Toymods » Tech & Conversions » Whipper snipper carbie problem solved.
DiZ_
The Eastwood MASSIVE !
Whipper snipper carbie problem solved. Fri, 26 March 2004 10:11 Go to next message
Ok I have a whipper snipper 2 stroke engine , the fuel was old and soiled and the carbie needs a very good clean.
I don't have much experience with carbs at all , but a general clean out should just involve a little dismantling and alot of carbie cleaner right?
[Updated on: Sat, 27 March 2004 06:01]
Re: Cleaning small carbie. Fri, 26 March 2004 14:28 Go to previous messageGo to next message
yup, about right.. either petrol or carby cleaner, whatever takes your fancy (mmmm carby cleaner smell Very Happy )
just remember where all the bits came from, adn what way round they go. if possible, take pics...
shouldn't be too many parts in there..
have fun Very Happy
DiZ_
Re: Need some help with my whipper snipper motor. Sat, 27 March 2004 02:43 Go to previous messageGo to next message
All right , its all clean , new fuel hose , fresh fuel with 40:1 mix in it.
But there is a problem , it doesnt want to start , it half kicks alot and sometimes roars to life but dies before I can do anything about it.
Update - these are the instructions for starting
1. Spark switch to on , full throttle , set to choke , pull cord till motor pops
2. Switch to partial , full throttle , pull cord till engine starts , hold full throttle for 5 seconds.
3. Swtich to run.
Now I can't get the slart past stage 1.
[Updated on: Sat, 27 March 2004 02:48]
c2888
Re: Need some help with my whipper snipper motor. Sat, 27 March 2004 03:06 Go to previous messageGo to next message
usually the spark plug is cactus, just cos it sparks doesn't mean it's good.
or get a can of aerostart, pssst
dodgydan
DiZ_
Re: Need some help with my whipper snipper motor. Sat, 27 March 2004 03:16 Go to previous messageGo to next message
Had the spark plug out , looks fine , not corroded or fouled at all.
DiZ_
Re: Need some help with my whipper snipper motor. Sat, 27 March 2004 04:39 Go to previous message
Well I have come to the conclusion that the carbie is not giving any fuel , thanks to the use of aerostart . It starts , burns the aerostart , then dies.
UPDATE -
All is well now , with the help of a mate I took it apart and cleaned the diaphrams which had becomed blocked , now it works a charm.
Thanks to all who helped in narrowing down the problem.
[Updated on: Sat, 27 March 2004 05:55]
Previous Topic:cylinder head tension 4 3sgte
Next Topic:fuel tank overflow &bastard plug
Current Time: Fri Nov 20 22:54:51 UTC 2026
Total time taken to generate the page: 0.0046570301055908 seconds
