Toymods » Tech & Conversions » How do i read boost
dispatcher
Malaysia,Kuala Lumpur
How do i read boost Mon, 29 March 2004 07:53 Go to next message
i know i know...it's silly...but i've no idea. Just installed a boost meter proper. 0 is at 12 o'clock..then 5 10 14 etc and the opposite is in reverse i think. So when i start it goes anti clock to 20..psi vacumm ?
So how much boost is good and right and how should it be actually ?
ed_ma61
Lost in the K hole
Re: How do i read boost Mon, 29 March 2004 08:19 Go to previous messageGo to next message
when idling, you should be reading negative (anticlockwsie) as the manifold is under vacuum and the turbo is not boosting. when driving along, NOT boosting, you should see numbers, still in the negative, but less so than at idle, even aproaching zero...
then once you hit boost, the dial will swing clockwise, and start reading positive pressure. how much? depends what car, engine, and how youve set things up.
dispatcher
Re: How do i read boost Tue, 30 March 2004 05:36 Go to previous messageGo to next message
Alrite that sounds pretty much what's happening now.
Thanks Ed.
dispatcher
Re: How do i read boost Sun, 04 April 2004 07:11 Go to previous messageGo to next message
Just to add what i noticed today, crusing at 100 km.
Boost gauge reads -5-10 PSI...is this right ??...When i floor the pedal, and when boost comes on..it's moving towards 5-10 psi positive, Is this normal ??
Re: How do i read boost Sun, 04 April 2004 07:21 Go to previous messageGo to next message
yep, that's normal.
when you're cruising, the throttle is only partly open (you're not flooring it) so the turbo is not spooling fast enough to make boost .
Think of it like this (even though it's not comprehensive): the further you put your foot to the floor, the more boost you'll make
dispatcher
Re: How do i read boost Sun, 04 April 2004 14:39 Go to previous message
Righto..thanks...normal...phewww
Previous Topic:What pod filter do you use?
Next Topic:heat resistance of radiator rubber
Current Time: Sat Oct 24 09:10:43 UTC 2026
Total time taken to generate the page: 0.0039260387420654 seconds
