
I just cant find it.
Anyway, Im dumping old noisy T-series and fitting Hilux diff in. How much shorter tailshaft I should have?
BTW. Im asking this because I cant measure my diffs right now!
CrAiGzEE
south of the big smoke
Re: Hilux diff swap & tailshaft shortening. Tue, 23 March 2004 23:41 Go to previous messageGo to next message
i believe it is 20mm, u need to shortern it by that
Jayem
Finland
Re: Hilux diff swap & tailshaft shortening. Tue, 23 March 2004 23:50 Go to previous messageGo to next message
Thanks!
Looks like CE-70 Tailshaft is direct fit Cool .
CrAiGzEE
Re: Hilux diff swap & tailshaft shortening. Tue, 23 March 2004 23:57 Go to previous messageGo to next message
what is a ce70?
Jayem
Finland
Re: Hilux diff swap & tailshaft shortening. Wed, 24 March 2004 00:02 Go to previous messageGo to next message
RWD Diesel Corolla
Jayem
Finland
Re: Hilux diff swap & tailshaft shortening. Wed, 24 March 2004 00:06 Go to previous messageGo to next message
http://toyotacover.50megs.com/kytkinkoppa/Kardaanit1nettiin.jpg
http://toyotacover.50megs.com/kytkinkoppa/Kardaanit2nettiin.jpg
Up most Corona TT-132
Middle Corolla CE-70
Undermost Unknown Toyota tailshaft
BTW. Shafts arent bended Razz
ra23celica
Re: Hilux diff swap & tailshaft shortening. Wed, 24 March 2004 03:48 Go to previous message
I can only speak from my own experience, with a RA23 and a RN27 tailshaft.
It is more than 20mm in this case...something closer to 35mm.
No reputable diff specialist will shorten your tailshaft by any set amount without wanting to measure up your car in final form
before committing to cut it down.
And, in my case, there are different lengths in each section of both these two piece shafts, so if I want to use the existing chassis captive nuts to bolt up the centre section, I have to get both pieces shortened.
Just my observations, FWIW.
Mitch.
Previous Topic:1989 AE92 $AGZE is it MAP or MAF
Next Topic:Weber Carbs and return lines?
Current Time: Fri Oct 16 13:05:38 UTC 2026
Total time taken to generate the page: 0.0054159164428711 seconds
