Toymods » Tech & Conversions » Sprinter strut/stub axle integrity
gabe
Sprinter strut/stub axle integrity Wed, 24 March 2004 10:09 Go to next message
All,
Just curious as to the strength of the sprinter strut. More so the stub axle.
I am in the process of trying to upgrade the brakes on my sprinter and the most common approach is to change to an RA-60 strut due to its larger stub axle.
My question is why??
I have never heard of anyone having dramas with the strength of the sprinter stub axle.....Are they known to bend, crack or completely break? Or is the main reason for upgrading to the celica strut simply due to the fact that its easier to do a comprehensive brake upgrade??
Basically I am trying to determine if I should work out an upgrade with my standard strut or the RA60 unit.
Also, I am aware of the associated camber issues with the celica strut (up to 3 deg positive I have heard). Will adjustable strut tops be enough to cancel this AND give me a few degrees negative camber??
Gabe
Re: Sprinter strut/stub axle integrity Wed, 24 March 2004 10:30 Go to previous messageGo to next message
1. Most people are interested in the RA60 brakes, not necessarily the RA60 stub axles. The larger stub axles give you access to a whole range of different hub/brake swaps.
2. No, adjustable strut tops allow fairly limited camber adjustment and it won't be enough. You have to take more drastic measures, like longer control arms or get the struts bent.
CLG
Perth, Western Australia
Re: Sprinter strut/stub axle integrity Thu, 25 March 2004 01:09 Go to previous messageGo to next message
Try the earlier RA23/28/40 struts they're bigger, easier to fit vented brakes too, and still run the older stub axle angles that you'll need. The adjustable tops with later model struts will only allow you to get zero camber at the most.
Youngy
Eskilstuna, Sweden
Re: Sprinter strut/stub axle integrity Thu, 25 March 2004 01:23 Go to previous messageGo to next message
Personally (and as Norbie has indicated) I think the people thinking that the sprinter strut is weak is just a load of rubbish.
I have much larger discs and calipers on my modified sprinter struts and no issues have been encountered with the stub axle or the strength of the strut.
If I was at all worried I would get the strut gussetted, which I would do with any strut if it came down to it. But this is over kill on a road car, common for rally cars though.
ae86trueno
Re: Sprinter strut/stub axle integrity Thu, 25 March 2004 02:24 Go to previous message
I have managed to bend a stub axle only once but also moved the engine cross member across a couple of cm, so you have to have a fairly big impact to bend one.
Ben
AE86 Trueno 4AGE.
Previous Topic:4agze ignitor problems - where can i get new one or is there a aftermarket option?
Next Topic:Anyone know any repairers who'll weld in new door sills?
Current Time: Fri Oct 23 11:45:19 UTC 2026
Total time taken to generate the page: 0.0055880546569824 seconds
