Toymods » Tech & Conversions » Crank Angle censor in 3t-gte
Tris
Crank Angle censor in 3t-gte Fri, 26 March 2004 00:46 Go to next message
Does any one know of a crank angle censor that will fit in to a 3t-gte, or of any way of setting up individual coil packs on one.
thank
tris
Re: Crank Angle censor in 3t-gte Fri, 26 March 2004 00:55 Go to previous message
I have a direct fire setup on my 3T-GTE. Though its in conjunction with an Autronic SMC and MSD DIS-4.
Basically I have a custom made trigger disc on the crank to supply the Autronic crank angle, and then used the gutted dizzy housing with a 1 tooth setup for reference signal.
Ignition outputs from the Autronic bridge into 4 channel MSD. So I can run all 8 plugs still in a waste spark setup.
Joel
Previous Topic:AE86*engine question
Next Topic:1jz with jdm 2jz map sensor upgrade n 550cc injecters
Current Time: Fri Oct 23 03:50:09 UTC 2026
Total time taken to generate the page: 0.0061500072479248 seconds
