Toymods » Tech & Conversions » fittin 1uz into my hilux this mon
sideshow
fittin 1uz into my hilux this mon Fri, 26 March 2004 07:27 Go to next message
hey guys
will be fitting my 1uz into my hilux on monday
i will be runnin a crown 1uz with an auto
have done most of the wiring while engine is on the floor
not to hard just time consuming
u dont need a front cut to get these runnin
the old pertol 22r is for sale
ill let u know how it goes
hopefully take 3 to 5 days
i will be doin some notes on it hopefulyl if i get time
want to make it look standard
[Updated on: Fri, 26 March 2004 07:29]
Re: fittin 1uz into my hilux this mon Fri, 26 March 2004 07:30 Go to previous messageGo to next message
Nice work
Get me pics, and prolly a copy of the mounts!!! I have a few friend with Hilux's who would love to do this conversion!!
sideshow
Re: fittin 1uz into my hilux this mon Fri, 26 March 2004 08:33 Go to previous messageGo to next message
the mounts look easy
not to sure at moment
wont be modifying much on mounts
just hope to cut and relocate hilux brackets on chassis
and use hilux rubber mount
Re: fittin 1uz into my hilux this mon Fri, 26 March 2004 09:31 Go to previous messageGo to next message
Good stuff! Look forward to it.
RobST162
Re: fittin 1uz into my hilux this mon Fri, 26 March 2004 09:56 Go to previous messageGo to next message
hey mate your hilux already looks the ticket, but it's gonna fly now!
good luck with it! Smile
sideshow
Re: fittin 1uz into my hilux this mon Fri, 26 March 2004 10:36 Go to previous messageGo to next message
thabnks
i just have to piss of the bull bar
the engine bay will look good i hope
i have it pictured in my head
shpould manage to hide most of the wiring bar the thick loom for the fi
but i might run a box tubin over it
dont want to just wrap it in black tape
but i ran the alternator wires under the dizzy leads and under the black covers so u cant see much of it
then i pulled the dash apart
found wires for tacho temp and oil
then ran wires for them behind the dash instead of in the engine bay
and i hope to use the A/T oil temp light as the check engine light
and im in luck the hilux has an electronic speedo
so it has an output for the ecu
plus my hilux is 4speed auto
and the crown auto seems similar in size
so hope the auto side of things will bolt straight up
if im lucky the tailshaft will fit straight in
so far looks like it wil be easy
[Updated on: Fri, 26 March 2004 10:40]
sideshow
Re: fittin 1uz into my hilux this mon Sat, 03 April 2004 08:22 Go to previous messageGo to next message
hi all everything is just bout done
wiring is just bout hidden
i have found the perfect oil filter for the 1uz into a tight spot
i can get them for 20 bucks if anyone needs one
this meant i didnt need to get a remote oil filter adapter
hope to get my sump on tuesday and start the bastard
engine bay looks way cleaner that the original shitbox 22r
i have pics on my website but they not up to date
ill get some pics of the job nearly done on tuesday
im finally learnin all the shit about the diff types of 1uzs
so im goin to make a book bout them if i get time
Mr DOHC
Re: fittin 1uz into my hilux this mon Sat, 03 April 2004 08:48 Go to previous messageGo to next message
sik, when my mates gets his manual 1JZ going i'll post pics too
sideshow
Re: fittin 1uz into my hilux this mon Tue, 06 April 2004 11:48 Go to previous messageGo to next message
hey guys
my 1uz runs
she starts beaut
i modified the orig fuel pickup in the tank and fitted efi internal pump
so much easier and cheaper
they wanted 300 for efi tank which still needed mods
just need rad hoses done tomorrow
and exhaust on tues
she sounds good
i got pics of engine mounts and new sump on my web site
CrAiGzEE
south of the big smoke
Re: fittin 1uz into my hilux this mon Tue, 06 April 2004 12:48 Go to previous messageGo to next message
did you use the orginal computer with this?
sideshow
Re: fittin 1uz into my hilux this mon Tue, 06 April 2004 20:54 Go to previous messageGo to next message
yep
i used orig engine ecu and orig auto ecu
its a crown v8 so it has 2 ecus
bit of a bitch to wire up
once everything is runnin ok i wwill rewire the ecus again
try make it neater and easier to understand
KDog
Re: fittin 1uz into my hilux this mon Tue, 06 April 2004 23:10 Go to previous messageGo to next message
Make sure you do some easy maintenance whilst the engine is out.
1. Spark plugs and lead if needed.
2. Timing belt - should be done on all cars regardless if the belt looks new.
3. Idler bearings.
4. Water pump.
5. Reseal of Power Steering pump - they pretty much all leak until you do this.
6. Rebuild alternater - will at least have worn brushes from PS fluid going into it.
7. Complete flush of trannie fluid with Toyota type4, including inside the TC housing. Actually do this when the engine is running, much simpler.
8. Clean engine bay - it doesn't get any easier with no engine in there.
SupraPete
Re: fittin 1uz into my hilux this mon Wed, 07 April 2004 01:45 Go to previous messageGo to next message
Yeah all good advice KDog.
Where did you get your idler bearings from? I think Toyota quoted about $200 for each of them (2). Thats one thing I didn't change, which I would've really liked to.
KDog
Re: fittin 1uz into my hilux this mon Wed, 07 April 2004 01:59 Go to previous messageGo to next message
I just took the old ones out and took them to the bearing shop. They had them in stock. I think around $50 each. This was many years ago though.
Re: fittin 1uz into my hilux this mon Wed, 07 April 2004 12:47 Go to previous messageGo to next message
HKSPete wrote on Wed, 07 April 2004 09:45
I'm guessing you are talking about the timing belt idler bearings, not the main belt idler bearings?
KDog
Re: fittin 1uz into my hilux this mon Wed, 07 April 2004 23:32 Go to previous messageGo to next message
Yeah sorry about that. Can't remember what I did with the normal idlers. I'll try and pull one off this weekend. From memory they weren't tricky. I can't remember any of the bearings as such being non standard. But it was 5 years ago and I did a lot of bearings.
SupraPete
Re: fittin 1uz into my hilux this mon Wed, 07 April 2004 23:54 Go to previous messageGo to next message
CrUZsida wrote on Wed, 07 April 2004 22:47
I was talking about the timing belt idler bearings, not the fan belt ones.
(whats a "main" belt? joke)
sideshow
Re: fittin 1uz into my hilux this mon Thu, 08 April 2004 10:16 Go to previous message
well its finally running
i drove it up and down driveway testing it
has no exhaust so thing sounds like a race car
had a prob with speed sensor
the speed sensor that comes with crown gbox has a shitload of pulses every revolution
and in 1st gear my speedo was reading over 120 kmp
so the ecu was goin from 1st to hi heheh
i fitted a speedo sensor which i modded to suit my gbox awhile ago
it has 4 pulses every rev and now its good
cant wait to get it engineered next week and exhaust on it
Previous Topic:1UZ FOR MA61
Next Topic:Fuel gauge stuffed on an AE82
Current Time: Sun Nov 1 01:33:33 UTC 2026
Total time taken to generate the page: 0.059531927108765 seconds
