Toymods » Tech & Conversions » mx62 cressida discs etc
people100
Rocklea qld
mx62 cressida discs etc Sun, 28 March 2004 08:59 Go to next message
will mx62 cressida discs and calipers fit a ra40 struts. how far from fitting would they be. Is it a worth while upgrade or apart from the onviously corona/hilux/pug conv whats a good easy upgrade.
SeptemberSquallIndustries
Re: mx62 cressida discs etc Sun, 28 March 2004 09:05 Go to previous messageGo to next message
By my understanding the T13# strut is even easier to fit in place of RA23/28/40 strut than in TA22.
In this case I find it extremely improbable that you'll find an easier and more sound upgrade that Corona struts, four piston Hilux calipers, and vented discs to suit as discussed previously.
Re: mx62 cressida discs etc Sun, 28 March 2004 09:24 Go to previous messageGo to next message
the cressida calipers and rotors DO NOT fit onto a RA40/early celica strut. For starters, the rotors sit in a different position such that they dont fit into the RA40 caliper, and then the cressida caliper wont fit onto your RA40 strut because of both caliper bolt spacing (100mm for MX62 and 90mm for MX73) and that the cressida caliper mounts in the OTHER side of the caliper mounting bracket from the RA40 caliper.
Trust me dude... i tried.
NOTHING is an easier upgrade than these following steps, in order of ease and cost....
# RT-132 struts calipers and rotors (twin pot), XT-130 is only single pot
# Pug 604? vented discs with the RT-132 calipers
# Hilux 4-pot calipers
people100
Rocklea qld
Re: mx62 cressida discs etc Sun, 28 March 2004 09:42 Go to previous messageGo to next message
Is it worth going to all tha trouble though. I do wanna do street sprints but i dont think big brakes like that are needed are they. will i need bigger brake booster with that upgrade
ChuckLandwehr
Re: mx62 cressida discs etc Sun, 28 March 2004 11:33 Go to previous messageGo to next message
OR: you could use:
RT132 Struts,
RA60 Discs, and
MX62 Calipers.
Requires that the strut caliper mounting holes be re drilled, and a small spacer used at each caliper bolt hole.
Done it 3 times works a treat, Ideal conversion for those on a budget.
regards Chuck.
Re: mx62 cressida discs etc Sun, 28 March 2004 11:37 Go to previous messageGo to next message
What are the MX62 calipers like? How many pistons, what size pads? What size are the RA60 discs? Vented standard?
people100
Rocklea qld
Re: mx62 cressida discs etc Sun, 28 March 2004 11:52 Go to previous message
what sort of stopping power can i get with that. Its gonna be used in street sprint events so need some stopping on a budget,
Previous Topic:Hilux diff breather valve
Next Topic:Power to weight ratios
Current Time: Sun Oct 25 03:40:13 UTC 2026
Total time taken to generate the page: 0.011469841003418 seconds
