Toymods » Tech & Conversions » Base ignition timing for 4AGZE
TE72_Turbo
Base ignition timing for 4AGZE Sat, 17 August 2002 10:30 Go to next message
what does the second mark (not TDC) on the crank pulley relate to in in ignition timing for the 4AGZE?
any one out there got a 4AGZE manual, or know where to get one?
Phil
feral4mr2
Bundaberg, Qld.
icon7.gif  Re: Base ignition timing for 4AGZE Sat, 17 August 2002 11:40 Go to previous messageGo to next message
Freak the second mark is 10 degrees, when the motor is warmed up, the wire jumper between T and E1 on the diagnostic box, the second marker (10 degrees) is where the pionter should be for base timing. when you pull the jumper out the pointer should be on or around the third mark (this is supposed to be 16 degrees). i always have my base timing set in between the two marks,([__[*[) (about 13 degrees), i have not had any trouble with detonation, having it advanced a bit.
TE72_Turbo
Re: Base ignition timing for 4AGZE Sat, 17 August 2002 13:06 Go to previous message
thanks mate. I just needed to know so i can use it for a reference when setting the ignition figures in the haltech software.
Previous Topic:Ra60 Headlights :( What are my options????
Next Topic:Air Flow Meter upgrade
Current Time: Fri Oct 16 05:00:01 UTC 2026
Total time taken to generate the page: 0.086312055587769 seconds
