Toymods » General Car Talk » why do worn tyres have no grip and slicks have lots?
lang
why do worn tyres have no grip and slicks have lots? Wed, 24 March 2004 09:19 Go to next message
as per the title,
how come tyres with worn rubber, like not fully bald down to the lining or anything, but with allmost no tread left, how come they have less grip than tyres that have more tread.
a worn tyre has more rubber in contact with the roads surface, so wouldnt you expect it to have more grip, because that is the concept behind a slick tyre. more rubber in contact with the road means more grip, but with my tyres, 2 are pretty worn down, and 2 are still good, and the end with the worn ones has less grip and i rotated them and the same thing apply, the end with the worn ones has less grip
i dont understand how come more rubber in contact with the road reduces the grip, is it crappier rubber down low or what?
Re: why do worn tyres have no grip and slicks have lots? Wed, 24 March 2004 09:30 Go to previous messageGo to next message
same weight - but greater area in contact with road.
how to simulate this at home?
1. stand on a large towel which is laid flat on kitchen floor - flatmate gently pulls on towel to drag you (still standing) across room
2. laydown on towel, spreading your weight around on the towel - in theory, you should be easier to drag you around the room
3. drink lots of beer in celebration of such an inane thing to do in the kitchen... Wink
where as slicks are a different rubber compound than your average tyre rubber - requiring much greater force to 'break traction' when in contact with road surface.
[Updated on: Wed, 24 March 2004 09:31]
lang
Re: why do worn tyres have no grip and slicks have lots? Wed, 24 March 2004 09:31 Go to previous messageGo to next message
but by that theory, woudlnt fitting wider tyres also reduce your grip,
or having a tyre with half the amount of contact patch as a normal tyre increase the grip
i still dont get it, mabye im stupid
Classique71
Colac, Victoria
Re: why do worn tyres have no grip and slicks have lots? Wed, 24 March 2004 09:38 Go to previous messageGo to next message
alot could do with compounds too ?
lang
Re: why do worn tyres have no grip and slicks have lots? Wed, 24 March 2004 09:45 Go to previous messageGo to next message
Classique71 wrote on Wed, 24 March 2004 19:38
yeah i guess so, but i wouldve though that having a worn tyre with more rubber in contact with the ground would be similar to just having a wider tyre.
i guess the grooves must have more to do with it than just to disperse water on a wet road. like i know the design effects handling, but i woudlve thought more a larger contact patch would equate to more grip
torque
UK at moment
Re: why do worn tyres have no grip and slicks have lots? Wed, 24 March 2004 10:56 Go to previous messageGo to next message
Compounds have everything to do with it Very Happy
With slicks you do a burnout to warm them up - they need to be warm. The outside of the tyre actually liquifies! You can hear it sticking to the tarmac when a decent drag car reverses after a skid.. It even leaves tracks of rubber!
Draza
Wahroonga
Re: why do worn tyres have no grip and slicks have lots? Wed, 24 March 2004 12:37 Go to previous messageGo to next message
Slicks also use alot different tyre set up. They use lower tyre pressure, and the tyre wall on slicks folds over itself (there are two tyre walls)and provides more surface area to the ground when first taking off and the tyre then unfolds itself providing the acceleration that would have been lost by the wheels spining.
Torque is right that the tyres need to warm up, if u take a good look the burnouts that they do at the start of the 1/4 mile they position their wheels on a puddle of water to start the burnout.
So slicks work so well because the have a much better compound and a different tyre setup than street tyres.
If anyone disagrees with me or thinks i'm wrong, plz state ur view here. I have only read a few articles on the subject and only been to the drags once, so feel free.
Re: why do worn tyres have no grip and slicks have lots? Thu, 25 March 2004 00:07 Go to previous messageGo to next message
Yes it's mostly compound. Worn street tyres have no grip because the rubber has gone hard and crappy. Slicks are uber-soft and sticky, although they also become harder and less sticky as they wear. Note that in racing classes where street tyres must be used, it's common practice to grind most of the tread off new tyres; the rubber is still new so you have just as much grip, but the smaller tread blocks don't squirm around as much.
As for the contact patch thing, the contact patch for any tyre is a function of only two factors: tyre pressure and weight. For a car with a given mass with a given tyre pressure, the surface area of the tyre's contact patch will be constant regardless of the tyre size. A wider tyre will change the shape of the contact patch (wider and shorter) but the surface area will remain the same.
Youngy
Eskilstuna, Sweden
Re: why do worn tyres have no grip and slicks have lots? Thu, 25 March 2004 01:46 Go to previous messageGo to next message
Norbie wrote on Thu, 25 March 2004 11:07
Are you sure about that?.............. Rolling Eyes
Re: why do worn tyres have no grip and slicks have lots? Thu, 25 March 2004 01:53 Go to previous messageGo to next message
if that's true, why do v8 supercars/f1 cars bother with uberwide rubber?
edit: not debating, as I have no idea. But I'm considering what tyres to get for my car, and woul love to know the theory behind tyre choice
[Updated on: Thu, 25 March 2004 01:53]
rob_RA40
c'town, NSW
Re: why do worn tyres have no grip and slicks have lots? Thu, 25 March 2004 02:44 Go to previous messageGo to next message
http://www.chris-longhurst.com/carbibles/index.htm l?menu.html&tyre_bible.html
chrisss
melb
Re: why do worn tyres have no grip and slicks have lots? Thu, 25 March 2004 03:11 Go to previous messageGo to next message
ok that link was pretty good.
it basically says as norbi did that the contact area of wider tyres will be the same as for narrow tyres.
but the shape will change - wide tyre has a wide thin patch.
narrow tyre has a long narrow patch.
but total area is the same - end of story!
not end of story totally
but this begs the question why does the shape affect the grip of the tyre - why do wider tyres grip better?
[Updated on: Thu, 25 March 2004 03:13]
lang
Re: why do worn tyres have no grip and slicks have lots? Thu, 25 March 2004 05:16 Go to previous messageGo to next message
Norbie wrote on Thu, 25 March 2004 10:07
that still dosent explain why the worn down tyres i have have less grip than the ones with lots of tread left when they are all the same age....
and isnt a worn tyre with less gaps in the tread equivalent to a tyre that is wider?
(not trying to be difficult, im just having trouble making sense of the whole thing)
Re: why do worn tyres have no grip and slicks have lots? Thu, 25 March 2004 06:46 Go to previous messageGo to next message
lang wrote on Thu, 25 March 2004 15:16
It's not so much the age of the tyre, it's the heat cycling the rubber is subjected to during normal use. If tyre A has more wear than tyre B and both are the same age, it's clear that tyre A has had a harder life, ie more frequent and/or more extreme heat cycling. This is what causes the rubber to "go off" and lose its grip.
Not sure what you mean by that...
draven wrote on Thu, 25 March 2004 11:53
I never said wider tyres weren't beneficial, I just said they don't give you a larger contact patch! There are other factors to consider, and it pretty much comes down to compound again.
A wider tyre has a shorter contact patch, which means any given point on the tyre will be in contact with the road for a shorter period of time. It also means the overall area of the tyre's contact surface is larger. What this means is you can run a softer compound without overstressing the tyre, ie overheating the rubber to the point where localised melting occurs. Melted rubber = skids = lack of traction and accelerated wear.
Of course this is oversimplifying things a great deal; tyre design and construction is an extremely complicated business these days.
lang
Re: why do worn tyres have no grip and slicks have lots? Thu, 25 March 2004 08:43 Go to previous messageGo to next message
Norbie wrote on Thu, 25 March 2004 16:46
what i was getting at is imagine the lines that follow shortly to be the contact patch of the rubber on the road.....
Tyre A: -- -- -- (normal Tyre)
Tyre B: -------- (normal Tyre with its grooves worn off)
Tyre C: -- -- -- -- (wider Tyre)
So as you can see, the normal tyre with its grooves worn out has a longer contact patch on the road, even though its not actually any wider, its contact length on the road is similar to a wider grooved tyre that still has its gaps. hope that makes sense.
but yeah i agree with your point about the rubber in the more worn tyres having had a harder life.
as for what you said about localised melting of the rubber, i had that occur when i went out on street tyres at mallala, after a few lots of 8 laps the rubber was gettings so hot that the grooves in the tread would be allmost filled in with melted rubber, eventually it got so bad it caused me to spin out, i was just taking a corner normally when all of the sudden i lost all grip basically and just went straight off on a tanget to the curve i was turning on and off the track.
Mr DOHC
Re: why do worn tyres have no grip and slicks have lots? Thu, 25 March 2004 09:29 Go to previous messageGo to next message
chalk and cheese
how long is a piece of string
ect ect
the reason drag slicks grip so well is they are VERY soft, i.e. if u pick up a normal commodore tyre and rim and thorw it at someones face u will fuck them up, if u did the same with a full sized slick u will knock them over but PROBABLY not injure them
They also run about 6-8 psi so the sidewalls "ripple" heavily when they launch, which allows them to hook up better
On launch, most group 1 drag cars probably have a contact patch of about 15-18 odd inches {approximated}, but by the end of the track it can be 12 inches of track,
most of the reason they stick to the tarmac on reverse is because of a traction compound just called VHT {has a more technical name}, they spray this on the WHOLE track to help accomodate traction.
If u r at a street meet they probably wont put it down {not emuff power out of most of the cars to neccetate it}, but some times at street meets a very quick car comes out and tries to run and the run just goes to shit caus he's slipping all over the joint {thats why tony khoury's old probe hit the wall, 1600hp on an un-prepped track Confused }
any car leave tracks of rubber
here is what i mean by tyrewall distortion
http://www.nhra.com/2004/gallery/tf/Larry_Dixon.jpg
Re: why do worn tyres have no grip and slicks have lots? Thu, 25 March 2004 09:39 Go to previous messageGo to next message
much appreciated... gotcha now.
spectral
Re: why do worn tyres have no grip and slicks have lots? Thu, 25 March 2004 10:14 Go to previous messageGo to next message
just to extend on what Norbie was saying..
The size of the contact patch doesn't change when choosing a wider tyre.. *at the same pressures*. It just gets shorter, ie:
This provides better cornering because the size of the lateral contact patch is greater, giving more sideways grip
It also explains why wide tyres tramline (follow imperfections in the road), because their longitudinal grip is less than a narrow tyre which tracks nicely.
The only way to increase your contact patch is to lower the tyre pressure, as seen in all dragracing and 4WD beach driving.
lang
Re: why do worn tyres have no grip and slicks have lots? Thu, 25 March 2004 10:31 Go to previous messageGo to next message
what effect does the circumference of the tyre have on the shape of the contact patch? (what happens with a larger overall rim and rubber size)
torque
UK at moment
Re: why do worn tyres have no grip and slicks have lots? Thu, 25 March 2004 13:11 Go to previous messageGo to next message
Any tyre will leave tracks after a burnout, but it is a LOT greater with proper slicks - you can hear it sometimes!
I thought VHT was just sprayed the first half of the track?
I've learnt a bit from this thread - but i'm having trouble with the idea that the contact patch doesn't change, even a bit..
EG: a 175/65/15 compared to a 285/65/15 - is this not going to have more rubber in contact with the ground at all?
chrisss
melb
Re: why do worn tyres have no grip and slicks have lots? Thu, 25 March 2004 15:04 Go to previous messageGo to next message
torque - learn this equation p = l/a
where p = pressure, l = load, a = area.
if the pressure is the same (eg 30psi), the load the same (eg 1000kg car) the area must be the same.
the original question is bad - why do worn tyres have no grip and slicks have lots?
this is a pointless question, its like comparing apples to oranges. its stupid to compare a worn out street tyre with a racing slick!!
the question should be :
seeing as racing tyres have no grooves why dont my worn tyres grip as good as when they have lots of tread? - now we can make a decent comparison.
but heres another question basically asking the same thing :
- would a slick that has been grooved have the same,less or more grip than an ungrooved slick? why?
and by grip im not talking about racing conditions,im imagining for example the start line take off where the tyres are at low temps and have not had time to heat up.
lang
Re: why do worn tyres have no grip and slicks have lots? Thu, 25 March 2004 23:10 Go to previous messageGo to next message
chrisss wrote on Fri, 26 March 2004 01:04
if you actually read the first post in this topic youd see that the title was an attempt at a vague description of what the topic contanined rather than all the bullshit ones that say "click here please reply" at least you had some idea what you were going to be looking at when you entered the thread.
if you DID actually read the first post properly, i was comparing 2 normal street tyres, one with the grooves worn off, one with a good amount of tread left. a slick was merley mentioned to help describe what the tyre was LIKE with the grooves worn off. it was never actually a discussion about the compound used. it is blantantly obvious to everyone that slicks have more grip than a street tyre. it was a reverence to the fact that no grooves are used.
now that youve read that properly, you will see im comparing 4 of the same kind of tyre, 2 worn and 2 not worn. i was never comparing a worn street tyre with a slick tyre.
the question wasnt bad it was the exact same question that you have so brilliantly rephrased in your post, the title of the topic was a guide to what was in the thread not the actual question.... as you would have known if you bothered to read it!
Mr DOHC
Re: why do worn tyres have no grip and slicks have lots? Fri, 26 March 2004 07:26 Go to previous messageGo to next message
torque wrote on Thu, 25 March 2004 23:11
yes it is much greater
some only spray half track but the big tracks {willowbank/WSID ect} spray the whole thing
chrisss
melb
Re: why do worn tyres have no grip and slicks have lots? Fri, 26 March 2004 08:02 Go to previous messageGo to next message
settle down lang...my response was not meant to insult you...where did I actually call you anything....I knew what you were trying to ask, but there were a lot of responses crapping on about compounds - the first 3 responses mention compounds.
Im not interested in getting into a tit for tat bullshit discussion, trying to prove to people participating in this forum who is the smarter - why do I give a shit.
what I am interested in knowing is the answer to your (poorly worder) question....thats all!!!
norbi, in the 7th post, was the first to actually try and answer the underlying question.
sorry for trying to help find the answer.
lang
Re: why do worn tyres have no grip and slicks have lots? Sat, 27 March 2004 00:41 Go to previous messageGo to next message
heh mabye i was being a bit over the top Smile
Farmsci ST162
Re: why do worn tyres have no grip and slicks have lots? Sun, 28 March 2004 13:52 Go to previous message
chris
there are so many posts about tyre compounds because that is the answer. Your average street tyre is made of a very hard rubber. hard rubber is FAR less grippy than soft rubber BUT it is VERY durable in comparison the soft rubber. lasts longer, thats what your average driver is most concerned about. SO a worn out street tyre has less grip because the rubber is old and stiff.
A slick tyre is very soft and has a shitload of grip BUT is made from very soft rubber, therefore durability suffers greatly. If you own GT3 on playstation 2 go out on a track with supersoft slicks and take a hairpin, then go get a super hard tyre and try take the same corner at the same speed.
As for comparing its surface area with that of a new street tyre its a matter of the tyres life, the more worn out one has clearly been subjected to the most abuse and life all things rubber degrades in quality through abuse. Just look at aged rubber bushings, eventually they become hard and brittle. and given a street tyre is designed to only last a specific number of kilometers most manufacturers will choose a compound that can be made cheaper to last that number of kilometers.
Long story short, road tyres are made of a hard, less grippy compund that slicks. Worn out street tyres grip less than new ones because the already less grippy rubber has begun to degrade in quality.
Previous Topic:RECONDITIONED TA22 STEERING BOX...WHERE?
Next Topic:VLD-11I *A70 Supra
Current Time: Fri Oct 30 21:56:54 UTC 2026
Total time taken to generate the page: 0.016905069351196 seconds
