Toymods » Tech & Conversions » Weber Carbs and return lines?
alex_ta22
Newcastle, Hunter Valley
Weber Carbs and return lines? Wed, 24 March 2004 01:01 Go to next message
Do weber carbs need the return line?. I pulled the return line off and nothing is coming out of it?.
The reason i ask is that i'm swapping a 3t out of my parts car into my car, and my car doesnt have the return line.
Re: Weber Carbs and return lines? Wed, 24 March 2004 02:12 Go to previous message
they don't "need" return line if your fuel pump provides the correct pressure...
return line is used when you have a 'post carby' fuel pressure regulator.
webbers like to have about 3psi ish....
i have my return blocked off and am using a "fuel miser 4cyl" crappy pump, that does 2-3psi.. works like a charm.
Previous Topic:Hilux diff swap & tailshaft shortening.
Next Topic:That stuff you spray in your injector/spark holes to clean your pistons
Current Time: Mon Oct 12 22:33:34 UTC 2026
Total time taken to generate the page: 0.092616081237793 seconds
