Toymods » Tech & Conversions » TA22 with RT132 struts: Dampers to use?
SeptemberSquallIndustries
TA22 with RT132 struts: Dampers to use? Sun, 28 March 2004 09:45
Refer the following diagram (regards Grega):
http://forums.toymods.org.au/index.php?t=msg&t h=26807&prevloaded=1&rid=3250&S=74339a 0231221cf4c765d919a8b1a9de&rev=&reveal=&am p;start=60&count=60
Using the standard strut in TA22 requires shortening of the strut body below the spring seat by 15mm to maintain the standard lower strut length.Additionally lower springs than standard will be used, incorporating a ~30mm drop (ie. standard off-the-shelf lowered springs).
Obviously an OEM RT132 insert would risk bottoming out with ~2" taken out of its travel. Any alternatives available which fit RT132 pattern but 2" (~50mm) shorter?
[Updated on: Wed, 31 March 2004 06:39]
Previous Topic:z2 soarer air susp -> springs?
Next Topic:Mx63 cressida brakes on to Ta 22 strut
Current Time: Sat Oct 24 22:06:28 UTC 2026
Total time taken to generate the page: 0.0066940784454346 seconds
