Toymods » Tech & Conversions » water temp Vs. thermostat & fan
water temp Vs. thermostat & fan Mon, 20 May 2002 07:44 Go to next message
Hello, i want to know more about what time a thermofan should turn on in relation to the temperature the thermostat opens up etc?
currently i am running a 3t-gte engine.
thermo stat opens about 86 i think
thermofan comes on at 92 and turns off at 88 or there abouts.
TE72_Turbo
Re: water temp Vs. thermostat & fan Mon, 20 May 2002 09:02 Go to previous messageGo to next message
on my 3TGTE, I have an 82 degree thermostat, the motor runs between 84 & 88 degrees normally. my thermo turns on at 91 degrees, and turns back off at 88.
What radiator are you using??
Phil
Re: water temp Vs. thermostat & fan Mon, 20 May 2002 23:17 Go to previous messageGo to next message
I am still running the stock RA28 radiator, recored though and a 14" craig davies fan.
Gets hot in traffic though so trying to work out if i had something setup wrong or too small radiator/fan.
Thanks for the info you gave me.
rob_RA40
c'town, NSW
Re: water temp Vs. thermostat & fan Mon, 20 May 2002 23:26 Go to previous message
it sounds like your fans are comming on a bit too hot
what is the temp guage at when the fan comes on? 3/4 in the red?
Previous Topic:Re-torqueing head bolts - Hot or Cold??
Next Topic:CAMS Affliated.. I wanna rally farkin!
Current Time: Wed Oct 28 16:49:14 UTC 2026
Total time taken to generate the page: 0.0094940662384033 seconds
