Toymods » Tech & Conversions » Need advice on replacement clutch
Skip
Need advice on replacement clutch Sat, 27 March 2004 13:32 Go to next message
Successfully destroyed my clutch at the drags the other night, poor thing had only done about 500km. So I need to replace it with something alot stronger. Ive got 2600lb clamping force at the moment, my plate is 8.5" 21 spline x 29mm organic Toyota. I dont want to change my pressure plate or go button cause 4wding and boat launching will be impossible, will an inorganic plate material do the trick?
Re: Need advice on replacement clutch Sun, 28 March 2004 08:40 Go to previous messageGo to next message
Yeah, change the plate material, plus try and find a lot more clamp than that if possible... Otherwise, multi plate may even be needed! Shocked Have a chat to Direct Clutch in Brissy.
Re: Need advice on replacement clutch Sun, 28 March 2004 11:26 Go to previous messageGo to next message
You'll find a 5+ puck button clutch won't be too harsh. I have one and it's perfectly drivable in stop-start traffic, so with appropriate gearing it shouldn't be a problem doing what you want to do as well. This is probably the only effective solution to your problem without spending uber dollars (ie twin-plate as mentioned above).
Skip
Re: Need advice on replacement clutch Sun, 28 March 2004 12:22 Go to previous message
I suppose the other solution is to make a bigger diameter flywheel i.e. more recessed ring gear and new pressure plate and clutch plate Sad
Previous Topic:3t-gte Airflow Meter pinouts.
Next Topic:Re: Half cut for EP82
Current Time: Sat Oct 24 03:17:06 UTC 2026
Total time taken to generate the page: 0.057894945144653 seconds
