Toymods » Tech & Conversions » ke70 drift car?
Chris Davey
sunny coast, qld
ke70 drift car? Mon, 29 March 2004 09:09 Go to next message
hello all,
Upon returning to australia from Japan, i have been thinking about getting into a little bit of drifting. I have no experience at present.
I own a ke70 corolla which has a 5k engine in it with a webber, extractors and exhaust. What mods should I do to make this a decent drift car? I don't want anything too crazy as this would be a budget project.
I was thinking, shocks (what type?), springs (what rate?), 15's with lower profile tyres, most likely a locked diff. Do this to start with and see if the 5k is up to it. If it isn't, maybe a 16v 4age conversion? I will do a search on the swap, but if anybody wants to throw in some info., it would be great!
Thanks in advance
Chris
shcao
Re: ke70 drift car? Mon, 29 March 2004 09:35 Go to previous messageGo to next message
I was thinking the exact same thing..
I know a lot of ae86 suspension components are the same, so you won't have a problem sourcing parts..
If i had money, I'll get like 8kg springs at the front, 6kg springs at the rear. Short stroke shokers all round, and some decent sways... That'll get you sliding good... makes a very unconfortable street car tho.
strip everything out of the car.. including the backseat, and get yourself a 4age 100kwater... Should be mighty fast.. Considering how much the car will now weigh, the power to weight ratio should be enough for you to have some decent fun..
Getting an LS for the Ke70 is a ripp off. You'll either have to adapt, or get one from japan, which will set you back thousdands either way.. Go locker, or try one of those cheapo phantom grip LS thingy's ... Smile
let us know how it goes! Smile
rock on.
Drift_AE71
adelaide
Re: ke70 drift car? Mon, 29 March 2004 09:42 Go to previous messageGo to next message
yer i have a ca18det ae71 and its awsome for drift
had it out last night for its 1st real slide sesion and it was nuts
with stock motor/boost/exhuast in the wet holds 4th gear slides no worrrys
and its so precise
but not many ppl what ke70/ae71 they want the "inital D" "wank factor"
ill save my cash thanks,thats nore mods later on
shcao
Re: ke70 drift car? Mon, 29 March 2004 09:54 Go to previous messageGo to next message
hahah...
I was seriously thinking about buying a white ke70 and doing a home panda job on it Smile Smile..
But in all seriousness, I wanna buy one while my sprinter is being worked on at the panel shop Smile
Chris Davey
sunny coast, qld
Re: ke70 drift car? Mon, 29 March 2004 12:33 Go to previous messageGo to next message
you said that ke70's have similar suspension setup to ae86s. Does that mean that ae86's have the shocky seperate from the spring like my ke70?
what brand of shocks make a shorter stroke shocky for a ke70?
ae95
Re: ke70 drift car? Mon, 29 March 2004 12:57 Go to previous messageGo to next message
Yes, if your talking about the rear then yes the shocky is seperate from the spring.
There are many brands that make short stroke shocks for the ae86/ke70/ae71/te71
KYB
TRD(Made by KYB)
Tokico
Koni
..etc
theres probably heaps more. My personal pick are the Tokico HTS shocks, very nice shocks.
shcao
Re: ke70 drift car? Mon, 29 March 2004 13:15 Go to previous messageGo to next message
yeah, same goes for the ae86,
the ae86 has a live axel rear.
just get coilovers for the front..
and do springs and shocks seperately for the rear..
rotorace
Re: ke70 drift car? Tue, 30 March 2004 09:47 Go to previous messageGo to next message
I have seen a drift video and there was a black ke70 with a 4agte in it, it was the wildest little car on a tight drift track, but no power steering meant the dude was flat out trying to steer/correct it all the time. still looked very cool.
t_temperley
Re: ke70 drift car? Wed, 31 March 2004 04:36 Go to previous messageGo to next message
a wet road
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: ke70 drift car? Wed, 31 March 2004 04:51 Go to previous messageGo to next message
ae95 wrote on Mon, 29 March 2004 22:57
KYB
TRD(Made by KYB)
Tokico
Koni
..etc
just a note, TRD are made by Tokico.
onejayzed
Re: ke70 drift car? Wed, 31 March 2004 06:13 Go to previous messageGo to next message
i have often pondered why no-one else has done this. Razz essentially, the 2 cars are the same, supension wise, but one is a 2door (obviously stiffer body) and one is a 4door (no real theft value).
kudos for thinking outside the square. Cool
Chris Davey
sunny coast, qld
Re: ke70 drift car? Wed, 31 March 2004 22:44 Go to previous messageGo to next message
thanks mate Smile
the only reason i thought of it, was because i have one in the front yard Smile
TraeKe86
Perth, W.A
Re: ke70 drift car? Thu, 01 April 2004 00:41 Go to previous messageGo to next message
they guy your thinking about rotorace in japan, his ae71, was supercharged still, cause i remember seeing the video half way thru my conversion and thinking to myself how hard it would be to leave it supercharged than to turbo it, but yeah, it went allright.
for suspension in my ke70, at the moment im using cut springs (haha) but with ra60 shocks and brakes up front, i have a set of coilovers to go in, its a bit of mystery where the coilovers came from but they have y31 written on top, and supra written on the rotors, but they arnt supra rotors, so damned if i know.. they should fit in allright thou.
im building mine for drag first, then drift, have to beat my mates mark4 supra first Smile 11.8 i have to beat.
anyways..
oh, its a 4agte in a ke70.. wish i started with a ae71.. doh!
-bc
TraeKe86
Perth, W.A
Re: ke70 drift car? Thu, 01 April 2004 00:43 Go to previous message
oh and that ke70 in japan was brown, not black..
and had the dodgiest rose joint conversion i've even seen haha
Previous Topic:C-one bodykit importer?
Next Topic:What has an F series 3.7-3.9:1 lsd?
Current Time: Sun Nov 1 21:41:28 UTC 2026
Total time taken to generate the page: 0.0047578811645508 seconds
