Toymods » Tech & Conversions » 5M-E Woes...
ZZT231
melbourne.vic.au
5M-E Woes... Thu, 25 March 2004 23:56 Go to next message
Hey All,
Currently I am trying to chase up parts for the engine. I am looking for new pistons but I can't seem to find the ones that I would like (Flat top - Not Dished). Does anyone know any equilivent piston tops which are flat which will fit the block.
Any Ideas anyone?
Cheers.
Re: 5M-E Woes... Fri, 26 March 2004 00:04 Go to previous messageGo to next message
5mge (early) and 6mge are both flat top, and I believe they are the same.
Re: 5M-E Woes... Fri, 26 March 2004 00:41 Go to previous messageGo to next message
Personally, I would fit the 5MGE high tops.
ZZT231
melbourne.vic.au
Re: 5M-E Woes... Fri, 26 March 2004 00:43 Go to previous messageGo to next message
Should I also go and get a 7MGE crank and rods and put it in the bottom of the 5ME?
Cheers.
ZZT231
melbourne.vic.au
Re: 5M-E Woes... Fri, 26 March 2004 00:47 Go to previous messageGo to next message
Also, thanks GT and CrUZsida for your reply.
Read your email. I left a suitably longwinded reply there. Smile
Re: 5M-E Woes... Fri, 26 March 2004 01:02 Go to previous messageGo to next message
http://www.acl.com.au/web/aclwebsite.nsf/8df7d3f7b 605537a4a2569660082eda8/f7914230e2e6c7cc4a25696700 0e22bb/$FILE/PP03.pdf
Look at pg 251 of that file (15 meg). ACL 5ME pistons are dished. 5MGE pistons have 0.1mm extra compression height (no big deal - you have a mile of clearance) and are mildly high top to boot. This should put your static compression ratio well above 9:1. If you can then use a 7M crank and rods, the extra swept volume crammed into the slightly smaller combustion chamber should put you very close to the desired 10:1 you ought to be looking for.
ZZT231
melbourne.vic.au
Re: 5M-E Woes... Fri, 26 March 2004 02:43 Go to previous message
Thanks GT,
Check your mail.
Previous Topic:MX73 Cressida questions
Next Topic:AE86*engine question
Current Time: Fri Oct 23 12:04:45 UTC 2026
Total time taken to generate the page: 0.0092620849609375 seconds
