Toymods » Tech & Conversions » HELP! - 18r-gu PCV valve (center of rocker cover)
rx793
Perth, Western Australia
HELP! - 18r-gu PCV valve (center of rocker cover) Fri, 26 March 2004 11:33 Go to next message
I am unable to run a hose from the center valve to the back of the air filters because there is no room for a hole anywhere.
I am contemplating the small center filter in the middle of the rocker cover and i need to know if they are legal!!!
ORRR what else i can do to get it over pits coz they will pick that up for shure.
THanks
PLEASE ASAP!!! need info by 10:00 2moroo mornin
gabe
Re: HELP! - 18r-gu PCV valve (center of rocker cover) Fri, 26 March 2004 11:50 Go to previous messageGo to next message
what filters are you running??
rx793
Re: HELP! - 18r-gu PCV valve (center of rocker cover) Fri, 26 March 2004 11:52 Go to previous messageGo to next message
Twin Chrome K&N filters...!!!!
gabe
Re: HELP! - 18r-gu PCV valve (center of rocker cover) Fri, 26 March 2004 11:56 Go to previous messageGo to next message
Im sure a filter over the hole isnt legal (plus it leaves shit on the underside of your bonnet). drill a small hole (12mm ish) and put a fitting into that.........
Re: HELP! - 18r-gu PCV valve (center of rocker cover) Sun, 28 March 2004 09:40 Go to previous messageGo to next message
are you guys also using 1-way valves on yours?
gabe
Re: HELP! - 18r-gu PCV valve (center of rocker cover) Sun, 28 March 2004 09:49 Go to previous messageGo to next message
The setup I have seen doesnt have a small inline valve but an electronic job......about the size of 2 matchboxes stacked on top of one another. A valve is not necessary but preffered.........
Steve M
Re: HELP! - 18r-gu PCV valve (center of rocker cover) Sun, 28 March 2004 23:52 Go to previous message
We were using a hose straight from the centre of the cover to the rear of the filters without a valve, but the filters kept getting clogged with oil.
To fix this we put a tube from the cover to a catch can and then a tube from the catch can to the filters, it has made a big difference, but still is not perfect.
We couldn't find a PCV valve for the G so that was what we had to do.
The filters that attach to the top of the cover hole are not legal.
Previous Topic:Corolla beater
Next Topic:Pod on 97 Celica
Current Time: Sat Oct 24 09:09:56 UTC 2026
Total time taken to generate the page: 0.0053110122680664 seconds
