Toymods » Tech & Conversions » Intake Resonator Purpose
BlackSupra
Intake Resonator Purpose Fri, 26 March 2004 01:33 Go to next message
Designed to reduce intake noise or are they part of the whole tuned intake system.... or both?
By removing them, will i only make the intake louder? or will it adversely affect performance?
ta. Very Happy
Re: Intake Resonator Purpose Fri, 26 March 2004 01:35 Go to previous messageGo to next message
Muffler
Re: Intake Resonator Purpose Fri, 26 March 2004 01:56 Go to previous messageGo to next message
Part of intake system...
koen
Re: Intake Resonator Purpose Fri, 26 March 2004 02:02 Go to previous messageGo to next message
I can't really comment generally, but removing the resonator from my Swift GTi made induction noise significantly louder, gave me more power above 4 grand and a slight flat spot around 3500.
So, both Smile Defintely a worthwhile mod on a G13B though.
Re: Intake Resonator Purpose Fri, 26 March 2004 02:03 Go to previous messageGo to next message
I suppose it depends on the engine
But the one on the 5mge would be muffler only
as would the one on the 1uz
[Updated on: Fri, 26 March 2004 02:04]
Re: Intake Resonator Purpose Fri, 26 March 2004 02:12 Go to previous messageGo to next message
CrUZsida wrote on Fri, 26 March 2004 10:03
And this is based on what factual groundings? Razz The world of NA tuning is so finnicky, I think you'd be surprised how much of a difference they make with and without.
Re: Intake Resonator Purpose Fri, 26 March 2004 02:22 Go to previous messageGo to next message
No factual groundings, just the design and location of the 'unit' indicates that it has very little to do with airflow
SeptemberSquallIndustries
Re: Intake Resonator Purpose Fri, 26 March 2004 03:12 Go to previous messageGo to next message
As in most cases! What it *does* do is change the total displacement of the intake tract, aparently leading to significant changes in intake tuning and resulting motor behaviour.
Re: Intake Resonator Purpose Fri, 26 March 2004 04:05 Go to previous messageGo to next message
Does the volume of the pre-throttle intake tract have much relevance to intake tuning? Post-throttle I can understand, but I wouldn't have thought pre-throttle would be that significant...
Re: Intake Resonator Purpose Fri, 26 March 2004 04:22 Go to previous messageGo to next message
muffler and integral part of intake tract. if it is pre throttle, then it is there for WOT help...
think about it... what is loud noise? large amplitude waves of air compression.
what is intake tuning? getting the length of the intake right so the reflected large amplitude waves hit the intake valve while it is still open and stuff more air in there.
problem is, this is in small rpm bands, and at other rpm, there can be unwanted pressure reflections in the intake, causing flatspots Wink
the resonator is designed to add different frequency waves into the intake tract, in essence to provide cancelling or dampening to the nasty reflections, resulting in a smoother torque curve.
it is possible that removing it could help at certain rpm, but you will almost defintiely see a negative effect somewhere (with a stock motor)
thten again, some ARE just noise cancelling.. same principle, just not large enough to actually effect the induction process....
dyno with, dyno without, and let us know Very Happy
Re: Intake Resonator Purpose Fri, 26 March 2004 04:25 Go to previous messageGo to next message
Norbie wrote on Fri, 26 March 2004 15:05
at WOT, the open throttle does not pose much of a restriction to resonance, and the whole intake tract is the resonator, so pre-throttle resonator would have an effect. how large depends on design. at anything less maybe half throttle, the throttle acts effectively to block a lot of the resonance in the intake,
resonator is tuning aid when the intake tract is not good perhaps Wink
SupraPete
Re: Intake Resonator Purpose Fri, 26 March 2004 04:57 Go to previous messageGo to next message
http://www.planetsoarer.com/resonator/resonator.ht ml
BlackSupra
Re: Intake Resonator Purpose Fri, 26 March 2004 06:35 Go to previous message
Thanks Pete, awesome article! Cool
Previous Topic:MA70 Question - Aero Top
Next Topic:4agze into a ke30
Current Time: Sun Oct 25 17:53:10 UTC 2026
Total time taken to generate the page: 0.0058910846710205 seconds
